Here's my build thread to duplicate the VT-3 setup from NHT.
The original VT-3 system had an upper chamber using two 6.5" woofers, one 5.25" midrange, and one tweeter. The lower compartment had two 10" subwoofers.
Link to a review:
http://ultimateavmag.com/speakersystems/11/
Well, as luck would have it, my last subwoofer built just so happened to use twelve of the exact 10" subwoofers from the VT-3. I believe that I have the bass portion nailed down.
So, that leaves me to build the upper front compartment, which is pretty much exactly like the matching VC-3 center and the VR-3 surrounds. I contacted Jack Hidley and he was able to get all the exact drivers, the original crossover, and even the build plans! http://home.comcast.net/~jhidley/
I have the finalized outside dimensions for the upper compartment and the center channel. The original had laminate over 3/4" mdf. Jack went to work and decided that 1" mdf could be used with no laminate and get the same strength, which of course would also be easier. Plus it would allow for roundovers, which he believes should sound better.
Link to a review:
