Originally Posted by Drag0nFly
What exactly do you mean with "sobing like disturbs"? Clipping? I've tested the re-encoded PCM 5.1 soundtrack from Kill Bill 1 and it sounds quite stratospheric actually. However, there are output level differences between the original and re-encoded DTS tracks, however, the DTS track is always lower on my setup.
btw., did you encounter problems with titles other than the Warner-released Kubrick titles that I listed? I have so far not seen it on other discs, but suspect the problem might be related to titles which does not have SAP.
I intend that during the reproduction ( either the music at the start of Kill Bill 1 ..) there are clipping and "blouuugh ...polp ...criiiss... blooop" like sound over it ...
Do you know the effect when you play an Audio disc that is ruined and drops even with the works of the player error correction routine ??
Edit:
Wish to add...
This trick/bug, could be useful if it should works in all releases where is there an uncompressed multichannel PCM ... but it works only on few titles...
For example:
There are some releases ( e.i. Sleepy Hollow and Dei Hard 3, by Cecchi Gori Home Video distribution ) that have only the PCM 5.1 uncompressed track and no one lossy track like DTS or DD.
This kind of releases in layout with a Player without analogic outs ( like PS3) and AVR without Hdmi input force you to listen at it in PCM Stereo only !!!
