Originally Posted by danepowered
I have 4 Sony DHG units. They all quit receiving listing updates around the 1st of October. Pretty suspicious since it is the beginning of a fiscal year. I receive the info over-the-air only. I have contacted WJCT and have not received a response yet. Does anyone have any info whether WJCT is still broadcasting TVGOS info?
Do you know how to tell? From Mark on the DHG forum:
If you are running the 1.2.21 firmware, and there is any TVGOS data to be found on the cable line (analog data or digital data), the DHG will find it.
You can go into the 753 menu, and check the clock in the upper left, and see if it has a [2] next to it. If it is a [2], and not a [3], then there is no data. However if it is a [3], then the DHG has been getting data.
Mark
<<<<br />
Same logic applies for OTA data.
