AVS › AVS Forum › Gaming & Content Streaming › HD Radio › DAB reception vs FM same antenna ?
post #1 of 17
Do you need different antenna to receive DAB if your tuner is equipped or you can use FM antenna ?
post #2 of 17
What's DAB?
post #3 of 17
DAB is Digital Audio Broadcast, or sometimes called DRB Digital Radio Broadcast.
post #4 of 17
So that's what it stands for. What is it?
post #5 of 17
http://www.uk-dab.info/stationlist.php
I am not very familiar with DAB, but I gather from the above website that UK DAB digital radio transmissions operate on the following frequencies:
11B: 218.640 MHz
11C: 220.352 MHz
11D: 222.064 MHz
12A: 223.936 MHz
12B: 225.648 MHz
12C: 227.360 MHz
12D: 229.072 Mhz
FM Broadcast Band can vary depending on what country you are referring to, but it often starts at about 76 or 88 mHz and may stop at 107.9. Considering the frequency range of FM vs. DAB probably the answer is usually no, but also keep in mind that any antenna may get some signal at various frequencies, so I think a discone antenna may be an option if you are looking for an antenna that will work for both. I have used discone antennas and there is no gain, but they are very wide banded. Mine is rated from 100 mHz to about 1 gHz.
http://en.wikipedia.org/wiki/FM_radio
http://en.wikipedia.org/wiki/FM_broadcast_band
http://www.avforums.com/forums/dab-d...endations.html
http://www.aerialsandtv.com/fmanddabradio.html
post #6 of 17
Digital Radio and Digital TV are still transmitted on a analog signal with digital data superimposed on that on that analog signal .Trying to transmit digital data by itself is not going very far without a carrier.The same antenna you used for regular radio will also work fine for digital (HD)
post #7 of 17
Actually I was looking for an indoor antenna .My tuner has an FM antenna connection, and another one for DAB . I contacted Dynalab and they recommended ST-2 for FM but said no good for DAB, for that they said to go for SR-100 ( 20 miles max range ).
http://www.magnumdynalab.com/fmantennas-overview.htm
post #8 of 17
What country are you in, zeiter (does that imply Germany)? We don't have DAB in the U.S. since those frequencies are in use for other things.
post #9 of 17
I'm in Canada and we have so far about 60 DAB stations I think. Does not concern me much, as I heard DAB range is about 50 KM. I live in Montreal, and there are about 12 or 13 DAB stations. Tuner I got ( Arcam ), in menu setting , says DAB for US and Canada. And by the way, my Tuner came from Arcam US as Canada were out.
post #10 of 17
Does this radio support DAB+? That's closer to what HD Radio provides with codec and error correction.
post #11 of 17
Yes it does support DAB+ where available. Just remember if you decide to buy it that DAB is optional. You'll have to check with your dealer to have the chip installed. Maybe other brands are standard, I don't know.By the way I learned that in the US, L frequency for DAB is restricted to military communications only, so not sure what's used instead for DAB if any.
post #12 of 17
DAB is not broadcast in the U.S. on any frequencies. HD Radio is the only digital radio system here.
post #13 of 17
That freqs, is in somewhere in 1.4 GHz for DAB "L-band" I heard they are having a lots of problems mostly due to microwave's propagation issue.
Just google it, on Canadian DAB's broadcast issues and why they started in the bad place to do it.
2-21-09
post #14 of 17
DAB in Canada is pretty much dead. Nobody monitors the signal. Some stations go with left or right channel missing for months. Also some are in mono even though on FM they are stereo.
Here is the link to Canadian forum that discuses DAB and HD radio. http://www.digitalhome.ca/forum/show...t=34783&page=8
post #15 of 17
I've complained about engineers messing up their HD audio but the posts on that thread show that Canadian stations have let their DAB stations become completely unlistenable.
I hope DAB+ will revive it. It has a better codec and much more error correction than old DAB. I like the idea of digital audio being broadcast with a non-proprietary codec and in its own band.
post #16 of 17
Deception. Module for DAB+ I ordered from my Arcam dealer won't be coming at all. I got a call saying that Arcam dropped the hole DAB+ thing for North America.It will be only for Europe, and the optional internal module won't be available for North America . So that cancels the whole post, and which antennna does not matter anymore. No DAB or DAB+ for North America ( at least from that manufacturer ).
post #17 of 17
DAB+ uses the same codec as HD Radio which is AAC+. However Ibiquity licenses it under HD Radio codec to make it easier. DAB+ will be a failure just like DAB, and it is completely incompatible with with any DAB receivers.
Many countries that had DAB and shut it down, are actually testing HD Radio.
Spectrum is at the premium nowadays, and can be used for other and better things beside duplicating what is already on the air on FM and AM.
The only country that has any DAB that actually people use is UK, and even there it sucks. Many stations are in mono, even if they are stereo on FM, and many stations are at 80Kbps Mpeg1 audio that is the worst audio codec ever developed.
In Canada they will probably be switching to HD Radio at least for FM. There is already station that broadcasts it. Also many people that live close to US border are buying HD Radio tuners to listen stations from US.
  Back to Forum: HD Radio
