AVS › AVS Forum › Audio › Speakers › Will My Onkyo 605 Be Enough For the av123 ELT525s?
post #1 of 3
So av123 is having a sale on the 5.0 channel ELT525 package. http://**********/component/page,sho...art/Itemid,37/
My receiver is the Onkyo 605, and given that the bookselfs are only 83dba efficient, the center is 86dba, and the towers are 87dba, I'm wondering if I'm going to be wanting more power. My listening room is about 12x20 but the 'home theater' part is set up in half of that space. I don't listen to it at particularly loud levels, and I'm usually the only person listening.
Anyone see any issues here?
(I've searched here and on the av123 forums with no good answer by the way)
post #2 of 3
Listen to them at levels you want. You'll know that way. I wish I had the power break down but it goes like this:
1 watt = 87db
2 watts = 90db
4 watts = 93 db
8 watts= 96 db
16 watts = 99 db
Basically every time you double the amplifier power you gain 3 db. How far you are from the speakers is also important though. The above measurements are from 1 meter and would be less the further you move from the speakers.
Actually this calculator will let you plug in distance from speakers, efficiency, and power.
Most normal people don't listen at loud levels and a regular AVR is plenty. Adding an Amp can add to dynamics and extension, but is the extra cost worth it to you. For most spending more on the speakers would be much more effective at improving the sound.
post #3 of 3
I just reviewed these below and I used a Denon 2305, plenty of power for moderate volume action flicks and music, plus my room is about 20X30X15 which is pushing it for these speakers...you should be fine, use multiple subs for larger rooms (you can buy an RCA splitter, don't need dual sub outputs)
http://www.hometheaterhifi.com/home-...er-review.html
  Back to Forum: Speakers
