AVS › AVS Forum › HDTV › HDTV Technical › TVGOS ( TV Guide On Screen ) Devices
TVGOS ( TV Guide On Screen ) Devices - Page 32
post #931 of 1480
Originally Posted by Rammitinski View Post
The Panasonic EH55 and EH75V with v9 are compatible with Direct and Dish.
He must be using one of those two models with DirecTV, if it's actually getting the appropriate guide data (it doesn't get guide data with Dish - you program the recordings through the Dish tuner's guide. I have one of each model, and have been using them with Dish that way for a few years).
I know it sounds improbable for the unit to be getting guide data through the Direct tuner, but some people here have sworn it works, even without adding an antenna to get it OTA (you can get the guide data for it OTA, though - I've actually set up for and gotten it, just for the heck of it).
According to the setup procedure, you don't need an antenna to get it. Supposedly gets it right from the Direct tuner. I have no clue how it actually works. Maybe Jed1 knows (all I do know is that I was able to get the call letters for some of the local stations when I had my v7 recorders hooked up to my Dish tuner, without an antenna hooked up. Figure that one out. It wasn't even v9, nor was it with Direct. Yeah, I know you're probably thinking I must've been high, but I swear to you, it actually happened).
The way those two models work with Dish, though, is a lot easier to fathom. The tuner sends out some kind of cueing signal, which starts and stops the recorder. It basically works just like if you were using a DTV Pal DVR. It goes into a "pause" mode two minutes before it starts, and you can pad the times, etc.
Oh, I believe you. I just seems so improbable. Guess I'm not too old to learn something new.
post #932 of 1480
Originally Posted by iver81 View Post
hi, I've been reading this forum about TVGOS and tried several remedies but... nothing seemed to work
Sony KDL46Z4100 model, TVGOS stopped working several months ago. The software/firmware was updated. In Los Angeles/Long Beach, 90815. OTA antenna on the roof. No cable, no sat but we have hooked up the WII for netflix ( I had this problem before netflix).
I've shut the TV off overnight (it did ask for time/set up but the TVGOS was still what I had before. I allowed auto channel select hoping to it clear up). I get channel call letters, even program name on the header when changing channels but the guide has no info. Is it just me? Have I not done something? thanks
Similar thing with my Sony W4100 LCD. When I push the GUIDE button I get nothing, like I never pushed it, if I push GUIDE again I lose video but audio stays. After that nothing happens when I push the number keys, only a CH up or CH down moves me to another channel and restores video. Even though I can scroll through channels I don't get a channel banner and pushing DISPLAY does nothing
I tried a fresh channel scan and all went fine, I was even able to hide the channels I didn't want but I have absolutely no TVGOS, only program title(I assume provided by PSIP) but no description.
I haven't tried a INITIAL SETUP because I don't want to go though the hassle of reprogramming all my preferences. Their must be 100 different settings and I have almost all customized and unless I knew it would fix things I'm not willing to try.
Anyone else experience a similar thing with TVGOS and if so were you able to correct it?
EDIT:
Well after I typed up above I thought I should try a power cycle of TV. I unplugged it for 5 minutes and after plugging it back in I pushed GUIDE. At first nothing happened and I figured the PS didn't help. Finally after about 10 seconds the TVGOS grid came up but everything was NO LISTINGS. Hopefully overnight it will populate, weird
post #933 of 1480
Originally Posted by JoeKustra View Post
Ever wonder how an OTA data stream can cause problems with a satellite signal? Ever wonder if Dish causes problems with DirectTV? Sounds like male bovine excrement to me. And why would a broadcast station even care? Did Dish/Direct threaten to sue or call the FCC?
Are you saying only the time is wrong, and all the channels and listings are correct? That's a real trick.
I'm in Columbus too like the guy you responded to. I called Channel 10 weeks ago and all I was told was that it would be fixed real soon. I should have had them define "real soon" for me.
I'm using a DTV PAL DVR. If the true tvgos signal is being received, you get a TV Guide logo in the corner. I have not seen that in weeks.
I noticed the problem on a Monday. None of Friday's listings or beyond were available. I still had my TV Guide logo. As the week progressed, Friday and beyond were still unavailable but I still had my TV Guide logo. When Friday came, no TV Guide logo and I was getting limited listings.
For me, the channels all show up in the grid and the time is correct. I normally have the correct listings for about the next 5 hours but after that, they are unavailable. OTOH, Channel 10's listings are good for about the next 15 hours. For an added bonus today, none of the listings worked for the ABC affiliate.
Since things went south, 3 new channels have appeared in my listings. The channels are too far away to receive but I get show listings for 2 of the channels.
I loved my DTV PAL until I lost my 7-day show listings. Now I have to set up recordings based on what I read in the paper, which does not include any of the more obscure channels. Plus I get a lot of recordings that do not know what they are, which is annoying when you are trying to figure out what to watch on your DVR.
post #934 of 1480
First, remember I'm cable only and using a Sony DHG (V8).
Things were 100% stable for over six months. On or around 4 July, my TVGOS started to lose stabilty. I have only had one day 8 of "no title" and several days of no ads. Titles all filled in after a day or two. Perhaps it's vacation time at Rovicorp? There have been no changes to my cable feed since March.
I get a grid with 600+ channels. I have 200+ active (enabled on scan) channels. I only watch (enable) 20 channels. I disable the rest. All my recording are manual, so I use MSWord to track the schedule from both tvguide.com and TitanTV.com.
ABC has always been a funny channel. I wonder if they have money issues with Rovicorp.
post #935 of 1480
It is interesting following the posts of those that have "stuck with it" for TVGOS. I was a fan-boy of it when I purchased my first HDTV, a Mits RPTV in 2007 that relied on it. Now, I just find it interesting reading the trials and tribulations of those that have stuck with it and are hoping it continues. Just want to let you know that although I no longer use TVGOS, I will try to keep this thread updated as long as you all post to it. As you all know, I've replaced my TVGOS with the competition, TiVo.
post #936 of 1480
One of my two decks completely lost all listings while the other has listings from my distant host since the local host encoder is down as reported by another member. Both have the same feeds (OTA and CATV).
Normally analog CATV channel 3 is where the decks prefer to get data from even though it is available digitally OTA & CATV.
Ideas?
post #937 of 1480
It's nice of you to stick around. People with the Sony DHG units depend on TVGOS to get the clock set since it has no manual clock set. I have a newer Sony EX700 that can use the guide to get 24 hours of listings via the internet (V10). This forum is a good place to go when hardware or version-specific diagnostics are not important.
"Hoping it continues" is a big understatement.
post #938 of 1480
Wouldn't that be a big overstatement?
post #939 of 1480
I light candles.
post #940 of 1480
I light candles.
I recently up-graded to a higher tier of programs through Comcast Cable. Sixteen of the new channels I was to receive did not appear on the TVGOS channel editor. I E'd Comcast and Rovi with a list of the missing. Rovi replied promptly, stating that all would appear in the editor within 3 days. To my suprize that happened. Most of the added channels even came with icons, even some new start-ups, except for Oprah. Given the rapid response and the new icons it seams that support is still strong for TV Guide. To further my point, I was told by Rovi that new icons were not programmable a few months back and that only CAP icon logos would be available. Not true, because many of my already existing all CAP logo icons have been replaced by real channel logos in the channel editor over those months. It doesn't feel like TVGOS will be discontinued soon given the excellent response I got from Rovi. Hope this helps you light more candles.
Has anyone noticed prices falling on TVGOS devices on eBay? I haven't.
CableCard on 7 devices in Northern CA all working great, Gregg
post #941 of 1480
It's a small world. My only experience with Comcast was in San Mateo and it was very positive. You sound like Rovicorp actually has people working there. Now, please don't mention my name since my gride still shows that were dropped over a year ago and with no cable card, I am manual only. But I like the guide. My cable company is too small I guess. Thanks for some positive feedback.
I still see DHG-HDD250's going for $250 - $350 and 500's for $400+. They are V8 only.
post #942 of 1480
Any problems with cable TVGOS data?
post #943 of 1480
This has me stumped.
We recently got HD boxes from Rogers and it was set up from the technician this way.
(box) Cable from wall into cable in.
(box) Cable out into RF IN onto the Pan EH50
(EH50) Out to VCR
VCR out to TV
I unhooked all that put in a 2 out splitter from the wall and sending one output cable straight into the EH50's RF IN and sending the cable out into the VCR instead of the PanEH50. With the cable box - no option set on the TVGOS.
The Cable box and the Panasonic now don't pass through each other.
Yet no listings. It's got a host, host ID, VBI, but listings are "no listings" when it downloads the data now.
So I unhooked the cable box from the set up and just took the cable box's cable in and cable out and connected them together to remove the cable box from the equation. Waited over night and I got listings for day 1, 2 and 8.
Put back in the cable and cable out and now no listings again.
So I don't know, they're not connected to each other but something is still making the TVGOS not get data. The signal in the splitter is the only place the wires meet? Any ideas what I'm doing wrong?
post #944 of 1480
Jacksonville, FL-
TVGOS is not working for me on either of my Sony DHG-HDD500 units since about a week ago. I now have no listings at all on both units. I have contacted my local cable provider, Comcast, and they have no idea what I am talking about when I try to explain TVGOS. I have also left an email with my local PBS channel, which I am told carries the TVGOS data stream.
Anyone else in J-ville with TVGOS issues?
post #945 of 1480
(EH50) Out to VCR
VCR out to TV
Having an HD box would imply you send the box output to your TV via HDMI. That would be normal.
I would split the wall into two outputs. Feed one to the cable box and let it use HDMI to feed your TV. The other leg feeds your EH50 rf in and the EH50 rf out feeds your VCR. The VCR rf out feeds the TV if you like that. The EH50 should feed the TV via composite/component/HDMI (sorry, I have an EZ28). The VCR should feed the TV via composite/component. This assumes your TV has enough inputs.
Draw a picture first. I find it helps. My cable box (Pace) has rf out but it's slaved to the channel I'm tuned to and goes away if the box is turned off. It's not a pass-through. I wish it was.
post #946 of 1480
acribb; Most stations don't reply to e-mails. You are better off calling their Engineering Dept. Don't bother talking to any one else since they won't have a clue what your talking about (what else is new?).
Can you receive the host OTA signal? If not, since the recorder has the capability, I would suggest doing so, if nothing else, for backup when your CATV service goes down.
There is the dedicated Sony DVR thread where 90% is TVGOS related (should of been merged here where it belongs) which you could try.
post #947 of 1480
clb012;
I assume you are in Ontario? (put that under your username, it lets others know where you are located) Do you really record anything on that VCR??
I'm not familiar with those Panny DVR recorders, but do you record anything with those? Aren't those analog only?
IOW's do you need RF anything past your STB except for something going directly to the TV's tuner for whatever analog services you have and the QAM, in the clear digital channels.
post #948 of 1480
(EH50) Out to VCR
VCR out to TV
I also own a Panasonic DMR-EH50, connected via IN3 S-Video Input from the STB and using the IR blaster to control the HD cable STB
1) What is the model of your Rodgers HD STB?
2) Does Rodgers provide Analog TVGOS data on one of the channels through the STB? (If so using the IN3 S-Video Input from the STB and using the IR blaster to control the HD cable STB is the best way to go. The HD STB would need both Analog and Digital capabilities, (Ex. Cisco 4250HD or 4652HD, the third digit "5", of the model number denotes both Analog and Digital receiver)) Note: Cisco will use the Scientific Atlanta codes from the DMR-EH50 TVGOS Set-Up.
a) If not, then the RF Coax Input is your only choice. The Coax should not be passed through any device and a 2-way splitter should work fine as long as your signal is strong enough.
Rovi TV Guide On Screen/Guide Service Availability Check
If you do not have the User Manual,
Here is the link to Operating Instructions DMR-EH50
Attached are the Set-Up and Connection Pages:
PanasonicDMREH50UserGuide Cable Box.pdf 226.744140625k . file
PanasonicDMREH50UserGuide Cable Box 2.pdf 219.7578125k . file
post #949 of 1480
For the past week, I have emailed numerous people around the WJCT PBS station and have made about 20 phone calls thus far. **No one** returns my calls or emails. I have been extremely polite. ***THIS IS VERY FRUSTRATING.***
I think I may sell both of my Sony DHG-HDD500 units. I will sell them for $400 each + actual ground shipping cost. PM me if interested.
post #950 of 1480
Is this where I tell you 'I told you so'?
Have you asked for engineering?
have you asked in your local reception thread?
post #951 of 1480
You get what you pay for.
Right now HDTV is available free OTA and on some cable co's as unencrypted Clear QAM.
Get a rooftop/attic/whatever antennae and enjoy it while it lasts (free, that is) b'cause it wont be long before you have to pay for it, no matter how it comes to you.
We're discussin' years old tech that is obsolete, so enjoy it while you got it, but nobody in CORP is listenin' to your yells about not gettin' it for FREE.
Rovi is making money elsewhere and is obviously not interested in keeping this technology going forward as there's NO PROFIT IN IT.
I WOULD BE INTERESTED IN HEARING IF ANY OF YOU HAVE BOUGHT A PRODUCT RECENTLY (A NEW PRODUCT INTRODUCED IN 2011) THAT ADVERTISES IT HAS TVGOS???
IF SO, WHAT IS IT, WHAT VERSION OF TVGOS DOES IT HAVE, HOW MANY DAYS OF PROGRAMMING, DOES IT WORK FOR YOU?
P.S. Just want to say for those who bought into this technology early on, I know it wasn't free as I did the same. But it's old-tech and obsolete now. We were the pioneers that paid for it.
post #952 of 1480
The most recent DVR is the CM (former Dish Network) DTVPal.
Last I knew, some Mits' & Sony TV"s still have at least a single days worth of TVGOS.
post #953 of 1480
............. P.S. Just want to say for those who bought into this technology early on, I know it wasn't free as I did the same. But it's old-tech and obsolete now. We were the pioneers that paid for it.
Yeah, we hear you. But the problem is there is no device, NO DEVICE, currently available in the U.S. that is as slick as the DHG. And "old-tech and obsolete" or not, when friends come over they never cease to be amazed, and ALWAYS ask where they can buy one (DHG).
post #954 of 1480
I WOULD BE INTERESTED IN HEARING IF ANY OF YOU HAVE BOUGHT A PRODUCT RECENTLY (A NEW PRODUCT INTRODUCED IN 2011) THAT ADVERTISES IT HAS TVGOS???IF SO, WHAT IS IT, WHAT VERSION OF TVGOS DOES IT HAVE, HOW MANY DAYS OF PROGRAMMING, DOES IT WORK FOR YOU?
Right now Sony seems to be a buddy with Rovicorp. My EX700 has V10 (24 hours via internet) but it assumes you are OTA and doesn't support cable since the TV doesn't support a cable card. The latest version, EX729, also supports TVGOS.
It is strange since V10 shows all the raw QAM channels as unknown and will permit mapping of the channels to analog number from back when we had analog basic cable. Do that, however, and you may crash the TV software. I don't keep TVGOS activated but when you switch to PSIP (I have none) the clock still gets sucked from the internet. So yes, a 2011 TV exists that uses TVGOS. I still get two V8 feeds on my analog cable. That probably won't last.
post #955 of 1480
I hear you. It sucks. I doubt Funai will add HD to their 515H. No guide either. The Sony DHG is one classy unit. I can see Sony exec's walking around, shaking their heads, wondering how they made something that has lasted this long. Imagine how much they would cost on eBay if it had a manual clock set!
post #956 of 1480
Just look at what they go for on e-bay.
What other consumer electronics device sells for close to what it sold for new??
Sony & Samsung made huge mistakes dripping a winner. Sammy with their LED driven DLP TV's and this. Of course, Samsung doesn't own a movie studio.
post #957 of 1480
This is true for me, too. It's probably the only device I have which people are ever interested in to that extent.
I even had a Dish tech once all enthralled with it and asking me questions about it. He was all surprised that he had "never heard of it before".
post #958 of 1480
The HD definitely won't ever happen. And I seriously doubt if it will ever get any kind of guide, either. For one thing, it's designed for the lower-end customer, and that would put it too up there. Their full intention is to keep it that way. It's the modern, albeit better, version of the VCR. That's it's niche, plain and simple, and I would fully expect it to stay there.
The only thing comparable to the Sony these days is an HD Tivo with the lifetime fee. That can be had for under $600, which really isn't a bad deal at all, considering that the Sony DHG250 and DHG500 originally sold for $800 and $1000 respectively (and the hard drive in the TiVo can be user-upgraded).
post #959 of 1480
Less moving parts to go wrong and no bulbs is really a bigger selling point, though.
I'm not a big fan of how they've pushed LCD technology over plasma myself (for TV's, that is), but it's apparently more profitable, even though plasma's really more like a natural progression of, and more like watching the old CRT's - just on a larger screen and with more detail - and watching flat panel LCD TV is, to me, like watching TV on a giant computer screen.
post #960 of 1480
The HD definitely won't ever happen. And I seriously doubt if it will ever get any kind of guide, either. For one thing, it's designed for the lower-end customer, and that would put it too up there. Their full intention is to keep it that way. It's the modern, albeit better, version of the VCR. That's it's niche, plain and simple.
I agree, but I'm allergic to a CableCARD. So is my cable feed. They barely use RG-6 unless requested. So the search continues....
  Back to Forum: HDTV Technical
