AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-83 Owner's Thread [technical talk only]
Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 528
post #15811 of 38730
Originally Posted by narkspud View Post
I know ImgBurn will do it. It's free.[IMG]http://***************/9/P/i.jpg[/IMG]
Great resource thanks..I found some other progs but this seems like it will do the job perfectly
post #15812 of 38730
Originally Posted by grafxman View Post
I was hoping someone here might know how to get around that blank disc requirement.
And this has been answered.
post #15813 of 38730
Originally Posted by stevec325 View Post
It is generally NOT advisable to power any equipment using the AC outlet(s) found on AVR's... I wish they would not even include them on the AVR. It's not a good source of power and there is a potential for interference back into the AVR from the device - let alone the potential for damage to AVR from the external component. Get a good power strip with surge protection.
The -83 stores settings in NVRAM. They will not be affected by the presence (or, specifically the lack of) power. They can, however, be affected by how the -83 is powered down. Pressing the front panel power button (or using the power button on the remote) will cause an orderly shutdown of the player. Yanking the power cord (equivalent to what happens if you shut down your AVR with the -83 powered on) is not an orderly shutdown. All bets are off on what can happen, if powered off this way.
I repeat the BDP-83 was always shutdown orderly via the power button on the front of the BDP-83 after setup changes were made.
Orderly shutdown= Explicit shutdown via the fron power button on the BDP-83.
It is now plugged into my APC H15 directly and keeping setup changes.
I realize that power outlets on the back of AVRs are not recommended for high current equipment but please this is transport not a dedicated 200W amp. Lol
post #15814 of 38730
Originally Posted by Slooshy View Post
Hello,
Are you using the latest beta firmware?
And this issue is repeatable?
Thank you for reporting the issue to Oppo.
Would you happen to know if Predator 2 works?
Greetings,
Yes, latest beta release, the issue is not repeatable, and Predator 2 does work..
post #15815 of 38730
OK - but NVRAM will generally not lose settings.
I still suggest not using the AVR's AC receptacles for anything.
post #15816 of 38730
Originally Posted by Ralph Potts View Post
Greetings,
Hello,
Thank you for the information. Hopefully, the 12 Rounds fix will also work with Notorious.
post #15817 of 38730
OK - you can try reapplying the last firmware update, following the recommended procedure. Failing that, a call/email to Oppo my be in order.
I used to have a receiver that got a little hot. I put a small 117VAC fan on the switched outputs and put it on top blowing up and out.
That worked pretty good.
post #15818 of 38730
I use it only for a small computer fan that sits on top of my Onkyo 805.
post #15819 of 38730
Airport Express...
post #15820 of 38730
Guys, you realize that you are powering a cheaply made, AC motor through your AVR's... right? If anything is going to kick noise back into your audio - an AC motor is right up at the top of the list. Even other components, including your -83 can cause problems. And, honestly - not worth the risk, no matter how minor.
Surge suppressing power strip, please. Or, an APC/Panamx/Furman power conditioner, if you have a few extra $'s to light on fire.
post #15821 of 38730
I still suggest not using the AVR's AC receptacles for anything.[/quote]
I agree for major equipment, but they are handy for back lighting, add-on equipment fans, etc.
post #15822 of 38730
You guys would rather read a Sterophile article inferring how much better it would be with a $1,000 power cord and/or $500 "magic rocks" placed on the top - to eliminate unwanted power line transients and ambient distractions?
We need one of these as well:
http://www.usa.denon.com/ProductDetails/3429.asp
It's an expensive phone cable.......
post #15823 of 38730
Originally Posted by vinnie97 View Post
Beck - Sea Change DVD-A?! Any idea where this can still be bought?
ick...great album that I wouldn't mind hearing in that format but not for that asking price. It's too bad DVA-A is no longer viable...I'm surprised Oppo is putting so much effort into bug-fixing a dead format.
vinnie77,
All of Oppo's previous players supported this format and many of the loyal Oppo customers bought the early Oppo players for this reason. This is just Oppo thinking about it customer base both old and new. While DVD-A recorded media is not selling like cd's there are quite a few in circulation both old and new.
Respectfully,
Willie
post #15824 of 38730
I read an earlier post stating that for analog audio, lip sync control is not yet available (but may be added later), and I noticed no such control noted in the owner's manual.
Does anyone know if this capability has been added yet? (A deal killer for me)
Paul
post #15825 of 38730
Actually, ac motors are pretty quiet for both radiated and conducted emissions, especially brushless induction motors. Otherwise most turntables would have serious motor electrical noise. DC motors are another story, as are energy-efficient CFLs, very high electrical noise.
Dave
post #15826 of 38730
Is there any way to get lossless audio (music) into the BDP-83 via USB? I have a music library ripped to WMA lossless, but there are other lossless codecs and I could consider them.
My goal is to have a virtual music server with music ripped/downloaded at my PC played on my Home Theater. My pre/pro (Integra 9.8) does not support network streaming. I'm currently feeding my DirecTV HR20 from my networked PC using TVersity on the PC side. That does work. But, I've always been a little reluctant to rely on the HR20/DirecTV for this functionality. I'd be much more comfortable if I had a reliable and standards-based way to get a lossless music library in via the OPPO.
Thanks, Tim
post #15827 of 38730
Just watched 20 minutes of the movie street fighter BD and everything loaded fine.
post #15828 of 38730
Originally Posted by thebland View Post
We all know those who use Macs have a far higher IQ than those who don't...
I realize I'm late to this discussion, but you are correct, at least from my perspective (Mac pc user since 1986 - IBM-type pcs suck IMO)
and as far as the 83 is concerned, as long as the drive in question has been formatted FAT 32 on a IBM-type pc platform, downloading the firmware on a Mac and transferring it to the drive works perfectly fine for me.
post #15829 of 38730
Thanks, Tim
No, not at the moment. Maybe never.
-Bill
post #15830 of 38730
Hello,
Notorious on non-beta firmware played fine for me.
post #15831 of 38730
That's good news!
post #15832 of 38730
Yes.
Roberta
post #15833 of 38730
Thanks, Tim
-Bill
__________________
Can anyone say "deal breaker"?
Roberta
post #15834 of 38730
Thanks, Tim
-Bill
__________________
Roberta
What other Blu-ray players offer lossless audio via USB?
post #15835 of 38730
Originally Posted by Styln View Post
Have to say I have never listened to this disc in stereo, only MCH. And in MCH SACD it is simply incredible! It's one of those discs you play for non-audiophiles to help them understand how good a system can sound. So the MCH version is highly recommended.
Styln
PS I just looked it up here:
http://www.sa-cd.net/showtitle/588 and it costs a fortune! WOW! And here I was worried my SACD collection was a complete write-off. Nope, my "baseball card collection" is going to pay for retirement at this rate
Holy saints alive, I think the DVD-A is looking more attractive compared to that price (I'm not so enthused about owning a CD on 24kt gold...placebo comes to mind).
post #15836 of 38730
Roberta
weird. Ah, well, what's important to some...
Frankly, why not just play CD/SACD/DVD-A/BD/DVD with lossless audio instead, and hookup a computer for FLAC/WMA lossless if that's what's really required? If you're running flac, and posting on AVS, you've got a comp somewhere at the house to manage the larger files.
Respectfully, this goes beyond expectation management - I was vocal, and continue to be, about mutliregion support, as this is a limitation of a feature we've come to expect from Oppo. It's also directly related to playback of core functionality (DVD). If there was no support for TrueHD, or DTS-HD MA, or 7.1 PCM, then, yeah, deal breaker.
I'd -love- Flac support, but I simply can't see how that's not a stretch, particularly given the fact that this is hardly news, being discussed for -months- now. No Oppo has ever done Flac, I can't think of any BD player that does either (save through UpnP and tversity transcoding).
Besides, it's not like you're adverse to having more than one player in your equipment rack (*cough* Laserdisc *cough*)
ps. In case you missed it, the players are available now in T.O. from local resellers...
post #15837 of 38730
Originally Posted by stevenjw View Post
Any owners of this Kevin Smith BD? Did you try playing the outakes extra? Did it work for you? I have the Oppo 83 and it freezes when this extra is selected. I have to hit eject as nothing else works after the freeze. Display shows 100000000 or something like that. Stuck it back in after making sure new disc was perfect and tried again. Same issue.
Can any Oppo owner that also has this BD test this too? I'd like to verify that I'm not the only one with this issue before contacting Oppo.
I'm on the 430 release (not the 601 beta).
I called in three weeks ago. I was told they were aware of it as the engineer had that blu-ray in his player before he left.
post #15838 of 38730
Guess it's an Oppo issue that they know about, so need to contact them. Hopefully, they'll eventually get it solved in a future firmware update.
Thanks for the reply.
post #15839 of 38730
A similar issues also happens with T3: Rise of the Machines, but on this disc it happens after you have finished watching the special features.
post #15840 of 38730
Is there a page that has "recommended settings" for brightness, etc.?
