AVS › AVS Forum › HDTV › HDTV Technical › TVGOS ( TV Guide On Screen ) Devices
TVGOS ( TV Guide On Screen ) Devices - Page 6
post #151 of 1484
Originally Posted by bwall23 View Post
12 days and nothing yet. I have over 1,000 zipcode packets, yet no timezone packets.
I did learn something today. I went to check on the TVGOS as I do everyday to see if it would finally ask me to select a lineup. When I changed the input on my Mits TV from the DVR to the antenna, it came up on analog channel 42, which is a Spanish station. It also shows it as the VBI channel (0:0-42), which is PROOF it cheated on me. I always tune to CBS digital 13.1 before changing inputs or turning it off. I have all the analog stations turned off on my Mits channel editor, so surfing by doing a channel up/down only goes through the digital channels and you cannot tune to any other channel unless you key in the channel number on the remote. Looks like TVGOS is desperate and scanning ALL channels.
With the Sony 250/500, the "vbi channel" is simply the channel the unit is tuned to, not necessarily one from which it has gotten anything...does the Mits use a different nomenclature?
post #152 of 1484
In my case, the VBI channel is the last channel the TVGOS tuned to (while harvesting/scanning), not what I tune it to before going into the TVGOS diag screen. As I mentioned, I always tune the Antenna input to CBS digital 13.1 before I switch inputs (to the TiVoHD, Blu-Ray, Firewire DVR, etc.) or turn the set off. My set powers on to the input and channel it was last set to when turned off. AND, I do not have any analog channels enabled in the channel editor for my set (I'm talking about my Mits TV device, not the TVGOS channel editor, since I don't even have a TVGOS lineup).
P.S. The analog channel 42 (KTNC-TuVisión) it was tuned to is 60 mi. away LOS, very snowy and does not even carry Closed-Captioned data
P.P.S. Just to make sure, I just turned the set on again to check and it came up on another Spanish analog channel 19 (KUVS-Univision), 60 mi. away LOS and off direction from my UHF antenna aiming. It's definitely cheating on me. It appears to prefer Spanish, hmmm?!?, now looking for the language preference in TVGOS setup
post #153 of 1484
bwall23...I think we're probably in agreement - in that your TV is TRYING to cheat on you, i.e., is scanning (as it should if it is not getting data from where it used to)...but what I meant (just in case you weren't aware of it) is that the vbi channel does not necessarily have any TVGOS data...it is just what your unit was last tuned to (whether by your action, or from scanning, I guess)...
(Many people don't know how to distinguish the vbi channel from the host channel)
post #154 of 1484
myoda; Mine is a 57732.
I have been hounding Mits in California (forget about overseas) for a solution since their upgraded firmware was suppose to work, but doesn't. I got another response via e-mail and a phone call that they are still working on it.
post #155 of 1484
Surprise , Surprise ............. Today when I was checking out the new firmware on one of my HDD500's I decided to press the "Guide" button on my Mits 46246 remote. Lo and Behold ....... The grid was filled in with listings for the first time in a month!
post #156 of 1484
Yes, the VBI Channel is definitely the last channel that TVGOS tuned to before I entered the diag screens. Today when checking mine, my set turned on to analog channel 19 (not in my list of channels I enabled) on the ANT1 input (OTA UHF antenna), the VBI Channel was 1:0-37 which is analog 37 on ANT2 input. I have nothing connected to the ANT2 input and there is no channel 37 (analog or digital, virtual or physical) anywhere near me.
post #157 of 1484
My Mits TVGOS (v08.01.71) hasn't picked up new software or a channel lineup since I reset it 6 days ago. Since I finally got a dual-stream Cable Card in my TiVo HD, I gave the single stream card that was in my Mits back to Comcast.
As far as TVGOS on my Mits goes, I'm strictly digital OTA now. Disconnected Comcast cable from the Mits and plugged my OTA UHF antenna in. Setup the Mits for OTA on that input, scanned channels and turned off all analog channels in the Mits channel editor so they cannot be tuned. I then System Reset the TVGOS and set it up from scratch.
I'm not going to play with TVGOS anymore (tune to Host & leave on, do G* Test, etc.). I'll check it once a day to see if it ever gets a lineup.
OK, It's been just a wee bit too long since you'all Sony DHG users reported success immediately after applying your firmware updates to bring you up to the same TVGOS software version I've been (NOT) enjoying. I'm just going to assume that either my broadcaster or cableco isn't passing the TVGOS info, that you'all seem to be enjoying... I was there, many months ago, before Sony released the same version that I've been running on my Mits.
post #158 of 1484
SO, I'm happy I made the right choice
post #159 of 1484
WS65711; And the host channel is............?
post #160 of 1484
It is displayed on the Mits diagnostics screen as 1:12-0.
By the established convention, this should indicate Cable, Digital Channel 12 (PBS). My local PBS digital is on OTA Chnl 11, QAM 83.1, virtual channel 12.1. The thing that puzzles me is that my HDD500's don't give me any indication that any of these have TVGOS data, although analog PBS OTA channel 12 does. Go figure?
post #161 of 1484
I just noticed my TVGOS is not configured correctly, so I'm trying to reset it somehow to start over at square 1.
Look at your TVGOS diag screens "Setup-Input Configuration->Input #'s and config" and "System-System Info->Video Source" and see if they reflect reality.
I had originally setup mine with ANT1 as Cable w/CableCard and ANT2 as OTA Antenna, but changed the physical setup after I returned my cablecard to Comcast and moved the OTA antenna to the ANT1 input.
When I looked at those TVGOS diag screens tonight, I noticed it still showed TVGOS configured for CableReady on ANT1 and OTA on ANT2.
Used to be with my device (Mits TV) I could perform the TVGOS System Reset code and it would start setup from scratch, but with the new Mits (v8.03) and TVGOS (v08.01.71) software, it doesn't. I'm trying to figure out what & how to reset it to start the TVGOS setup from scratch. There may be hope yet.
post #162 of 1484
This is how mine is set up, and has been from the very start. Ant1/MAIN is cable and Ant2/AUX is antenna. I was going to hook them up just the opposite, until I saw in the manual that CableCard could only be used with Ant1/MAIN. I don't have CableCard, but I figured that down the road I might . . .
I will double check the screens you mentioned, but I probably won't get to do that until tomorrow (at least). The HDD500's are running me ragged right now . . .
post #163 of 1484
Which would tell me it's analog channel 12.
Those two 'reset' codes, warm and cold, I have never saw a difference between either. Both operate identically.
But, the "System reset" is another deal. Other than it 'crashing' (pardon the expression) the set with a full power off (no cool down), this is the only way that seems to wipe out everything including those two firmware/software update stages seen in the first diag. screen (other than using the TV service menu to reset the set which I perfer not to do).
Neither my Mits or that Sony DRV have updated since I lost my analog host. The best I have is correct time and the 1st level firmware/software upgrade shown in the diag. screen on the mits and the 2nd level on the Sony.
Neither show a 'host' channel.
On the Sony, the VBI test now fails where it passed before on the digital host (OTA). I am getting no VBI packets anymore.
post #164 of 1484
"It is displayed on the Mits diagnostics screen as 1:12-0. "
I believe you're quoting me?
1:0-12 = analog, based on all the info I've seen.
1:12-0 = digital, based on all the info I've seen.
My Sony's are using 0:0-12, which is OTA analog, based on all the info I've seen.
post #165 of 1484
I've gotten reports of a digital station showing on TVGOS as 1:11-0 (as in the analog on 42 is long gone) rather than 11-1 or something like that.
- Trip
post #166 of 1484
I thought about it after I posted and it dawned on me I was reversing thelocation of the zero.
I usually type it "43.0" to mean anlaog as opposed to 43.1.
My bad.
post #167 of 1484
Anyway, I just finished a lengthly conversation with a local station engineer regarding this mess and he/we have come to some conclusions.
1. All of these guys that have claimed in the past 6 or 9 months to have a working TVGOS guide from their digital Host in their Sony DVR's were still receiving data from their analog host.
2. There appears to be a serious flaw (or at least a major 'quirk') in this "G* test" where it will give a VBI packet count on the Host's digital channel when in reality the count is from the analog channel due to the VCT channel numbers being the same: 0-17 vs 17.2 in my case. IOW's even though you tune to the digital Host, the system (TVGOS) will see these (incorrectly named) "VBI packets" from the analog Host instead.
3. I'm now doubtful that Sony firmware upgrade works. The Mits upgrade surely hasen't.
Why do I say this? I ran several G* tests a month ago on my analog host (which is now dark) and the digital host. I also ran tests on my distant analog host from Toronto. All tests returned a VBI count. The difference being the amount of packets receive within a specific time period (60 seconds). The analog counts were 3x what the digital counts were.
I now re-ran the test and I receive absolutely NO packet count from my digital Host where I did before using the Sony. There is no known problem as far as the station enginner knows, it is being run my Macrovision and some data service (I forgot the name). If there is a problem, they call him.
Take a look at these screen shots;
First is the digital Host last month, 60 packets in 60 seconds,
Second is the analog Host, 200+ packets in the same time period,
Third is my other analog Host, 185 packest in 60 seconds.
Now, take another look. All three show ATSC data and a pass grade. The 2nd and 3rd attachments are analog channels. How do you get a ATSC pass on a analog channel??
Also note, the 2nd image shows an actual channel number under the 'Statistics' line, not that "1023-65533" (whatever that is suppose to mean).
post #168 of 1484
I choose to believe what I have done myself, and can see with my own eyeballs.
First off, the G*test on the Sony's is completely different now after the firmare upgrade. It flat out does not have the same effect on the machine that it did with the old firmware. Why? ... I dunno.
But in the past (with the old firmware) I could start with a channel lineup and grid, but NO LISTINGS. Then I could tune to my OTA CBS DIGITAL station, execute the G*test, LEAVE THE DVR TURNED ON, and come back a few hours later, and have EIGHT DAYS OF COMPLETE LISTINGS. This does not happen with the analog TVGOS broadcast.
The Sony only has ONE tuner. If you tune it to a digital station and leave it on it cannot go grab a signal from anywhere else.
post #169 of 1484
videobruce,
Along with the info I mentioned over on spiffspace, here are some pictures for you to look at. You can compare them to your screens.
Picture 1 & 2 are the 2 Section Slicing screens, notice all zeros.
Picture 3 is the new ATSC Slicing screen.
If I had an analog host, the Section slicing screens would not be filled with zeros.
Mark
post #170 of 1484
0:#-# is ANT1, 1:#-# is ANT2, see my previous post about looking at "System-System Info->Video Source"
post #171 of 1484
Exactly, your host is on ANT2, virtual digital channel 12. Since the data is carried in a separate PID from the brodcasts, it shows the 12-0 instead of 12-1 or 12-2 or 12-3, etc. It could also show up as 0-11 meaning physical (as opposed to virtual) channel 11 and that could be either analog or digital. You need to know what the physical and virtual channel numbers are. When you introduce cable and then cablecards, it gets even more wicked.
post #172 of 1484
I could not get TVGOS to recognize my set's new configuration and did not want to reset my TV to factory defaults. I tried TVGOS Warm, Cold and System Resets (ouch, no cooldown). Turned off TVGOS from the TV set setup and back on. TV System Reset. Tried TVGOS zipcode 00000 and 99999. Stuck tongue out left side of mouth while standing on right foot and holding left ear, etc.
I gave up and setup my config as TVGOS thinks it is.
  • ANT1 - CableReady, only I have nothing connected to ANT1 now and did a channel scan for both cable and OTA from my Mits set and disabled it in NetCommand so I cannot even select ANT1 as an input
  • ANT2 - My rooftop OTA UHF antenna and did an OTA channel scan and disabled all analog channels in the Mits channel editor
  • Disabled TVGOS, shut down completely and unplugged overnight.
  • Enabled TVGOS (from the TV setup) on ANT2 as OTA with my correct zipcode.
TVGOS still thinks I have CableReady (cable w/CC) on ANT1 and OTA on ANT2. I will let it stew over that(/sleep on it) tonight and see if it gets any smarter tomorrow.
Pardon the poor images, but in a hurry to watch TiVo recordings...
System-System-Info
Reception-VBI Stats
ATSC-ATSC Slicer
post #173 of 1484
mabuttra; The 3rd pic, on the Sony those last lines PID 1&2 has a hex number 0x111 and 0x112 (I believe), on the Mits it was like yours, "NONE" for both.
Lines 2-5 all had counts with 4 & 5 updating. Also that "Dummy" line was updating. All others remain fixed at whatever number was shown.
bwall23; Using either the warm or cold resets does nothing. Only that System reset (crash) seems to fully dump the system data.
I just got a call from Mits relaying messages from Macdrovsion (they still call Gemstar) telling me about the clock settings being different based on the screen shots I e-mailed them a number of weeks ago. They want me to compare the clocks time with another "3rd party" device's clock. They also suggest bypassing any power strip filter and pluging the set in a wall outley directly.
Is Macrovision on some other planet or what? From the message, someone doesn't know what UTC or GMT is all about and thinks the clock setting comes over power lines.
post #174 of 1484
Just tell them the TRUTH. You're in an alternate parallel universe that uses Macrovision Savings Time
post #175 of 1484
Power strips and UPS's may alter/affect the electrical power cycles and thus lead to the internal clock not keeping accurate time. I can recall an old VCR's clock not keeping the proper time when connected to a UPS. It is best to humor them simply to have one less variable to deal with until everything is figured out.
post #176 of 1484
videobruce, good eye , I wondered if anyone would notice that my 2 PIDs say NONE. There is a reason for that. My DVR has an issue that nobody else seems to have. My guide data fills in fine, as long as I don't have a host channel set. Once the host channel sets, the nightly guide updates are 'No Listing'. The work around for this is to change my zip code at least once a week. This clears out my host channel, for a day or two, and allows my guide data to fill in completely, until my host channel sets again. Apparently, without a host channel, those pids switch from 0x numbers back to NONE. I just changed my zip code yesterday, so the data on that screen hasn't actually updated in 24 hours. I just wanted to show that I have had HostChan packets counting up, just not today.
Mark
post #177 of 1484
Around February there were scattered reports from people in several areas that their DTVPal was finding the "special" TVGOS data from a digital station that the Pal was able to convert to an analog form for "legacy" devices requiring the data in that form.
Are any of those people (or others) currently finding that data and having their Pals successfully convert it???
post #178 of 1484
Interesting, I never made that connection. Since I never used a UPS, I never thought about that affecting power frequency (which, I suppose it could). But, a power filter strip shouldn't have any affect.
The above would only apply to a clock that used the power line frequency to keep time. If it was set to a TV signal, all of the above wouldn't matter, correct?
mabuttra; I try to look for entries that are different, or something that stands out. "NONE" and "0x111" qualify. I do remember reading that TVG2 was for future use (something like that).
Gee, I thought I had a problem.
TiVo HD is starting to look better and better.
post #179 of 1484
Mits TV situation:
I did another 'System Reset' last night. I checked the diag. screens and everything was set to '0' or just blank including the clock set channel and the two software/firmware upgrades.
This morning the clock set channel and VBI channel were the same as they were last night. The firmware was at the 2nd and/or final upgrade stage: 06.044. It was just as things were before the upgrade as I never did anything. before or after, the clock was not set, even though it was showing in UTC time.
I figured the system was corrupted, so I did a full 'Initialize" which resets everything in the TV including channel memory and all user settings (fun wow).
Sony DVR situation:
On hold untill I talk with Sony. (That ought to be interesting)
I'm really questioning if our 'Host' is actually passing the data correctly. Their chief engineer even admitted they have no way of knowing except when some company called 'National Data Services' (??) which whom they contract through, not Macrovision contacts them. I even asked about resetting the data inserter (if that is what it is called) and all he said was it could be unplugged and plugged in again.
I can't beleive there isn't any provision to monitor the output of that device if indeed correct data was actually leaving that device and sent into the xmitter chain.
post #180 of 1484
Mark
I have two NONEs, too...but none of your reasons...
  Back to Forum: HDTV Technical
