This thread was started in an attempt to do the following;
When posting, please provide the following three pieces of information in your post;
Trip maintains the RabbitEars website listing confirmed TVGOS host channels here and an Unofficial Guide to TVGOS written by Lance G. here
If you don't know which version of TVGOS you have, here is some info that may help you to find it;
Here's what my v8 device shows for versions. IGNORE THE 2 DIGIT NUMBER IN THE MIDDLE, i.e. 08.XX.44.
Upper one is before my device got a firmware update from the mfg to update the base version, lower is current after the firmware update from mfg to update the base version. Version before first / is base version, after first / is patch version.
In both cases I have main patch 08.06.44, but the base version before is lower than the base version after, if you read it correctly and IGNORE the middle two numbers (XX) between the .'s on the base version! i.e. 08.ignore_this_part.44 is lower than 08.ignore_this_part.71. Think of it as 08.44 is old and 08.71 is newer. I know, it's counterintuitive to the way most developers version their software.
If enough posters reply, you won't have to spend days searching the forum or reading threads to find the info you're looking for.
With so many devices using TVGOS, you will likely find relevant information in threads discussing other devices.
It could help answer questions you have, for example;
NOTES:
POST#2 in the thread will track Version Updates to POST#1
- List CE devices with Gemstar/Macrovision/ROVI TVGOS
- Provide links to other threads on this Forum discussing that device with TVGOS
- List if the CE device is compatible with DTV (Digital) TVGOS transmissions - v8 (w/base 08.##.65 and up) and newer are
- Manufacturer and Model of device you use it on (add revision/version/build, etc. if you know it matters).
- Links to threads on this forum discussing your device and TVGOS, or "don't know".
- TVGOS Version on your device, i.e. 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 or "don't know".
Version 0 of the Guide does NOT have any diagnostics.
You can recognize a V0 device by its menu.
SURF NEXT SCAN SORT
Version 1 of the Guide does have diagnostics.
You can recognize a V1 device by its menu.
FEATURES NEXT SCAN SORT
Version 2 and higher of the Guide do have diagnostics.
You can recognize a V2 device by its menu.
GRID SORT SCHEDULE MESSAGES
For V1 Diagnostics, select FEATURES, then DIAGNOSTICS, enter the diagnostic code of 753 159 852.
For V2 - V7 Diagnostics, go to MESSAGES, down arrow to highlight the TVG ID number, enter the diagnostic code of 753 159 852 (for some RCA devices, precede this code with a 2).
For V8 Diagnostics, Open TV Guide On Screen, highlight SETUP on the service bar, down arrow once, enter the diagnostic code of 753 159 852.
For V9 Diagnostics - According to real world users: Open TV Guide On Screen, highlight SETUP on the service bar, down arrow once, enter the diagnostic code of 753 159 852. (But, according to Macrovision: Open TV Guide On Screen, highlight SETUP on the service bar, press ENTER, enter the diagnostic code of 753 159 852.) Whatever works for you.
NOTE: For V9 Guide Daily, Bring up TV Guide, press 'Menu' button, highlight first choice, enter the diagnostic code of 753 159 852.
SURF NEXT SCAN SORT
08.02.44/08.06.44/00.00.00/00040005/64/0000
08.01.71/08.06.44/00.00.00/00040005/64/0000
Code:
Understanding TVGOS firmware revisions
Devices are built with a base firmware revision which cannot be changed, except by a firmware update from your device's manuafacturer.
For example:
9.1.27/9.6.01
| | 27 designates the minor release level.
| 1 designates that this is a general release for all partners and devices.
| 2 would designate a platform or model specific release, ex. All brand X DVRs.
9 is the major release level and designates what UI and level of functionality are included.
Patch levels
A patch would be displayed between the first and second slash. For example:
9.1.27/9.6.01/
6 designates a main patch. These usually include all patches released up to this time.
5 would designate a setup patch. These are short patches which fix one or two specific bugs.
Patches are downloaded over VBI just like lineup or listings.
Main patches download three times a day during listing downloads.
Setup patches are downloaded many times a day.
Setup patches are critical, and they are shorter than main patches so they can
be downloaded to units that may have trouble downloading the larger main patches.
- Is anyone else using the same device and experiencing the same issues with TVGOS?
- Is my device's TVGOS compatible with digital TVGOS transmissions?
- Is there an update from the manufacturer of my device to allow it to be compatible with digital TVGOS transmissions?
- What CECB's convert digital TVGOS to Analog?
- What non-CE CB's convert digital TVGOS to Analog?
| Manufacturer | Model | TVGOS_Version (*0) | Digital_compatible | Forum_Links |
| ALL | ALL | ALL | v08.xx.65 and up | The Magic 8 Ball Speaks Out On TVGOS & DTV! |
| ALL | ALL | ALL | v08.xx.65 and up | TV Guide OnScreen issues for all devices: TV's, STB's, DVD Recorders & DVR's |
| ALL | ALL | ALL | v08.xx.65 and up | TV Guide On Screen - post your info here! |
| DISH/Echostar | DTVPal (*1) | 9 | YES | Dish DTVPal / Echostar TR40 digital to analog converter |
| DISH/Echostar | DTVPal+ (*1) | 9 | YES | Dish DTVPal / Echostar TR40 digital to analog converter |
| DISH/Echostar | TR40 (*1) | 9 | YES | Dish DTVPal / Echostar TR40 digital to analog converter |
| DISH/Echostar | DTVPal DVR | 9 | YES | The Official AVS Dish DTVPal DVR Topic! |
| LG | 42LB1DR | 8 | v08.xx.65 and up | ? |
| LG | 50PX4DR | 8 | v08.xx.65 and up | ? |
| LG | 60PX4DR | 8 | v08.xx.65 and up | ? |
| LG | LST-3410A | 7 | w/DTVPal | LG LST-3410A Review and Discussion |
| Mitsubishi | LT-46231 | 8 | v08.xx.65 and up | Official Mitsubishi LT-46131 & LT-46231 (46" 1080p LCD) Owner / Discussion Thread |
| Mitsubishi | LT-46244 | 9 (Guide Daily) | Yes | ? |
| Mitsubishi | v33/v34 chassis | 8 | v08.xx.65 and up (Netcommand v8.03) | 2007 Mitsubishi WD-XX73X and XX831 Owner's Thread |
| Panasonic | DMR-E95 | 7 | w/DTVPal | ? |
| Panasonic | DMR-EH50 | 7 | w/DTVPal | ? |
| Panasonic | DMR-EH55 | 9 | DTVPal?/NO ATSC Tuner | Panasonic DMR-EH55 User Review and Questions and Panasonic DMR-EH75V, TVGOS and Dish DTVPal+ |
| Panasonic | DMR-EH75V | 9 | DTVPal?/NO ATSC Tuner | Panasonic DMR-EH55 User Review and Questions and Panasonic DMR-EH75V, TVGOS and Dish DTVPal+ |
| Panasonic | DMR-E85H | 7 | w/DTVPal | ? |
| Panasonic | DVDR's | See Thread-> | See Thread-> | Panasonic DVD recorder US models, years produced and features |
| Pioneer | DVR-633 | 8 | v08.xx.65 and up | Pioneer Disappearing EPG |
| Samsung | HLR-5678 | 8 | v08.xx.65 and up | ? |
| Sharp | LC32D7U | 8 | v08.xx.65 and up | ? |
| Sharp | LC37D5U | 8 | v08.xx.65 and up | The Official Sharp 37-inch LCD Thread |
| Sony | DHG-HDD250 | 8 | v08.xx.65 and up | Sony DHG-HDD250/500: Official Thread |
| Sony | DHG-HDD500 | 8 | v08.xx.65 and up | Sony DHG-HDD250/500: Official Thread |
| Sony | HX900 | 7 | w/DTVPal | Sony RDR-HX900: Will it work after Feb. 17 changeover to digital broadcast? |
| Sony | KDL-40W4100 | 9 | YES | ? |
| Sony | KDL-40XBR6 | 9 | YES | ? |
| Sony | KDL-40Z4100 | 9 | YES | ? |
| Sony | KDL-42V4100 | 9 | YES | ? |
| Sony | KDL-46V4100 | 9 | YES | ? |
| Sony | KDL-46W4100 | 9 | YES | ? |
| Sony | KDL-46W4150 | 9 | YES | ? |
| Sony | KDL-46XBR6 | 9 | YES | ? |
| Sony | KDL-46XBR8 | 9 | YES | ? |
| Sony | KDL-46Z4100 | 9 | YES | ? |
| Sony | KDL-52V4100 | 9 | YES | ? |
| Sony | KDL-52W4100 | 9 | YES | ? |
| Sony | KDL-52XBR6 | 9 | YES | ? |
| Sony | KDL-55XBR8 | 9 | YES | ? |
| Sony | KDL-70XBR7 | 9 | YES | ? |
| Toshiba | 50HP95 | 8 | v08.xx.65 and up | Official Toshiba 42HP95, 42HPX95, 50HP95 & 50HPX95 Thread |
| Toshiba | 50HPX95 | 8 | v08.xx.65 and up | Official Toshiba 42HP95, 42HPX95, 50HP95 & 50HPX95 Thread |
| Toshiba | 62HM94 | 8 | v08.xx.65 and up | ? |
NOTES:
- (*0) - This is the base build TVGOS version in your device, so far only updateable by the device manufacturer vs. a TVGOS patch version that is transmitted with TVGOS data.
- (*1) - The DISH/Echostar DTVPal, DTVPal+ and TR40 are not a TVGOS device in the sense they don't utilize TVGOS data to display TVGOS on an attached TV or Monitor (they use PSIP from each digital station for that). They will, however convert digital TVGOS data received OTA to analog TVGOS data (refer to your PAL/TR40 User Guide) needed by many older TVGOS devices (versions below 08.xx.65).
