AVS › AVS Forum › Display Devices › Screens › Suggestions for an Inexpensive Fixed Screen
post #1 of 10
I am on a very tight budget and looking for a fixed screen with the best value. I need a 92" to work with a Panasonic Ax200u and would like to stay under $200. Does anything exist for me?
post #2 of 10
http://www.htdepot.com/Focupix_Wides...169lt-90mw.htm
Enter Escreen 12% discount code.
post #3 of 10
if you are willing to build - its very easy to do. i did mine in an afternoon and a couple evenings for the trim. heres my thread on mine -
http://www.avsforum.com/avs-vb/showthread.php?t=1071006
and a couple newer pics -
post #4 of 10
ebay; shoppingdeals
See screen DIY section.
post #5 of 10
Your selections in this range are certainly limited, but DIY is a good option.
post #6 of 10
I'm entirely satisfied with my Wilsonart laminate screen. Less than a hundred bucks, and infinitely durable compared to "real" screens.
post #7 of 10
Is this product available in sheets suitable for 110 diag viewable ? If so - links ? pointers ? TIA
post #8 of 10
Home Depot or Lowes sells Wilsonart laminates. Two types are recommended, the Designer White and Fashion Grey material make excellent screens and they come in either 4' wide by 8' long or 5' wide by 10' long sizes. You should check the DIY screen section for additional info.
post #9 of 10
The Escreen coupon expired anyone know of a new one??
post #10 of 10
springtime 11%
  Back to Forum: Screens
