I searched the forum and couldn't find my situation addressed.
I just installed the 390 thru the Denon with a high quality HDMI cable. If I set the resolution to 1080p/24 or Auto, I can play a blu-ray disc at 1080p. Same goes for Vudu HDX streams. However, if I insert a standard DVD, I get no picture and only spurts of sound.
If I manually change the resolution on the 390 to 1080i, standard DVDs play fine. However, to see bly-ray at full resolution, I need to manually to change back to 1080p.
Is this normal behavior for this player?
Or, is my player defective or setup incorrectly? I would think that an Auto setting would play all discs at the appropriate resolution.
All help would be appreciated.
