AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Loosing GUI with 3808CI
post #1 of 4
When I stream music from pc/usb or use internet radio I loose the GUI. The screen goes gray with those sources, I switch to sat or Blu ray and see what's playing but no on screen. I have to put the receiver in stand-by and then power switch it off then back on for the on screen to return. I also have a broken speaker terminal that is hanging on by a tread, but still works. Are these RMA problems?
post #2 of 4
No one has seen this problem with their receiver?
post #3 of 4
Have you RTFM? Is the receiver still under warranty? Did the receiver come with the broken speaker terminal? BTW, if you send it back, have Denon tighten up that loose GUI...sorry, couldn't help myself.
post #4 of 4
I am pretty sure it is still under warranty (came from listen up), it is less than a year old. The speaker terminal was not broke when I bought it and just noticed it when I was hooking up new TV and Blu ray. I will contact them and see what they say.
