Originally Posted by
calhokie
pgtr, I'm not sure where you are going with your comments. There is a 6xx line. The new years model comes out and "replaces" the prior year's model. Replacement usually means adding some features (new decoders, iPod hookup, HD Radio, etc.) and a slow decline of the amp as well.
Well no not exactly that simple. There is renumbering... see below
calhokie
There is the 863 > 663 > 563 > 463 > 363.
True. My point is comparing current models to previous models - they should be apples to apples, not apples to orange. Simply ensuring the first digit is the same is not an accurate way to compare to previous models. 'Hundred' series lines do not span the years - only valid for a given year.
calhokie
In the 6xx series, there have been to my knowledge the 620, the 630 (which I just replaced), and the 640. All were at the $500 price point. Then the 650 came out at $550 in 2005. YPAO and lots of amp power. then 657, 659 at $550 a year later, 661, 663 last year, and now 665. The 6xx is the Yamaha mid-range receiver.
Nope not accurate. You seem to follow a 6xx line as in:
620->630->640->650->657->659->661->663
Yamaha's top of the line receiver in their basic AVR line in 2005 was the 757. What some people might refer to as the '7xx' line or family. It had 100W, 400W power supply, 7.1, etc. etc. etc. What appears to be the same exact receiver was apparently renumbered the following year as the 659. Notice the 1st digit change. Again it had 100W, 400W power supply etc etc etc. THe only real difference appears to be the addition of the iPod port.
People seem to make apples to oranges comparisons between say the 657 and 659. A better comparison would be the 757 to the 659.
For example:
750->757->659->861->863->865
Or perhaps:
650->657->559->661->663->665 and so on.
So saying the 665 doesn't compare well to say the 659 because they are both simply '600' series can be somewhat misleading. There really isn't much of a '600' series spanning the years. It's better to look at the AVRs position within an overall lineup for a given year and match to same/similarly positioned receivers from previous years.
