Originally Posted by Mactavish
PASTED FROM REVIEW:
"Sound quality improved when the supplied HDMI cable was replaced (surprising because the supplied cables worked so well with previous Oppos) and improved again when HDMI was bypassed and coaxial digital (where applicable) or the multi-channel analogue connections were used. The bottom end gained in impact and pace, the brightness was reduced. The sound was sweeter, more engaging and importantly, some of the lost goosebump factor was restored."
Can an HDMI cable affect the audio "sound quality" as described by this reviewer?
PASTED FROM REVIEW:
I'm not sure what the review meant by the flowery language he used, but based off the review that secrets did (http://www.hometheaterhifi.com/blu-r...ay-player.html), there are definite gain or level differences between the the HDMI and analog outputs coming out of the Oppo. These level differences, if not calibrated out at the AVR level, can give the impression that one output is better than the other(see attachments), notably that the higher gain outputs(analog) sound better than the digital outputs. To complicate things further, there are level differences within a given output depending on its encoding and sampling rate! Why Oppo did this isn't clear to me but it is what it is
At the end of the day, as long as you enjoy what you hear is what counts
Yes, I fully agree that the BDP-83 should not be impacted by any changes in the speaker setup when using optical and re-encoding the audio tracks with secondary audio set to "on", and was skeptical to this result myself. The main reason I suggested it was due to the ambiguous reply I initially received from Oppo, suggesting that the subwoofer had to be set to "on".
), I've never done an A/B test between the various codecs. I simply plugged in the BD and enjoyed myself. Also, since my entire BD collection can be counted on one hand so I can't say I have compared a level differences between BD and DVD audio. Again, I waive a chicken over my head and relax to enjoy the sound
