Originally Posted by Smarty-pants
I'm a bit stumped from the info you've given.
Is there any type of setting in the processor to turn off audio output/passthough for the hdmi out?
You don't want audio going out to your projector, as that may trigger a handshake forcing stereo audio.
You could also try a different hdmi input on the processor to see if anything changes.
Also, you could try contacting the maker of your processor for further troubleshooting.
For each input in prepro setup I can choose analog, digital, and video. In the analog selections I can't choose off/none...have to select something. I set analog to 1...as if it matters...there is no current analog connected. I then set audio digital to hdmi and video off. I get 2ch or dsp's like prologic, etc. I am just going to use what I had. When I press 'watch dvd' on my remote(harmony) it will switch to dvd input and the 7.1 as signal source. When I press listen to cd on remote it will switch to cd input and use the hdmi as signal transfer. I'm over it. Until I upgrade this will do. Pissed.
