My Current set up is
Screenplay 4805 Projector (480 p)
PS3 for dvds and Blu Rays
Blu Rays look awesome on my projector even wtih it only bein ga 480 p
I was going to wait for the price to decrease in the 1080 p dlp projectors
but I have heard that tv's and projectors are gboing to be going back up
A few years ago , you couldnt find a 1080 p DLP projector for under like $8000 , Im wanting one around the $1200- $1500 range.
Possibly even $2000 , I just dont want to spend that much right now.
I am sure that my bulb is coming to and end soon lol I have no idea the exact amount of hours on it , because they hae reset the hours count at the factory twice
Do I need to check on that bulb, I dont want it exploding or anything , or is it programed to not come on anymore after the 4000 hours?
Whenever it goes out , more than likely I will be upgrading to something else,
even if its only to 720 p
. for me it was a simple choice. $1550 for 1080p with lense shift (required due to placement issues). At the time i bought my PJ, there was no other option for that price range.
