AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › HOME NEEDS TO BE TERMINATED! help with that, **QUESTIONS**
post #1 of 6
basically i have a home thats all wired up and dry walled up... i need to terminate it, from the open house to the plates.
basically how much is it to just term the plates?
or how much is it to term from the open house box to the plate?
any other way to deal with this?
post #2 of 6
Is it your home or are you the builder?
post #3 of 6
im a new company, we dont really to just terms, mainly its a package like 100 runs + 7.1 HT projector. 4 cam cctv.... in a package....
ive never just done terminations.
ive called a place and he said they charge $30 each run from the open house box to the the plates terminated.... is it that cheap?
post #4 of 6
I terminated my house, 15 rooms, and have done construction. His $30 quote sounds about right as that is what I was thinking. You are supplying the plates and connections, he is just doing the labor, correct? And they will test each line to make sure it is connected properly?
But if you have 100 runs, I think a better price may be negotiated, depending on how busy they are. Say down to $25 a run. But I would say they are still in the ball park @ $30.
post #5 of 6
What did this poor house do to deserve termination? Soliciting for a felony is a felony.
post #6 of 6
$30 per termination?!?! All this recent talk on the forum about new construction and wiring makes me appreciate the work I did myself more and more..
I have 5.1 in living room, and 6 zone whole-home audio (cheap way currently - with a speaker selector)... but I did all wiring, and terminations myself for under $300... without actually pricing it all out again, Id guess closer to $250 for everything - 16/4 speaker cable, CAT5e, RG6, and 22/4 for alarm AND ALL terminations.
  Back to Forum: Home A/V Distribution
