AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-83 Owner's Thread [technical talk only]
Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 1061
post #31801 of 38733
Originally Posted by tngiloy View Post
In the Oppo set-up there are a few choices for Deep Color settings.
My Panasonic plasma(th50pz-800u) does have deep color capability, but I'm not sure which setting in the Oppo would be best.
Is there a technical spec in the Panny manual that would let me know what to set the Oppo to?
Are there any BR discs that use deep color?
Tom
There are no Blu ray or DVD discs using deep color. The HDMI standards group is great about preaching about future standards that never happen. You will notice a little less banding if you enable 30 bit or 36 bit deep color on the BDP-83 usually. I would simply try all the settings and see what looks best being that your display supports deep color.
post #31802 of 38733
Originally Posted by trevor-b View Post
... The SE might be a tad over my budget, unfortunately
With this player, that is not a problem. You would be able to have it upgraded by simply sending it back to Oppo at a future time when cash is more available.
post #31803 of 38733
Originally Posted by MattS74 View Post
Anyone else have playback issues? I can skip through the trailers but once the top menu hits, nothing. Firmware?
yes, that is a classic symptom of needing a firmware update... get the current public update for May 5th, and be sure to do the factory reset and persistent storage clearing afterwards. Before you do the reset, make a note of any of your current menu settings you've made that are different from the Defaults, so you can easily re-enter them afterwards.
post #31804 of 38733
Maybe:
Upgrade option available while supplies last. We may stop this offer at any time without notice.
post #31805 of 38733
Hi there.
I have bought a Panasonic TX-P42G20 plasma TV european model ( I live in Norway)
Will the OPPO BDP-83 and my new TV work excellent together or be a mismatch?
Fanitullen
post #31806 of 38733
I just got a surprising notice from Overture Audio/Video in Wilmington Del. saying they are now carrying the Oppo line. This is a typical high end, high markup boutique that has started to carry a few lower priced lines. It seems to signal a change in marketing strategy for Oppo in the US. This is very different from reselling through Audio Advisor, primarily an internet retailler.
This can certainly help Oppo gain the legitimacy it deserves from high end buyers. That's good. I also like it because it will likely put an HDMI-capable, SACD-compatible machine in their Mch HT demo rooms. Surprisingly, many dealers have not had one available to them. Blu-ray, yes, but SACD, no, at least not with HDMI. That, in turn, might give more music linteners access to demos of Mch SACD, which I happen to think is about the best msic reproduction there is.
The fear is that this might signal a shift for Oppo away from their direct internet sales model. This has helped all of us get a great product at a staggeringly low price, without typical retailler markup. The retaillers are probably content for now carrying it as a low margin "loss leader" to attract customers. But, I am sure they will be sweet talking Oppo into higher prices with higher margins for the dealers. That could be bad.
I sure hope I am wrong about what this signifies. Time will tell.
post #31807 of 38733
it's certainly a change in strategy for overture... that wasn't a very "consumer friendly" place in the past...
post #31808 of 38733
could it mean we might see OPPO show up in dare I say BB?
post #31809 of 38733
If anything you will see something along the lines of Denon and their CI line of products. Denon created slightly modified receivers and DVD players with "CI" tags. These products sold at a higher and were exclusively available through custom installers and integrators. To the standard user, they continued to by Denon as normal.
OPPO would never go to one extreme or the other.
post #31810 of 38733
Originally Posted by Fanitullen View Post
Hi there.
Fanitullen
The Oppo will work fine with your TV. It is designed to handle European and American video standards. There will be two issues, one minor and the other a little more significant.
For the minor one, you will have to buy the appropriate aftermarket power cord to connect to your native electrical outlet since the Oppo ships with one designed for North American plugs. The connector on the Oppo is standard, so you should have no trouble finding a compatible cable.
The more serious issue is that the Oppo is set up and locked for Region 1 DVD and Zone A Blu-Ray. It will play Region 0 DVDs and non-zone-coded Blu-Ray discs fine but you will not be able to play every disc you may acquire in Norway. There are aftermarket modification kits that make the Oppo region-free for both DVD and Blu-Ray but installing one will void your warranty, so you will take some risks there. The best region-free kit comes from nearby to you Denmark, by the way. Firmware upgrades will work fine with the modded player though.
The Oppo is not officially sold in Europe but I believe there are dealers there who purchase in North America and modify the players. They may have their own warranties but it will not be directly from Oppo.
post #31811 of 38733
For that small group of us with lagging audio problems, I finally gave up and sent off an email to OPPO. They responded very quickly, but unfortunately it's not something they can address in an update--and I'll just accept that they know what they're talking about.
Dear sirs,
Would you kindly consider enhancing the current sync control so that it's possible to have negative values? The current mechanism can be used to correct situations where the video lags behind the audio, but not vice versa.
For reasons I still haven't identified, all media from my OPPO has delayed audio, in the order of 2 to 3 frames. Most people cannot discern this type of error, but I am particularly sensitive to it through years of video editing and subtitling. It's very possible that my receiver is introducing the delay, but like the OPPO, it has no solution for lagging audio--only lagging video.
A more complete audio sync control in a future update would be wonderful.
* * * OPPO * * *
Unfortunately there is no way to delay the video in order to compensate for downstream audio delays which cause the video to become faster than the audio. This is limitation of the decoder not having a dedicated video buffer and the ABT VRS not being designed with an adjustable video buffer.
post #31812 of 38733
I hate to be negative, but I really could care less what "High End" buyers think of the Oppo, or its pricetag. Let them spend money hand over fist for sometimes dubious reasons. (Often I think it is for no other reason than to impress their friends and themselves) It's a fantastic machine with first-class customer service. I like where the company stands at this point & I hope their basic principles stay the same.
post #31813 of 38733
I could care less myself, but Oppo or any manufacturer cannot have one price for direct internet sales and antother for retail sales. That is just unworkable. It's not an issue for the BDP-83. That price will likely not change much and it will be the same no matter where you buy it. My concern is about future products if they give emphasis to the retailers, who will want a higher price with a more typical (high) margin. We will then all pay that. I am much happier with them being a maverick internet sales company. That's pretty much why we are all here.
post #31814 of 38733
I have an issue when playing Patton on BR disc. e.g. picture only shows up in the top left corner of the HDTV. Did this after I installed the latest FW>
post #31815 of 38733
Per the fw instructions, did you reset the player to factory default settings, then reconfigure the settings taylored to your own setup?
Try also clearing persistent storage before doing a reset.
post #31816 of 38733
Yes ..I forgot to add...that I did contact Oppo and they stated that this was a known issue and would be corrected via a future FW upgrade.
post #31817 of 38733
yes ..i forgot to add...that i did contact oppo and they stated that this was a known issue and would be corrected via a future fw upgrade.
DOH!!!!!
o
post #31818 of 38733
Hi there.
Fanitullen
Hello to Norway, my favourite country
I have exactly the same combination and I have to say P42G20 is excelent TV for OPPO, probably the best for its price. I have 42" too, and I'm really very happy with it, but if I had enough money I would buy 46" or maybe 50".
You have to use THX video profile with Oppo, it gives the best picture. And switch off any energy saving and eco mode for best picture.
post #31819 of 38733
Thanks to JazzGuyy:
It`s good to hear that this combination will work well.
I have planned to by one with a hardware modification kit.
and thanks to noaid: it`s my favourite country too you see.
IMO one of the proffessional settings gives more options to get a better picture.
Otherwise I agree with you.
Fanitullen
post #31820 of 38733
DOH!!!!!
o
what does doh mean and I posted this to see if any body else was having this issue with the patton blu-ray disc. thanks , george H.
post #31821 of 38733
You had stated that OPPO confirmed it to be a known issue, and that it would be fixed. Thus, there was no real reason to ask the question in the first place. A real life "DOH!!!" moment if you will.
...and the word "doh" would ironically infer to a saying from The Simpsons TV show, a phrase coined by Homer Simpson.
post #31822 of 38733
again, my intention was to see if others had the same problem.
post #31823 of 38733
In case it matters, I found your use of "doh" amusing given homer612's user name .
If Oppo has confirmed that it's a known issue, then other users will definitely experience the issue sooner or later (unless Oppo gets a firmware update out before other people run into the same situation).
post #31824 of 38733
That's a given, if Oppo has known about this issue other's must be having the problem you are having, how else would Oppo know about it? Oppo can't buy every disc and play it just to find problems, owner's email or phone in the problem. The answer to your question is obvious ...
post #31825 of 38733
Originally Posted by r-gordon-7 View Post
OK, here's some nitpicking about FWD, REV & subtitles (on both BD and standard DVD discs) on both of my two Oppo BDP-83 machines:
1. The Oppos' FWD & REV functions seem especially "choppy" compared to the comparable FWD & REV functions on my prior DVD players. On my prior DVD players, the image motion in FWD & REV modes was relatively smooth (or, at least noticeably "smoother" than on my Oppos). On the Oppos, FWD & REV are more like a sequence of successive still frame shots that jump from one to the next, rather than a relatively smoothly flowing moving image that is simply speeded up or slowed down. This relative "choppiness" on the Oppos is especially the case at the faster and slower speed extremes, though is also the case even at speeds closer to normal play speed.
(BTW, on both of my Oppo BDP-83 machines I have the newest publicly released firmware and I connect each Oppo directly to a plasma TV via HDMI.)
Originally Posted by sbjork View Post
Not a deal breaker, but the Oppo does only have "smooth" FWD/REW on the first two speeds -- after that, it "skips" as you describe. It has done that for me since the day I got my player (and I was an early adopter) through every firmware revision. But it is something that I do not use all that much, so it really is a minor issue for me. The only related problem that I have encountered with forwarding at higher speeds is that sometimes when I am forwarding at 3x, 4x, or 5x, and press Play, instead of resuming play at that point, it skips to the beginning of the next chapter. That far more irritating.
New Oppo owner here (sprung for the 83SE version).
What really surprised me is how awful FF/RW performs on DVD's. Even at the fastest FF speed (5), which as mentioned above is VERY choppy, it's only fast forwarding in 10 Second jumps! So it's choppy AND very slow at even the fastest FF speed.
Why is this? On Blu ray discs the FF is much faster, and all my previous DVD players FF DVD discs quickly w/o issue. For this player to only FF in 10 second jumps at the fastest speed seems a bit odd/strange and finally--annoying.
I hope this is something that can be addressed in firmware
And yes, I've already experienced the '...sometimes when I am forwarding at 3x, 4x, or 5x, and press Play, instead of resuming play at that point, it skips to the beginning of the next chapter.'
post #31826 of 38733
Decided to time it: At the fastest FF speed (5), with DVD's, it takes about 6 seconds (real time) to FF 1 minute of disc time
So if one was to FF at speed 5, it would take about 12 minutes of real time to FF a 2hr movie from beginning to end. I think any of my previous DVD players would do that in way less than 1 minute.
post #31827 of 38733
fleaman,
1st congrats on the purchase of the SE. 2nd why were you surprised about the functionality of FF/RW when you sited two other postings regarding this functionality. The functionality of the Oppo FF/RW may not be as refined as your previous DVD, but then it is not a DVD player. The speed at which the Oppo FF and RW seem to be an annoyance for you and a few others, but I can't imagine you needing to fast forward no more than a few seconds or minutes within a specific chapter. If you are FF from chapter to chapter looking for a specific point in the movie wouldn't the Next button on the remote be more appropriate and FF once you are within the chapter you desire?
I know there is a need to occasionally FF/RW within a movie, but how often does this take place? I thought the point was to watch the movie.
Your desire to have this addressed via firmware may go unnoticed. The functionality of FF/RW would have to be very, very, very low or non-existent on the priority list for Oppo. I guess for a huge majority of the owner base this is a non-issue.
So I guess you have to decide if this is going to materially affect your enjoyment of the player or a big enough issue to warrant returning the player.
I personally think the player is a keeper if this is all that annoy's those few times where you may have to FF or RW.
Just my $.02.
Respectfully,
Willie
post #31828 of 38733
Tom
My Mitsubishi TV also supports deep Color,
but there is no word in the manual about 30
or 36 bits. Their support (a misnomer, if I
ever saw one) were stumped as well.
Searching the web it appears that there are
no titles using the technology -- BD or DVD.
I wound up setting the BDP-83 to 36 bits. I
am not sure it did any good, but it did no
harm, either.
-- Ron
post #31829 of 38733
[....] Oppo or any manufacturer cannot have one price for direct internet sales and antother for retail sales. [...]
Why not? That's a fairly common phenomemon.
Right now, the BDP-83 is sold by many mail order
retailers for $600 and higher. There is at least one
(very visible) ebay seller that charges $700 for
modified BDP-83s. Since the mod costs about 60
bucks, it is not difficult to calculate their markup...
BTW, since this seller is not an authorized dealer,
they offer their own 30 day warranty -- but only
if the buyer makes an issue of it before the sale.
Buyers' risk is probably not high, but still, it's not
zero, either.
aree
-- Ron
post #31830 of 38733
Originally Posted by bakerwi View Post
fleaman,
I discovered those posts after the fact.
Well, the DVD playback PQ (in my case, upscaling to 1080p) is one of the main reasons to purchase the Oppo, right? One of the reasons I went for the Oppo was to eliminate all my other DVD players, not have multiple players that each have a specialty performance advantage.
Well, in the case of the BD83, it is indeed 'only' FF a few seconds at a time, even at it's fastest speed.
If you are FF from chapter to chapter looking for a specific point in the movie wouldn’t the “Next” button on the remote be more appropriate and FF once you are within the chapter you desire?
Yes, if I knew which chapter the scene I was looking for was in. But if I don't, I'm back to square one.
I guess that's gonna be the case now. Yet for demo purposes (calibration checks, etc.) or favorite scenes, I like to go to the scene quickly of course. But now, if I don't know the exact chapter it's in, that will be an extensive process.
Yet the Oppo doesn't seem to have much of a problem with fast FF/RW on blu ray discs. Doesn't it seem strange and odd that DVD discs handicap this player so much? (with this function).
