I'm considering getting a receiver and some speakers. There is an itch to buy now but I really don't have to. My current budget is around $1200 for both the receiver and the speakers.
I'm strongly considering the Onkyo TX-SR706. I thought about the 606 but figured the upconverting scaler was better in the 706 than the 606 and the 706 has one more HDMI connector and a better EQ. I thought about the 806 but that will force me to get speakers that are out of my price range...
So based on this information. I've been leading toward the Polk RM95 with a Polk PSW 110 subwoofer. I also considered Polk RM705, which seems to be the RM75 with a tiny subwoofer with it.
I know that this isn't a lot to work with but I really don't want a HTIB, though I did consider the Onkyo 7100 (has the 606 as the receiver).
Now, my plan is to get a "starter" speaker system that's not too big because my plan is to move that speaker system into my bedroom once I replace all the other speakers.
I did see some posts that say I should possibly bypass the Polks and go with eDesign or The Speaker Company but I figured I'd ask anyway. I cannot spend more than $1200 and nothing has been purchased yet.
Any ideas?
Any ideas?
