Originally Posted by Gugu_s
Hi,
I just want to let everybody know, that after heaving problems with my Parasound C2 in and out for a year, thanks to Richard, and people from here, the Parasound service here replaced the plastic housing with the crimped connectors, and soldered the cables directly to the PSU, and everything is working fine now for the past few days. So remember, if anyone has problems with P7/C1/C2/etc. ( they all use the same PSU as far as I know, if it acts crazy, check the wires on the PSU connected with the plastic housing!!!!!
Thanks in advance,
Gustav
Hi,
Thanks in advance,
Gustav
I've had a problem with my P7...First they thought it was the RS232 circuit, so one was sent here and it was repaired locally.
That lasted for 2 weeks, then the controls locked up again..
So Richard then thought it was a wire harness, for the same reason you have mentioned. They sent me a slightly different one, I installed it and it worked for a week, then locked up again. Then started working again after about another week. Then locked up again.
So now I'm suppose to send it back to SF to be checked out.
