AVS › AVS Forum › Other Areas of Interest › Car Audio, Video, and Nav › Cant get flash drives to work on Alpine CDE-102
post #1 of 3
http://www.crutchfield.com/S-MYczVmc...e-CDE-102.html
I know its still pretty new but does anyone have this model yet? I hooked it up today and everything works fine except it wont read either one of my flash drives. It really sucks because thats the main reason I bought it. One is a Patriot 8GB, and the other is a Kingston 8GB. Both are formatted as FAT32. Any suggestions?
post #2 of 3
If your pen drive is bigger than half an inch it will not read it. I had the same problem till I bought a pen drive. It is a 4 gig but it works. Also press and hold "sound setup"-scroll to play mode-press enter and select CDDA/mp3. Factory does not set it for mp3. If any other questions, post reply.
post #3 of 3
Maybe your media needs to be in a special folder.. Try reading the manual to see what the folders name is supposed to be or if it's supposed to be on the root of your flash drive.
  Back to Forum: Car Audio, Video, and Nav
