Originally Posted by
tightrope
I do not use my 93 in a network environment (my files reside on attached storage), but it can access files via DLNA. You should check out the Oppo 93 thread here on AVS, it is very informative.
As I said, at the time that I bought the LG 390, Oppo only had the BDP-83, and it was very clear that it did not play NTFS files, only FAT32, through discs or external media (USB).
But I just read the BDP-93 manual and that seems to have changed, which is a very good thing.
About streaming, the 93's manual says that through "My network" that should be possible, but it's experimental and there's no support from them. What I wonder is if you can't stream film using "My films". Can you? What type of files?
The other thing I like about the Oppo 93 is it still has 5.1 analog audio output, which the latest LGs do not carry it anymore.
It's quite likely I'd buy an Oppo if I travelled to the USA soon.
