AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-83 Owner's Thread [technical talk only]
Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 77
post #2281 of 38775
Originally Posted by Neuromancer View Post
Unless something is dangerously wrong with the disc, you can bit stream 5.1 24-bit/192KHz DTS-HD Master. The BDP-83 will decode at 24-bit/96KHz; PS3 does 192KHz (but can't confirm if this is an oversample).
Could'nt 5.1 24-bit 192KHz DTS-HD MA be a firmware update? Are all 5.1 DTS-HD MA 192KHz?
post #2282 of 38775
Originally Posted by Bob Pariseau View Post
You can easily put the Oppo on your Wi-Fi network by attaching it to a Wi-Fi access point device.
For example, I use an Apple Airport Express to put my Oppo on my Apple Airport Wi-Fi network. The ethernet cable from the Oppo plugs into the Airport Express. The Wi-Fi configuration is done in the Airport Express (using a Mac utility provided by Apple). As far as the Oppo knows, it thinks it is directly connected to my internet router.
There are similar gadgets from other vendors commonly used in the Windows Wi-Fi world. Check the usual suspects in the networking world -- e.g., Linksys.
As I recall, this topic is also covered in the FAQ -- see the big fat link at the start of the first post of this thread.
--Bob
At risk of diverting this far beyond off topic, I just wanted to add that I couldn't get my airport express to act as a bridge to an existing WPA encrypted network--only WEP. Might have been my incompetence, but might be a restriction of the product--something to look into if that concerns you (not someone "hacking" your OPPO, more that you would have to lower your encryption or create a separate WEP network).
post #2283 of 38775
Actually, pretty much none of them are, with maybe a few exceptions.
post #2284 of 38775
I'm using WPA2 security with my Airport Express and the Oppo. No problems. The Airport Express is talking to an Apple Airport Extreme base station.
Your issue could still have been a bug of course.
--Bob
post #2285 of 38775
--Bob
I'm also running the same setup (Apple Airport Extreme/Airport Express) with no issues with the Oppo BDP-83 with WPA2 security using 5.4.1 software.
post #2286 of 38775
Originally Posted by Robert Cook View Post
Perhaps, but according to the DTS-HD White Paper, the following is true of the Master Audio stream:
* Up to 7.1 discrete channels with a sampling frequency of 96 kHz and 24 bits of signal resolution
* Up to 192 kHz sampling frequency and 24 bits of signal resolution for 2.0 channels
Unless this paper is outdated or DTS is strangely under-representing the capabilities of their format, DTS-HD Master Audio does not support 192 kHz sampling for multi-channel (i.e. more than 2.0) audio in the first place.
Indeed, the DTS white paper you referenced confirms the numbers you give. I looked on the DTS website and a brochure for DTS HD essentially reports the same thing. I have an article from a well known & respected AV e-zine that mentions multichannel at 192/24. Hmm... (More to follow, read my next post.)
As for Dolby TrueHD (from their website):
http://www.dolby.com/consumer/technology/trueHD.html
- Supports up to eight full-range channels of 24-bit/96 kHz audio
- Supports up to 5.1 channels of 24-bit/192 kHz audio
post #2287 of 38775
Originally Posted by sasser204 View Post
Just purchased a Pioneer elite Kuro and love it. I need a blue ray player. I have an oppo dvd player and love it. I understand the pioneer bd51 and bd05 to be good units.. Is the kuro link worth anything? Should I wait for the new pioneer units to be released or wait for the OPPO bdp-83.. any advice would be very helpful.. thanks in advance. sorry for so many questions
Kuro Link was just what Pioneer called HDMI-CEC for a short period of time. They've corrected themselves and now call it by the standard name. The Oppo does support HDMI-Control.
Get the Oppo.
post #2288 of 38775
Look at the specs listed for the TrondheimSolistene Divertimenti Blu-ray, on the last page (10) of the pdf.
http://www.2l.no/files/2L50SABD_eBook.pdf
Linear PCM STEREO + 5.1 surround 24 BIT / 192 kHz
DTS-HD Master Audio 5.1 surround 24 BIT / 192 kHz
Dolby TrueHD 5.1 surround 24 BIT / 192 kHz
The numbers for DTS-HD MA somewhat contradict the DTS-HD White Paper mentioned in the previous posts.
post #2289 of 38775
Originally Posted by fitzcaraldo215 View Post
I hear no loss of transparency at all with Audyssey. In fact I hear the opposite. The signal is already in the digital domain as it goes through the processors's DSP, where Audyssey resides. All Audyssey is doing is math on the signal. There is no reason for it to degrade the signal unless the math itself is not properly programmed, but it is, in fact, properly programmed. It's not at all like putting the signal through additional analog or conversion stages, which might introduce distortion and/or noise. Bits is bits inside the processor. That may not be true during digital transmission from the player, such as HDMI, because of jitter. But, I think jitter is mostly under control these days, anyway.
I can't speak for Audyssey as I don't have it in my current AVR but I plan to have this feature in my next AVP or AVR. However, I've listened to the Lyngdorf Audio RoomPerfect digital room correction system which is similar in form and function. I too feel that it opens up the sound and reveals layers that get smothered by the room modes. In my book, it's an advantageous trade off.
post #2290 of 38775
Yes, the DTS-HD White Paper is old (2007) and incorrect. Newer info from DTS, like the brochure on their "Master Audio Suite" (to create the content) gives the correct numbers (which are the same as for Dolby True-HD):
- Supports up to 7.1 channels of 24-bit/96 kHz audio
I guess the mixup can also come from the disc formats. DTS-HD Master Audio could in itself be used for more channels/higher frequencies, but the disc formats can't support it. Blu-ray can support 5.1 channels of 24/192, while HD-DVD did only have the transfer rate for 2 channels of 24/192.
post #2291 of 38775
Sorry I'm only on page 43, also this is OT...
What is DVD Ringing?
post #2292 of 38775
Originally Posted by abba1 View Post
Question for you EAP's...are the detail and enhancement adjustments worth tweaking? Or is the PQ good enough without the ''fine tuning?''
It depends on how much you want to tweak, and what is good enough. The controls are pretty fine-grained and you can move them alot without messing up the image. They also perform similar but not identical functions and you can move them independently.
Blu-ray looks ok to me at 0,0, but DVD needs small negative values, which do not seem to harm the Blu-ray image. I've never found the positive range to be of use.
See the FAQ: What are the recommended Edge and Detail Enhancement and Noise Reduction settings?
-Bill
post #2293 of 38775
Originally Posted by peka j. View Post
Thanks Neuromancer. The Wi-Fi in particular is something I am interested in. Unlike for some here apparently, it is not convenient for me to run a network cable from my router to my A/V rack. I rent, don't own, and running cables through walls is not an option.
I use the Buffalo wireless ethernet converter. It has 4 ports to connect your components to. If you pair it with their wireless router/AP it uses a proprietary method to double the speed of normal 11g. It made a big difference in the network performance of my PS3, plus I don't have to worry where I place the console in my rack. Streaming FLAC and video is smooth and clean.
post #2294 of 38775
It is the white halo you see around lines and edges in the image. It is partly caused by too much compression when the title is mastered, but also is sometimes added intentionally by the studio as an an attempt at edge enhancement: making the image "sharper".
Sharpening controls on a display or player can also add it.
-Bill
post #2295 of 38775
I'm keeping a list of wireless adapters known to work on the BDP-83 here: Does the player have built-in wireless networking?
No, but ethernet-to-wireless adapters have been used successfully, for example:
* Apple Airport Express
* Belkin F5D7330 802.11g Wireless Ethernet/Gaming Adapter
* Linksys WGA600N
* (others? Send me your comments).
Send me any others that have been tested and I'll add them.
-Bill
post #2296 of 38775
-Bill
Thanks Bill...
post #2297 of 38775
If you connect an analog cable to the Front Left and Right (either dedicated or Multi-channel) do you hear audio from the player?
Is your Volume set to 100 when you press the Volume + button?
If you connect the DVD player direct to your television, do you get audio coming out of your television's speakers?
I have analog cables hooked up to the dedicated stereo outputs and they are fed to the 'CD' input of my receiver. All discs thus far have worked. I haven't tried with the disc in question though.
Volume was up higher than normal to try and see if voices were just faint.
I can't just plug the Oppo into my TV to see if there is sound as my TV is not HDMI, it just has a single DVI input. It's an older HDTV that was first on my list to be upgraded, but the Oppo stole all the $$ I had saved up for the TV
post #2298 of 38775
He is thinking the RCA L R on the TV audio.
post #2299 of 38775
Originally Posted by Mike_G View Post
Unless you're actually trying to stream HD video power line (http://www.netgear.com/Products/Powe...s/HDXB101.aspx) and a cheap desktop switch work well for me.
It looks like Netgear has some other products coming that might help:
http://www.netgear.com/Products/Powe...king/Coax.aspx
http://www.netgear.com/Products/Powe.../XAVB1004.aspx
Mike
I have always wondered if any of these products that use the electrical wiring in your home result in any "electrical noise" that could effect the audio/video quality of our AV setups? Many companies are in the business of providing power filters and cleaners; do you think these devices might make things worse?
post #2300 of 38775
While the Lyngdorf and Audessy are trying to solve the same problem (room/speaker interaction), they do not do it at all alike. While (the built-in) Audessy is a great solution at low incremental cost, it is nowhere near as effective as the Lyngdorf and does not provide the same quality improvement (but then again the incremental cost of Audessy is a SMALL fraction of the Lyngdorf)
post #2301 of 38775
Oppo Europe's website now says "coming soon". Does that mean that the European version of BDP-83 will be released for sure?
post #2302 of 38775
5.4.1 is the latest version of Airport Utility software. 7.4.1 is the latest version of the firmware (released last week) for the "N" version of the Apple Airport Extreme/Airport Express.
Just like iTunes, Safari & Quicktime, Apple has a version of Airport Utility available for Windows.
Now back to the real/main topic.
post #2303 of 38775
Please contact them and ask them. If they give you any definite information, post it here and I'll add it to the FAQ.
-Bill
post #2304 of 38775
It has been saying that for a very long time...
post #2305 of 38775
Originally Posted by narkspud View Post
For one thing, when forcing the "math" to fit into a specific bit depth and sampling rate, you will invariably induce rounding errors.
I understand that there are also issues with phase shifting, but here I am treading on shaky ground knowledge-wise, so someone more well-versed at the technical stuff than I will need to take it from here.
Yes it is a bit of a trade-off. Some of it can be ameliorated by upsampling so round-off errors are pushed out to inaudibility. But the effects in a room are really gross compared to tiny errors in the digital domain which are at the edge of audibility at worst.
Room correction is really a good thing. Add some room treatments to help it out and it turns into a great thing.
post #2306 of 38775
I'm looking forward to resolving these audio issues with the new Oppo 83, with its improved audio circuitry. Hopefully.
Regarding the discussion of Audyssey and Lyngdorf and their effects on the audio quality, here's another interesting effect of the built-in Audyssey system. - Using the Oppo 980 and an NAD with Audyssey, there is a substantial attenuation of volume levels at normal volume settings when using Audyssey. For some sources, the volume control on my NAD pre/pro, which has a range of 0 to 100, must be set all the way up to about 97 or 98 (-2 or - 3 from maximum) to provide what I consider normal listening levels. And this is very unusual for my speakers/amps, etc. When using a legacy preamp, for example, I normally set the volume at perhaps 20% of the maximum range. Whether or not this would affect audio quality, it has been my understanding that it's generally preferred to set trim levels such that your average volume settings would fall somewhere near or below the middle of the range, and that you seldom have to crank it up much beyond that middle range. I'll look forward to checking all this out with the new 83 player.
Jim
post #2307 of 38775
Jim, Audyssey tries to set a reference level of 75dB at the 0dB level of your volume, or at least it does so in my Denon. Perhaps it works somewhat differently in your NAD???
post #2308 of 38775
Has anyone found a "bug" that could NOT be fixed by future firmware updates?
post #2309 of 38775
Well, that's exactly what this data signal appears as: "noise". So it does get filtered out by any filter or surge-suppressor, which is why the powerline networking adapter needs to be plugged directly into the wall and not into a surge/UPS.
post #2310 of 38775
How would we know? You know, crystal balls just aren't that reliable.
