AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-83 Owner's Thread [technical talk only]
Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 364
post #10891 of 38773
Originally Posted by quad user View Post
The BDP-83 remote also controls my 971H. This is very annoying. Both players open their trays simultaneously. Anyone know how to fix this?
Also see the FAQ: Do the remote codes conflict with those for older OPPO players?
-Bill
post #10892 of 38773
Originally Posted by BOB HAN View Post
Sorry, it is "Live from Austin TX", Norah jones Austin City Limits. produced by New West Records DVD production. The disk starts, but then "ROOT Menu" comes up ( no sound or picture)
Thanks Bob. Sorry, I have several other NJ DVDs but that one is not in my collection. Would have played it to give you my feedback. However, coincidentally someone has already succeeded in doing that.
I have seen that message (Root Menu) which is fortunately followed by the menu. Sorry for your problems. This may be obvious, but have you checked the playing surface of the DVD. And cleaned it? Even new out of the case, I have found that helps. Or the disc is defective (i.e., bad pressing). Just attempting to be thoughtful.
Best,
Richard
post #10893 of 38773
Sorry, I mean just "scrolling" Just plugged in again and still scrolling.. Everything is at default and played well thru my oppo supplied HDMI cable to my 1080i sony TV last night .I will now try unplugging my HDMI cable and power and try again. I did try the P/N button to no avail. Worked well last night everytime. My fat fingers just hit the off button insted of the volume button that caused this issue.
post #10894 of 38773
Hi,
I'm trying to copy a CD to minidisc. Normally, as long as the minidisc recorder is on digital-in it delineates each track on the CD and the track # increases. While trying to do this on the OPPO, all I get is 1 long track 1 as though I was doing an analog copy. Should I change the audio out from compatible to advanced?
post #10895 of 38773
Originally Posted by mw390 View Post
Hi,
I'm not familiar with your process, but I'm sure the audio setup in the Wizard will not change the behvior.
-Bill
post #10896 of 38773
Thank-you wmmclain. I re-trid the P/N button which did fix my scrolling problem.
post #10897 of 38773
I don't know why turning it off would cause this.
Connect the composite cable and switch to that input. This will at least allow you to see the setup screens. Do a reset to factory default and see if that helps the HDMI output.
-Bill
post #10898 of 38773
Ok, great! Somehow your player was sending 50hz (PAL) instead of the 60hz (NTSC) which is standard in North America, and your display didn't like it. Cycling with the P/N button got you back to NTSC.
There is also a setup menu item for this, but according to the manual the remote button setting is saved, so you should be ok.
-Bill
post #10899 of 38773
Originally Posted by Smarty-pants View Post
Mine sags a little, but the bottom of the female end rests on the bottm edge... never a problem.
What are you talking about here? I thought this was the BDP-83 thread
post #10900 of 38773
Got my 83 a few days ago and have been playing all formats. So far, all sounds and looks great, really liking this player.
The only thing that I felt was strange was the speaker trim control.
Let's say you trim the sub level down to -10db because it's too loud for some reason, if you click it once more, as if you were trynig to trim it to -11, it doesn't stop at -10 as all other controls I have used do, but it goes to +10! No big deal, but it is counterintuitive. I would expect it to stop at -10 and go no further. The last place I want it to go in that situation is +10. Could damage a speaker in some scenarios, especially when you figure the changes are inplemented instantly as you select each one.
Hopefully a firmware upgrade can fix this. Minor issue though.
I did a search and found no mention of this.
post #10901 of 38773
Main problem: When I play Bonnie Raitt's DVD-A the player goes through the FBI warning, then a very quick "CAPITAL RECORDS" display accompanied by a "pop" sound, then the Capital Records logo sequence for 33 seconds then goes to 0, displays root menu and produces loud static. I have to hit stop then play to get the main menu to appear. Have repeated the sequence three times. This seems like something on the Oppo side.
Secondary problem: As the disk plays with the lyrics on the display, the lyrics don't change as the music progresses. This sounds, perhaps, like something on the disk side.
Any advice?
post #10902 of 38773
Sorry if this has been covered but when using the 1080P24 output setting to my JVC HD-100 (RS2) FP, I lose the volume display from my SSP (Integra). The connection is HDMI to SSP to JVC. Turning off the 1080P24 restores the Integra volume display on the projector.
Since my electronics are in another room I can't see the Integra display without leaving the HT room. This is a real PITA so I am not using 1080p24. Anyone else notice this?
post #10903 of 38773
By the way, I just wanted to throw my two cents in about the tray: Why is this such a cheap tray (in some peoples opinion)? I think the tray is perfectly suitable, and it's WAY better than the trays that were used with some of their older DVD player models. I really don't see a build quality issue here. I love the build and design. Just wanted to argue with those that thought this was cheap, it's not!
post #10904 of 38773
Before I get to the problem, I must state that when, on Friday, I received and unpacked the BDP-83 I was stunned by the quality of the packaging and pleasantly surprised by the inclusion of the calibration disc.
I hooked up the unit to the D2 via the HDMI output. Played it a bit on Friday, and again for a couple of hours on Saturday afternoon. By then I was pretty impressed by this $499 player as compared to the Sony BDP-S2000ES I have been using.
On Saturday evening about 2hrs into watching a BD disc, I encountered a loud snap from the speakers, followed by a shutdown of video and audio. None of the components actually shut down and I later confirmed, via the time graphs on a power monitoring software program I have, that there was no electrical spike.
After about 20 secs, the video came back up and maybe 15 secs later the audio returned. The D2 acted as if it were coming out of a protection mode from an input spike.
This has never happened before, and the only difference is the inclusion of the BDP-83 to the system and frankly I am concerned that the Oppo sent the spike via the HDMI cable, that by the way was mine, not the one they sent. I did this so the Sony and Oppo have the same input.
I will report this to Oppo and Anthem. Has anyone else encountered anything similar?
post #10905 of 38773
Question re audio: many older BD's only have a 'lossless PCM' audio track, not the newer hidef formats (Dolby Tru HD, DTS Master audio). Can one give this track over Bitstream, or does one need to set the 83 to output PCM?
post #10906 of 38773
I don't think anyone has mentioned this before. In some cases you want menu selections to loop around just for faster access, but maybe it makes no sense for the trim. The Picture Adjustment sliders don't loop either, for example.
-Bill
post #10907 of 38773
I have the -83 hooked up to a WD passport 2.5 HDD. -83 sees it and plays mp3s no problems. No external power needed and there isn't actually a way to power it. Its 160 GB and black.
I actually have 2 versions of this external WD passport
One silver top, black rubber bottom w/ ability to plug in external power @ 120 GB
One all black, no external power ability @160 GB.
Possible BUG: When playing mp3s sometimed "Add to Playlist" overlays "Shuffle/Random"
edit
nice to see that music plays when browsing other types of files.
vobs work okay, I have a 16:9 5.1DD dvd vidrecorder and it looks awesome. The problem with the vobs is FF and RW and chapter movement is wonky.
post #10908 of 38773
This is my first post but I must admit I have enjoyed reading this blog over the last few months. I am an old audiophile and still enjoy a little tweek here and there. But have learned to just enjoy the music. I know that real audiophiles only listen to analog. I was in that group for many years. But the first time I heard DVD Audio on a good 5.1 system I was hooked. It just seems to involve you more in the music. I have a large collection of DVD A and sacd. Some great some not so great but for the most part better then my old LP's.
I have to say that I got sucked into this EAP program and have to admit to checking my email on an all to regular basis. I was not one of the 350. But I came home from work a couple weeks ago and there was my invite to purchase the BDP 83. I felt like a little kid on Christmas morning. This is wierd because I have owned equipment costing 10 times as much and most were Stereophile recommended products. Oppo had me feeling like I did when I picked up my first Marantz system at Musicraft in Chicago in the early 70's. That system lead to 20 years in the comsumer electronics industry. The most enjoyable time of my life.
Well that brings me to friday when the fedex truck pulled up out front with my Oppo BDP 83. Like that first system I couldn't get it out of the box quick enough. (I knew this was going to be great because the box was like getting audio equipment from Tiffany's) Anyway I hooked it up through the analog inputs of my HK AVR 7200. HDMI to my Oppo switcher into my Panny plasma. Went into the setup menu and adjusted everything to my liking. Put in Hotel California and was instantly floored at the sound. Over the weekend I have listened to all my favorites and I must say that my expectations have been exceeded. I have owned many DVD A and SACD players and the without question the Oppo is the most musical.
This is my first BD player. I watched Australia and Boltz last night and all can say is it was the best picture and sound I have seen and heard on my system. Anyway, that's my 2 cents worth. I am going to go back to my living room to enjoy the music.
Oppo job well done. You have created a fantastic product at a fantastic price.
post #10909 of 38773
If you look at the Audio Signal Reference Chart in the manual, you get PCM for these tracks regardless of the setting.
-Bill
post #10910 of 38773
-Bill
It might only be an issue if you have a cd or whatever that is putting out really excessive bass and you bring it down -10 then hit it once to much and push it to +10db. If -10db turns out to be balanced for your system on that cd and you roll it to +10 db, well that's +20db from ideal, could damage a sub that's not designed to handle that big a swing, correct?
post #10911 of 38773
I've never had anything like that using my Beta Oppo with the D2 or the D2v.
Did you happen to have the front panels in view? Any messages on the Oppo or D2 front panels during the loss of audio/video?
By all means call both Oppo and Anthem. While waiting on that, double check that in the course of adding the Oppo you didn't accidentally short any other cables/sockets.
Keep in mind that in addition to power, your system is likely also connected to the outside world via cable/satellite feed. That means you can sometimes get spikes that come in on the cable shields of those feeds (from lightning storms or whatever). Such garbage can travel from box to box (even if you are not viewing the cable/satellite at the moment) via the cable shields of the wires connecting the various boxes.
--Bob
post #10912 of 38773
Originally Posted by nsrii View Post
That sounds like an interesting workaround. Thank you for the suggestion and I'm glad it's working for you.
As I was always planning to use this hard drive with the BDP-83, I would never have known about the problem if I hadn't tested the flash drive first. The main thing here, however, is to try to gather as much information as we can in order to help OPPO diagnose the issue, since perhaps every flash drive they've tested has worked fine. If, as in this case, plugging in a second drive apparently corrects a compatibility issue with another drive, then to me this strongly suggests a bug in the firmware as opposed to hardware-level incompatibility.
I do have an external USB hard drive, but I don't want to format it just to tinker...I'm a Mac user so most of my drives are not FAT32. The reality is that I was just testing the flash drive for functionality. I'm probably going to end up getting a SageTV HD Theater and use that for all my digitally backed up content.
That's OK, just do what you can. I only have one flash drive, so I'm going to borrow somebody else's for now to experiment further (one with no critical data on it--I know people who have older flash drives lying around unused).
Can we add this to the potential bugs list in the FAQ, since it appears to possibly related to the use of Mac (I saw another poster mention that they were in the same situation -- Mac + USB drive = locked up Oppo.). I'm happy to contact Oppo with my issue so it's "official."
I use a PC, by the way, and although my BDP-83 was always able to access my flash drive's directory structure, it locked up upon accessing most files most of the time, sometimes immediately and sometimes after a few seconds. Occasionally, the file would play for more than a few seconds, and whenever that happened it generally played until the end perfectly. With a second USB drive attached to the other port, the drive that the BDP-83 was having problems with works flawlessly. Much of this information has been stated before, but the issue seems to be getting more attention now, so I'm reiterating it.
Originally Posted by Neuromancer View Post
I will put a note on the first post, but it will go under "Unconfirmed" until further notice, as there is no guarantee that the errors are related to using a MAC OS and formatting with FAT32.
There may or may not be similar problems related to the fact that a drive had been formatted on a Mac, but my flash drive was formatted on a PC and I still experienced lock-ups when accessing it (until I plugged my external hard drive into the rear USB port simultaneously).
Originally Posted by vläd View Post
I do know from several experiences that an Apple formatted FAT32 is not exactly the same as a Windows formatted FAT32. I wish that I could give everyone the exact differences, but other than the Apple/Mac allowing larger FAT32 partitions than a Windows format may lend a clue as to the differences.
How clever of them to compromise compatibility on a type of format that is retained only for the purpose of compatibility.
post #10913 of 38773
--Bob
Thanks, Bob,
The Oppo front panel appeared normal. I didn't see anything odd with the D2, and I know it did not totally shut down as my screen, that is connected to the D2 trigger, did not retract. Weather was clear and calm, and I have no way of knowing if the spike came from another unselected input.
post #10914 of 38773
How does the silver WD 120 GB work? I have one laying around...
As USB seems hit and miss, with certain devices working fine and others initiating the self destruct sequence, how about adding a list to the FAQ? Considering that USB support/changes seem low on Oppo's list, a 'Working USB devices/file types' would serve well in the interim. It could be a real time-saver (and cost-saver for those purchasing USB devices).
As part of the testing protocol, perhaps testers could populate both USB ports in the event of playback issues while using 1 USB port only. It seems to have worked in one case....
post #10915 of 38773
Thanks, Bob,
The D2 will put up a message on the front panel if it goes into protection. I presume you also did not see the Anthem splash screen come up indicating the D2 had rebooted.
If you had just lost audio, I'd suggest it was the power amp that went into protection -- and I'd look carefully for any hair of wire out of place at either end of each speaker wire.
But that wouldn't cause loss of video.
A failed HDMI handshake could cause loss of both audio and video -- including corrupted audio as part of that. But I'd either expect that to cure itself faster than 20 seconds or not at all. In any event, it is probably worth considering a replacement HDMI cable. While you are at it, get a flashlight and check both ends of the cable and both sockets for any sign of bent pin damage.
--Bob
post #10916 of 38773
Wild theory: an HDMI cable problem, possibly a momentary loose connector issue. With those awful connectors, nothing beats the security of the PPC locking connectors or possibly some of the other cheaper solutions out there.
post #10917 of 38773
I'm not yet seeing a consistency of reports on what works and what doesn't. It may be problem players, problem firmware, problem devices or problem formatting. (I omit "problem people" because everyone here is serious about testing USB, but you know it happens).
Unless we hear something definitive from OPPO I also suggest that everyone trying this be prepared to retry your test cases after each new firmware.
-Bill
post #10918 of 38773
Just setting up my unit, and am thrilled with both the analog stereo and HDMI outputs. However, I wanted to compare the Oppo's internal DAC's with my Benchmark DAC1. Unfortunately, I cannot get either the Digital coax or optical outputs to work. I've tried a factory reset, and also tried both the PCM and bitstream settings, but no luck. I previously used my 980H as a transport into the Benchmark via optical or coax, so I know those cables are good. I am seeing the red light output with the Toslink. Is there some special setting I'm missing?
post #10919 of 38773
Make sure everything is properly grounded. Since the Oppo doesn't include a grounding lugg on the AC cord, the grounding will need to come from the cables connecting the system.
It sounds to me like there was a static charge build-up that released though the system. You could try attaching a grounding wire from the Oppo chasis to the AVR grounding lugg. This would eliminate the possiblity of static build-up and discharge.
post #10920 of 38773
Any advice?
This disc has worked with previous FW revisions, this appears to be a new issue with the recent FW revision. This type of playback problem should be reported directly to Oppo.
