AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › BD370/390 LG Blu-ray player Master/Owners thread
BD370/390 LG Blu-ray player Master/Owners thread - Page 104
post #3091 of 6863
My BD390 is HDMI connected to an AV receiver which is HDMI connected to a 1080p Samsung HDTV. The HDTV is capable of handling whatever video resolution it's sent (my receiver is HDMI passthru for video). For this setup is it better to leave the display resolution in the BD390 set to AUTO? Or is it better to set the BD390 display resolution to 1080p - and let HDTV handle it?
post #3092 of 6863
Originally Posted by danny_w View Post
I know these questions are more Netflix related and player related, but I didn't know where else to ask, and I couldn't find a contact for Netflix on their site.
When you open Netflix page hit Ctrl+F, type "contact us", hit Enter and you will be placed on a link to contact, including phone, Netflix support.
post #3093 of 6863
Thanks. I'll call them after work tonight. I didn't see any way to email them, and the "report a problem" links were only for specific issues.
post #3094 of 6863
Originally Posted by catmother View Post
You did not specify the OS so assume it is XP Pro media center edition.. Do not have that but on plain XP Pro SP3 bring up the file manager, navigate to the folder with your recordings, right click and select 'sharing and security'. When that window pops up click the checkbox titled 'share this folder on the network' Give it a new name if you like and apply.
But keep in mind that a firewall or some (antivirus programs) may block this and will require adjustment. With Zonealarm set to 'trusted' on my internal network no adjustment is necessary.
I have not encountered the CFIS password situation but there are some posts on this thread that reference that. Do a search.
Sorry, it's Windows 7 and I tried everything and it won't even show any shares from this PC at all.
post #3095 of 6863
When you get the CIFS prompt just type in the username/pwd you use to log into your computer. It'll only prompt you once...
post #3096 of 6863
Thanks but the CIFS prompt shows up on the PC with the shares. The Windows 7 PC that I have the recorded TV programs doesn't even show any shares at all.
post #3097 of 6863
what if we dont use a password log in? can it still be done?
post #3098 of 6863
If you don't have a password configured for your user then try just entering the username and leaving the password blank.
post #3099 of 6863
With Winows 7 you need to set up your HomeGroup. When you do that you will be telling it what folders will be shared. I have no problem seeing files over my network on the three machines I've upgraded to Windows 7.
Go to the Control Panel and click on “Choose homegroup and sharing options”
post #3100 of 6863
Go to the Control Panel and click on Choose homegroup and sharing options
It's showing the files now and it shows 2 for the one recording. It's a .wtv file and the LG player is telling me "Cannot play this file" now.
post #3101 of 6863
Originally Posted by doctorwizz View Post
Pretty sure you can't play BR structure from a USB. You have to browse to the file you want to play. The only way to play HD audio is by playing a BR disc. It will not play any files with HD audio.
Best way to watch with uncompressed video is use TXMuxer on the ripped main movie m2ts. You have to highlight the HD audio track and put a check in the Downcovert TRUE HD to AC3 or DTS. I made .ts files. Rise or the Lycans with 25Mbps overall bitrate and AC3 streamed with out skipping using 100M wired. Benjamin Buttons with Overall bit rate 33.4 Mbps and DTS skipped when streamed. I put it on a 2.5 UBS drive and it played with no skips so far. Didn't watch the whole movie.
It seems the highest bitrate I can stream with my 100M wired network is 25Mbps.
Would a wireless N be faster then a wired 100M?
aww man, too bad there arent any bluray players that can play bluray rips as well with no video compression an hd audio. going to have to wait and see what the dune hd 3.0 player can do.
wireless will never be as fast as wired. for high bitrate files i would go wired or usb. i can't do wired as my computer is upstairs and player would be downstairs so usb is my only hope.
post #3102 of 6863
Since your AVR is pass through either one will work. My AVR is a Sony 820, also pass through, have tried both .. no difference.
post #3103 of 6863
Hi All.
I've had a problem for about a week . I can no longer stream Netflix from my bd-390. Vudu works OK. I spoke with LG, they directed me to Netflix. Netflix says that it was a bad LG firmware upgrade. I haven't seen any mention nor does LG have a resolution for me. Has anyone else heard about this?
Zaxdad
post #3104 of 6863
Just bought my first movie on Vudu. Very disappointed to find out that some of their movies are only available in stereo! Plus, since they use Dolby Digital Plus, my Yamaha RX-V863 can't apply any matrix processing. This really decreases my level of interest in Vudu.
post #3105 of 6863
I ordered my 370 today to replace my Panny BD35K. I hope I don't regret it.
post #3106 of 6863
What does DD+ have to do with matrix processing? with my receiver it doesn't matter whether it's DD or DD+ or DTS-MA etc.
If your receiver has a problem with it then you need to set the BD390 to decode it and send out PCM.
And as far as some movies only available in stereo, VUDU has no control over this. This is the same with all providers of VOD. They can only encode what is givem them by the studio. Many times the studios only give them a stereo master to encode and not a multi channel master. But whatever VUDU receives that is what they encode.
You need to talk to the movie studios if you have problems, but it won't change what they do.
The movie studios dictate the rental period, the quality of the master they give them, and whether the title can be in HD or Sd and whether it can be rented, purchased or both. They could give them a crap master or a great one. But either way the VOD providers have no control over any of it. The Studios control all of this.
So don't blame VUDU, blame the movie studios.
post #3107 of 6863
If the 370 is anything like the 390, you won't regret it. I haven't used my panny BD35 since getting my LG BD390. The BD35 is like a turtle compared to the speed of the LG.
post #3108 of 6863
I believe this is the most complete list of differences:
http://www.avsforum.com/avs-vb/showt...l#post17185872
post #3109 of 6863
If he wants to apply PIIx to the DD+, I guess he can't do that. After all PII/x/z is just a matrix you can apply over 2, 3, 4....discrete channels.
post #3110 of 6863
BTW, vudu is over rated. Netflix rentals rule the roost for quality and this is a site here that takes quality over dumbed down HD right???
post #3111 of 6863
After testing out Vudu for a few weeks, I have to agree. Netflix also definitely beats Vudu for price.
post #3112 of 6863
Can someone help with this? Why is the LG 390 telling me the it cannot play this file? Others on this forum say they're able to play their recorded Media Center shows on the LG 390?
post #3113 of 6863
Originally Posted by Viventis View Post
Control Panel...Under "Network and internet" is a choice for "choose home group and sharing options." Click what media you want to share and then check the box that says "stream my pictures, music and videos to all devices on my home network."
Can anyone verify that you can play music files? I can find all of my files, and when I select a song, the player starts but before the song plays I get an error that says: "There must be network congestion." Pictures play fine and so do videos. Just not songs. I wonder if I need more bandwidth. I am connected wirelessly to the network and I get a warning to that effect when I open the My Media from the Home Screen.
Viventis - did you resolve your issue with playing audio files? I am experiencing the same problem (all other media files play fine, also running Windows 7). I am on a wired connection. I definitely do not think it is a network congestion issue. I have no problems playing audio streamed from the same Windows 7 PC on other Windows 7 clients in the house as well (both wired and wirelessly).
Streaming audio from Media Player 11 in XP Pro works fine...
post #3114 of 6863
Did LG fixed the lipsync glitch in the 390?
post #3115 of 6863
Originally Posted by gring40 View Post
I now know that I've got an HDMI resolution issue (HDMI cable is OK) between my BD390 and my Hitachi Ultravision HDTV. I'd like some BD390 owners to run this test: go to Home > Settings > Video > Resolution, and then try manually changing the resolution to other settings than Auto or 1080p, like 1080i or 720p or 720i or 420p, etc. Does this cause the color to change to and from psychedelic, and what HDTV are you using?
Thanks to those who responded: I'm hoping a few more people will try this and post the results. Thanks ...
post #3116 of 6863
Also wondering about that. If anyone who noticed the problem before can retest, it would be appreciated. If its fixed I'd like to give the 390 another shot.
post #3117 of 6863
Is this player firmware upgradeable via USB or DVD, or do I have to have the unit connected to the internet for online updates? I'm thinking of getting the BD360 from Costco Canada but it's going to be in an upstairs room far from my router
post #3118 of 6863
Hopefully quick question, the manual is not so clear as it relates to the on screen controls. I'm using the HDMI to the TV and the analog outs from the 390 to my AVR [no issues there] but I'm confused about which setting to use, it refers to audio digal out but never analog out on the 390. for the output .
Which do I choose to give me the use of analog outs?
[PCM Stereo]
[PCM Multi-Ch] (HDMI only)
[DTS Re-Encode]
[Primary Pass-Thru]
post #3119 of 6863
I'm setting out to rip a set of christmas movies in prep for the upcoming season and am wondering what the recommended settings are to get the best picture out of my LG390 when streaming from my server?
I'd be using Handbrake, so what is the best output format and bitrate settings to keep the highest quality?
post #3120 of 6863
I am experiencing the same message when trying to play audio files when running Windows 7 to my 390. Looks like a software update is needed
