AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Help with Center speaker and receiver
post #1 of 2
HI I just got a jvc receiver from a friend and I hooked up my pioneer speakers to it. The center speaker won't work. I put the center speaker in another speaker spot and it works, so its not the speaker or wire. I have turned the speaker on in settings and changed it from small to large. It makes a hum when volume is really loud and no noise when I test the speakers. I have the receiver hooked up to my ps3 through optical and I tried the center speaker during movies also, but it just has a hum when you put your ear to it and doesn't test out. Help would be great!! Thanks!
post #2 of 2
Sounds like a blown center channel amplifier if you tried out all your other options. It's possible your friend never noticed it.
