Originally Posted by
Scadden24
ok so i have tried all that you said. i have just the one hdmi out going to the tv and two hdmi in to the avr. so the problem i am having is lets say for example i am watching a blu ray and i switch to my directv and switch back i cant get the bluray to come back on even if i stop and then play again to start the handshake over again. i dont know what you mean by turn off scaling of the video i dont see any option for that? i go to hdmi in the setup and it has stuff like hdmi control, through and i have it set for audio just to amp and i have the correct resolution selected for video. i noticed to that if i switch to bluray on my avr then turn on my bd player it works but not if i do it the opposite way just dont know why that would make a difference. and dont know why it would lose it just because i switched for bluray to tv and then back again.
Set the HDMI "resolution" and "aspect" to "through". Audio output to "amp". See if that helps any.
HDMI handshake is from the connected source to the TV, the AVR is not involved unless the TV is off. Power off - on on the TV should re-acquire the handshake to whatever source the AVR is switched to. Power off - on on any of the connected components should do the same thing. Since it's a pain to power off the BD player and re-start a disc, I'd go with the TV. Changing input sources on the AVR should trigger a new handshake, but one of the components is not playing nice. One of those components is not handshaking properly, I doubt the Yamaha is at fault.
Based on your description, either the player or the TV is at fault. If the DVR always works, then the player is the prime suspect. If the DVR has the same issue as the player, then the TV is suspect. (the player has HDCP, the DVR is a bit different)
Hope this helps.
