Just re-ran Audyssey on my Onkyo TX-SR606 amp since I just got a new BIC VK12 subwoofer. Followed the directions in the "Audyssey Setup Guide" document on the forums to the letter. I keep getting weird results that I was hoping someone could shed some light on.
First off, the speaker levels keep getting set to very low values -- most stuff is -7dB or so. I find I have to turn the volume way up when watching TV or movies to hear anything. My room is only about 14x14x12 and the receiver is at 35ish to make things audible. Here's what it decides on:
L: -7
C: -8
R: -8
SR: -7
SL: -9
LFE: -11
Second, whatever it's doing with the equalizer is causing ridiculous hiss. When I set the EQ to off or flat, it sounds much better. I confirmed that prior to the test running I have all the audio options at off/default (no weird EQ, dialogue boost, cinema mode, night mode, DRC, etc.)
Lastly, it is over-estimating my rear speaker distances by several feet. I have to dial it back down a bit. I think it might have to do with how I've got them turned at about a 30 degree angle?
What am I doing wrong here? I have actually done the "IntelliVolume +8dB" trick and it isn't enough.
My setup:
Onkyo TX-SR606
Polk R50 (f) -- tilted inwards very slightly
Polk CSi (c)
Polk R15 (r) -- tilted at about 30 degrees
BIC VK12 (sub) -- about one foot away from each wall in a corner
L: -7
C: -8
R: -8
SR: -7
SL: -9
LFE: -11
My setup:
Onkyo TX-SR606
Polk CSi (c)
Maybe I will look at running it through VMware.
