AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-83 Owner's Thread [technical talk only]
Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 635
post #19021 of 38733
Originally Posted by gonzalc3 View Post
The issue is that the Marantz uses dolby/dts algorithms for wav files... that is why I wanted the oppo to handle them..
I can assure you this is not true--unless you are referring to PLII or Neo:6, both of which are easily switched off. Just which algorithms did you have in mind?
post #19022 of 38733
Does anyone know if the 83 supports or could support RIHD (Remote Interactive over HDMI) given it's current hardware?
post #19023 of 38733
Originally Posted by venkatesh_m View Post
I am trying to understand your problem, so I might have got it wrong.
My current setup is Oppo BD83 > Onkyo 876 > Pioneer 8G 768p
I bitstream my audio to the Onkyo and have seen DTSHDMA 5.1, 7.1, PCM 7.1, Dolby TrueHD 5.1 all light up on the AVR display. Of course, to actually see the 5.1, 7.1 you would need to press the display button on the remote or the AVR. This is true even if I send the Source Direct mode from the Oppo. The thing is Onkyo's do not touch the 24p video setting and you cannot appply any post processing of video on the Onkyo. The Onkyo cannot convert a 24Hz signal to a 60Hz. I have also use the BD83 with DVDs that are Dolby Digital 5.1 and DTS 5.1 and have seen them light up on the Onkyo as well. Pls PM me if you need more details. The 876 and the 906 have the same menu structure and firmwares.
My setup Oppo BD83 > Onkyo 906 > Sharp Aquos. I set the Oppo to Bitstream. Playing back BlueRay and DVD movies on any resolution settings, I get NO lights, which on the Onkyo means the text display of the Audio codec from the disk source, and by "icons", I mean the little "speaker box icons" on the Onkyo front display, I only see 2.1, my two front mains, and the subwoofer. I have seven speakers hooked up correctly, Audussey corrected etc. I understand that if I choose "SOURCE > THROUGH" on the Onkyo, the Oppo is doing the decoding and therefore the Onkyo would NOT display such info and that is FINE and UNDERSTOOD! Again, movies play fine and using one of the many listening modes on the Onkyo I can expand 5.1 to 7.1 and get correct audio on all 7.1 speakers.
HOWEVER my GOAL was to setup the Oppo as a "transport", and see what the Onkyo could do with the Video output via it's own Reon chip as well as hopefully see the lights/text of the audio codecs from the source DVD/BLUERAY, on the Onkyo display for once. I ASSUMED the only was to make the Oppo a "transport" was to choose it's "Source Direct" mode, which for most blueray disks means 23.97/24 fps output, and I quickly learned my two year old Sharp display does NOT support. AGAIN, if I choose 1080P resolution output on the Oppo letting it do the processing, the Onkyo has NO problem PASSING THROUGH that signal, as you say it does 1080p 60 hz.
RELATED is I got the audio disk in the mail from Oppo, and with the same bitstream settings, I played the audio tracks and NO icon/text info comes on my Onkyo display. I tried setting the output on the Oppo to PCM, same results. I'm tearing my brain trying to figure out if I missed a setting somewhere on any device. I hope I've made this more clear, as the messages get divided up and lose content as the thread GROWS. Thanks for the help, I'm lost.
post #19024 of 38733
I'm 99% sure that the RIHD you are referring to is Onkyo's name for CEC, which the BDP-83 does in fact support. I've tested it, and the BDP-83 can communicate via CEC with both my Onkyo 885 processor and my Sony HDTV. Don't ask why Onkyo and other manufacturers insist on providing company-specific brand names for CEC even though CEC is part of the HDMI spec (and therefore not company-specific).
post #19025 of 38733
Originally Posted by Redbeemer View Post
I think you are perhaps confusing source direct mode with bitstreaming mode for the audio. The source direct mode is used primarily if you have an external video processor, not just an AVR. I recommend you turn source direct mode off and set your Oppo to bitstreaming for the audio output. That will send the undecoded audio to your AVR which will then use its decoders to process the audio into DTS-MA, Dolby TrueHD, etc. and the lights on your AVR will tell you which type of audio is being processed. I do the exact same thing with my Denon 3808 and the display tells me what type of audio my blu ray player is sending over and the Denon is processing.
Hope that helps!
I use Bitstream for everything, even tested PCM output on the Oppo. I doubt the Onkyo 906 is at fault, as I've seen my speaker icons become active when I am flipping through HDTV "Air" channels and select the Optical feed from display to AVR. I have to assume it's "USER" error, meaning ME at this point and something I am missing. Thanks for the feedback.
post #19026 of 38733
I had to look that up. Is different than HDMI CEC?
-Bill
post #19027 of 38733
I'm not sure. I'm just learning about CEC and RIHD in my search for a new receiver. Information is sparse on whether the compatibility is there between manufacturers. I'm not sure why they seem to name CEC something other than CEC unless they do something different with it.
post #19028 of 38733
Originally Posted by Ulisez View Post
Just wanted to know if the Oppo has a bit meter like PS3 or Pioneer Elite has were it tells at what bit rate a Dolby TrueHD or DTS-HD MA was encoded in? Thanks.
the answer is no it does not. as wmmclain said, it has a combined bitrate meter which tells you absolutely nothing because who knows what the audio and video bitrates are separately. one can only hope oppo will come to their senses soon and make this simple fix.
post #19029 of 38733
Originally Posted by kucharsk View Post
Have any of the board-resident audiophiles compared the sound of the Oppo when playing DVD-A or SACD to that of the Denon DVD-3930ci or other higher-end high-res audio players?
I've currently got a Sony BDP-S550 which has been my favorite BD player to date, and a DVD-3930CI for DVD/DVD-A/SACD and am curious if I can consolidate them with no ill effects (aside from loss of the seamless SD DVD layer transition) in a BDP-83.
Originally Posted by Foothill View Post
You hit the nail squarely on the head -- the layer change is the only noticeable difference between 3930 and Oppo. It doesn't bother me because I'm so spoiled by Blu-ray's audio and video quality that I will rarely play SD DVDs in the future.
I sold both of my 3930s after acquiring an Oppo 983 and a BDP-83. The Oppos perform at the 99th percentile and I don't miss the Denons at all. Search for my previous post for more details on the demise of my Denons.
Foothill,
You forgot about that little "speed" thing.
Respectfully,
Willie
post #19030 of 38733
This is a must have for me, sometimes I obsessively watch the PS3's meter for far too long!
post #19031 of 38733
Hi Roger,
There is a long discussion about this issue in the av8003 thread..Marantz representatives brought that issue...
post #19032 of 38733
According the wiki article on HDMI (http://en.wikipedia.org/wiki/HDMI):
Alternative names for CEC are Anynet (Samsung); Aquos Link (Sharp); BRAVIA Theatre Sync (Sony); Kuro Link (Pioneer); CE-Link and Regza Link (Toshiba); RIHD (Remote Interactive over HDMI) (Onkyo); Simplink (LG); HDAVI Control, EZ-Sync, and VIERA Link (Panasonic); EasyLink (Philips); and NetCommand for HDMI (Mitsubishi)
All I ever hear about CEC are complaints on the order of "what the hell is this?"
-Bill
post #19033 of 38733
Originally Posted by kingfats View Post
Channel Downmix set to 7.1? been reported here as well.
thought it only had to do with analogs with the downmix thing?
jimi
post #19034 of 38733
As has been stated several times before, it's not a simple thing at all. It's also not high on the list of priorities. If it were a simple thing it would have been done. The bit meter is showing the rate of the compressed and combined data as it comes off the media. A split meter would come from a different place, and it's not clear whether this is possible in this machine. Talk to Oppo directly about this if you want more information rather than sniping about it here.
post #19035 of 38733
well email oppo like i did. in fact i will probably email them again at some point about it. all they need to do is make it a double push on the info button, just like the pioneer 51 does. with the 51 you only get the bit rate meters if you push the button twice. it defeats oppos excuse that they "tried to make the info screen unobtrusive"..whatever, just make it a double push then anyone that wants to leave it on the screen with one push can do so and anyone that wants more info can push it twice.
post #19036 of 38733
Be aware that when listening to any source at 96 khz sampling or higher that if played through an Audyessy enabled receiver the Audyessy does not function properly as it also runs its' software at 96KHZ. Oppo is aware of this issue but not really their problem.
post #19037 of 38733
-Bill
I did see the wikipedia article, but I still don't know for sure and there is very little information on what exactly is implemented by RIHD and how much of that is supported in OPPO's implementation of CEC.
According to the manual:
The implementation and compatibility of
this feature varies by device manufacturer. Each may only implement part of the features or add
their own proprietary functions. The manufacturer-specific implementation of the HDMI CEC
function is often given a proprietary name of “…Link” or “…Sync”. The OPPO BDP-83 Blu-ray Disc
Player provides three modes for the HDMI CEC function:
• On – HDMI CEC is enabled. Use this mode if your other devices are compatible with the
player.
• Limited – HDMI CEC is enabled but the BDP-83 will only respond to playback control
commands. It will not respond or issue power on/off and input selection commands. Use
this mode if you do not want the automatic setup function to turn on/off your devices.
• Off – HDMI CEC feature is turned off. The player will not respond to HDMI CEC
commands from other devices, nor will it setup other devices automatically.
This still doesn't tell me much.
Basically, I'm looking to upgrade my receiver from a late 90's Yamaha rx-v995. I want to put everything in the closet so I'm trying to see if some of these types of features help me do that. Its a pita to pick receivers these days with so many features and not one of them having everything you need. One of the items I thought about not putting in the closet for convenience was the 83. So, this made me wonder if I had the 83 in the room connected via HDMI to my receiver in the closet I might get enough automation from this CEC/IRHD or whatever you want to call it.
Alternatively, I can do serial, Harmony 900 or IR target and distribution....
If someone has done extensive testing using CEC on the 83 with an Onkyo or Integra unit let me know. I'm leaning towards the Integra 30.1 at the moment.
post #19038 of 38733
Hi Roger,
Thanks much for that info. I found this post saying >>all modes outside of source/pure direct are programmed by Dolby/DTS and it's their algorithm that determines the sound in those modes.<< Now that I see the details, I can assure y'all, it's false, just as I said. Marantz is passing the buck. Neither Dolby nor DTS have any say over what happens in any modes but their own. If there's more info on the nature of these "algorithms" I'd be pleased to know.
post #19039 of 38733
CEC is a standard and all these manufacturers' implementations of it conform to that. If you are using a Harmony (or any other universal), you'll probably want to turn all the HDMI control off anyway; universal remotes allow for much better control than CEC does.
post #19040 of 38733
This is not true. The limitation on what processes can be accomplished and at what data rates is the DSP capacity of the receiver. Some run out of steam before 96kHz (e.g., Marantz), some handle 96kHz but not more (e.g., Integra/Onkyo), and some will handle it at 192kHz(e.g., the top Denon prepro).
It is not a limitation of Audyssey.
post #19041 of 38733
FWIW I don't think that is a true statement if taken literally. From my research so far I understand that while CEC is a standard no manufacturer is required to implement 100% of it or limit their implementation of it to only what is in the standard.
If you know OPPO has implemented CEC to 100% of the standard let me know.
post #19042 of 38733
[quote=Kal Rubinson;16984570]This is not true. The limitation on what processes can be accomplished and at what data rates is the DSP capacity of the receiver. Some run out of steam before 96kHz (e.g., Marantz), some handle 96kHz but not more (e.g., Integra/Onkyo), and some will handle it at 192kHz(e.g., the top Denon prepro).
Let's not forget the Anthem D2v.
John
post #19043 of 38733
FWIW I don't think that is a true statement. From my research so far I understand that while CEC is a standard no manufacturer is required to implement 100% of it or limit their implementation of it to only what is in the standard.
My understanding is that there is a basic set of functions that they all implement; this includes things like power and input control and basic transport controls. It does not convey all components' IR commands to one other as, say, an IR repeater system does. In my experience, it's a pretty crude system that may have been useful about ten years ago, when you had to buy everything from one manufacturer to get components to play nice together. But now, universal remotes have made the CEC system pretty obsolete. Any receiver you buy these days will probably include a remote that can control the Oppo or any other BD player you choose.
post #19044 of 38733
I am using Denon 4308, and my setup is like this:
Oppo --HDMI --> Denon 4308 --HDMI--> Panasonic 50" Plasma
(all three with the most updated firmware)
1080/24P is okay, no matter BD or DVD.
Please make sure you choose A to H only at HDMI option of the Denon AMP, don't choose the option with H to H, which will process the video by the Denon.
Hope this helps.
post #19045 of 38733
I was listening to some SACD's tonight that were multi-channel. Here is a question I have. My system is all HDMI 1.3, BDP-83>Denon AVR-3808CI>Panasonic 800U plasma. When I'm listening to multi-ch SACD's my AVR displays multi-ch, as soon as I turn off my plasma I loose multi-ch on my AVR and it goes to Dolby PLII Music. DSD is still lit on my AVR though. What is the cause of this. Is it from HDMI connections?
post #19046 of 38733
[quote=jayray;16984692]
John
And in what category does it fit? I was only giving an example for each, not trying to be exhaustive.
post #19047 of 38733
I just took the plunge and ordered this player. Should have it friday. I read the first page with all the firmwares, official, public beta and what not. And so without reading through all the other 635 pages of this thread, which seems to be the best and most stable firmware to put on when I receive my player?
post #19048 of 38733
Again, there is nothing that says anyone has to implement any of it. You can be HDMI 1.3 compliant with zero CEC.
I think the issue of not having a standard across all manufacturers on what must be implemented and how to do it for compatibility is what makes it appear crude to you. I just read the tech docs on how it works and it's anything but crude. It more feature rich than any IR code due to it's topology.
After reading the specs and white papers I seriously doubt CEC will go anywhere across manufacturers. I doubt many manufacturers will even implement it across more than one of their products using their own CEC devices.
post #19049 of 38733
Let's not forget the lowly Yamaha AVRs, which all use 24/192 DACs and DSP. No need to spend a bundle for 24/192 processing.
post #19050 of 38733
I have all HDMI 83->Denon2809-> sammie LCDTV and when I just tried that, all that happened was it blanked the audio for a few seconds. I do notice that once in a while when I start an SACD disc the Denon does not show MULTI CH IN. I simply switch the Denon to a different input (ex: TV) and back, which fixes it. Try it and see if that works for you. Yes I would attribute these oddities to HDMI secret handshake.
BTW, does sending DSD sound different to you than PCM? (I assume from your statement you're listening in MULT CH IN & do not use the DSD Direct mode.)
