Originally Posted by Lhasa-lover
I just picked up this player on Sunday. Returned a Samsung that had video drop out issues with SDVD. Connected it up in about 5 minutes. I have an old Yamaha RX-V2095 receiver in my bedroom that is about 13 years old so it doesn't have HDMI but it does have 5.1 analog inputs. So I connected the player up to the receiver via the analog outputs and to the TV via HDMI. Samsung 46" LCD bought last month. Player works perfectly. I watched several blu-ray movies as well as several SD as well. No lip synch issues at all. SDVD quality is great, as others have reported, much better than my PS3 that I use in my main media room. The reason for lip synch is fairly simple. It's a timing issue as the video signal gets handled slightly before the audio signal does which has to go through the receiver and get processed. That processing delay is what makes the audio signal get slightly behind the video signal. If your reciever or preprocessor has lip synch delay built in use it. The only other solution, as I see it, is to run both audio and video through the receiver/preprocessor if possible. If not and you have no lip synch delay, then you may run into the same issue with other players as well.
Build date on mine is May, 2009
And I agree that the drawer is flimsy! Good thing I do not have small children.
Well I was incorrect in saying my Onkyo SR605 has no adjustment for lip sync as I checked the manual. It is in the settings menu. BUT I never needed to mess with this as I have other BD players with no lip sync issues. If I adjust the lip sync setting, then I might cause a problem somewhere else with another player amd I'm unsure if it will solve the problem to begin with. Guess I have no choice but to try, the Video PQ is way too good for me to want to give up on this player.
The audio via HDMI for lip synch is way off whether I use my AVR or just connect to my display. And I do mean way off!
My golf game is coming together in June and if I can just get this lip sync issue resolved then it will be happy days as well with watching movies with high quality. Life's good? Not quite yet!
![Band of Brothers [Blu-ray]](http://cdn.avsforum.com/8/82/50x50px-ZC-82812e5d_B00129H7VS-51AHSW8fE2BL.jpeg)
It just that this particular issue spans many different transports, receivers, preprocessors and is fairly common. But you may be right. Your Blu-Ray player might be defective.
In tests done with components level matched nobody has yet been able to differentiate between DACS. Of couse unless the DAC is flawed.
