Originally Posted by
imdjenk
What are the symptoms? Does it say the data is corrupted, does it start to play and stop, does it stutter etc? I'm not an expert on streaming but I'll try to help. I use Tversity and PMS and stream with no problem. I don't think your network is an issue because the transfer rate shouldn't be too high.
BRB, gotta go turn the crank.
imdjenk,
Sorry for the delay with this response. I've resolved the issues. It was my network, sorta.
First, the symptoms I was having. It wasn't corrupted. When I tried to play the movie, it would play at about 1 frame per 15 seconds. Throughput was horrendous. When I hit the
select button, on the controller, it showed a "
-" as the number of kbs or mbs (I'm at work, so I'm going from memory) that it's playing/streaming. I thought at first, my DLNA servers were trying to decode the movie and that was what was slowing things down.
I put both my PC and PS3 into my Linksys WRT54G router/switch and now everything plays fine. Previously my PC was patch into a Cisco switch, which was then patched into the Linksys. The Cisco may have the port settings configured wrong. I'll be investigating that issues shortly, as it would explain some other rare anomalies.
I hope that all made sense. Sorry for taking such a long time to reply, but everything works great and I'm saving about 40% on space. NICE!!
