Originally Posted by Jed1
mabutta,
The best way I can answer your question is "There are two ways a cable company can "Transport" the analog wave form to its customers." Not "convert."
1. The TVGOS analog wave form is sent from the source (Rovicorp) through an analog phone line to a analog inserter which used to be in the PBS stations, and now is placed in the cable head end. The analog wave form is then inserted into the VBI of any analog channel of the cable companies choosing and then sent to the customer.
2. The TVGOS analog wave form is duplicated, then digitized at the source (Rovicorp). Then it is sent along with TVG1 and TVG2 on a mpeg transport stream using a DSL, to the inserter were the three streams are then inserted into the mpeg stream of the host stations high definition digital feed. Then it arrives at the cable head end were the hd feed, along with the digitized analog wave form (legacy stream), is downconverted, using SCTE 127 compliant equipment, to a standard defintion analog channel which includes the restored TVGOS analog wave form. It is then sent along to the customer.
I was thinking as I was typing this that all 10 versions of TVGOS can use the original analog data stream to populate the guides. Only 2, version 9 and 10, can use the digital data stream with out the need for patches to populate the guide. And one, version 10, can use a broadband ethernet connection to populate the guide.
If it wasn't for people who use OTA to get guide data, Rovicorp can just put analog inserters in all the cable headends and completely eliminate the need to have digital inserters at host stations. It the use of the public airwaves that require the TVGOS data to be digitized for transport from the source, Rovicorp, to the end user. If TVGOS would only work with cable then there will be no need to convert the original TVGOS analog wave form to digital because cable doesn't use the public air waves. Cable is a privately owned closed loop system.
In my opinion, it isn't a problem with the TVGOS data, it is the transport of TVGOS data to the end user that is causing the most problems because of the use of the public air waves.
mabutta,
WOW - are you backwards! In fact, based on TVGOS documents, I think all the stuff coming from TVGOS now is digital, with the v8 and up being broadcast (or sent via cable) as is and the legacy stream going separately, either over the air or to cable companies for conversion and insertion in vbi by the cable company or by the DTVPal.
