AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-83 Owner's Thread [technical talk only]
Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 1211
post #36301 of 38733
Originally Posted by dr150 View Post
I have and Xbox360 and PS3. ...
The pink screen only occurs when I switch from the Oppo to the Directv Tuner. By that logic, it seems the culprit is the Oppo to Panny TV HDMI handshake. Correct?
No. If you have an DTV xx24 it's RGB, the older ones are YCC. It may help to put the Oppo in RGB-CE (video) or you can sort out a better albeit more complex solution.
post #36302 of 38733
Once you switch Sources, a new handshake has to begin. That handshake, from end to end, is driven by the newly selected Source device.
Evidently your set top box is making incorrect assumptions about how the AVR is set when the AVR is switched from the Oppo to the set top box. Or the set top box is not following the protocol to get the AVR to switch gears. The problem is most likely in the set top box, although it is possible it is a combination of problems in the set top box and the AVR.
The one place the problem CAN'T be in this scenario is in the Oppo. The nature of the HDMI handshake is that things are supposed to start over, without making assumptions as to what has gone before. NO MATTER HOW the Oppo has left things, the new handshake is supposed to reset things the way they need to be NOW.
--Bob
post #36303 of 38733
Well, turned on my 83 to watch a movie tonight and hit the eject button...and nothing. Hit it three or four times, still nothing. Remembered the problems people have had with the tray, hit eject on the remote and it opened. I put the disc in, closed it with the button on the player and it closed and opened up a few moments later with the disc still spinning a bit.
Closed it again and watched the movie. The button on the player worked to eject the disc (power was never off). I opened and closed it another half-dozen times just fine and turned the player off. Tried again about an hour later just for the heck of it, and it still opened and closed fine.
Is this probably a sign of the tray failure that people have experienced? I was cleaning the outside of the player (including the outside of the tray) and hadn't turned it on since...so maybe it's wishful thinking that it was a fluke? Time will tell, I suppose.
post #36304 of 38733
That sounds more like a problem with the firmware sensing the button push on the front panel. If it goes away after a power cycle it is likely just a one time fluke -- nothing to worry about.
--Bob
post #36305 of 38733
Hope so! Thanks, Bob.
post #36306 of 38733
Is there anyway to show mp3 files on the OPPO 83 front panel?
I would like to view file names without turning on the TV.
It appears that the only way to select folders on a mp3 disk is to have the tv on.
post #36307 of 38733
You need a display. Some folks use a small (7 or 10 inch) LCD display attached to the player's composite video output for this. The Haier models are popular.
--Bob
post #36308 of 38733
Is anyone else having a problem with Battle: Los Angeles BD and the 83. The disc tries to load. The status bar blinks once and gets to the last mark and then freezes. I have the latest firmware installed. Works fine in my PS3. I do not see any defects in the disc itself. Display shows all zeros.
post #36309 of 38733
Does this procedure help? What do I do if a Blu-ray disc will not load or play, or if it freezes the player?
-Bill
post #36310 of 38733
Try hitting the yellow button on the remote when it seems to freeze. I have a couple of problematic discs that hang up on the menu screen and can only advance by hitting that yellow button. I'm not saying it's the do-all to end all but it's worthy of a try.
post #36311 of 38733
The 93 recently got the ability to play DVD & BD ISO's over the network - I wish Oppo would just fix the MKV aspect ratio issue on the 83 and for making us wait so long add ISO support to the 83.
post #36312 of 38733
It's my understanding that the BDP-93/95 models do ISO from direct connected hard drives, not from a network. It would be nice if the BDP-83 could do the same. Is it possible?
post #36313 of 38733
^^^^ maybe I misunderstood the info I saw but the context was iso's being played from a server so i assumed that meant over a network.
Technically speaking its all software, the player is merely creating a virtual DVD/BD rom drive and mounting the iso file with it.
post #36314 of 38733
Originally Posted by Bob Pariseau View Post
ISO support is from directly attached disk drives (USB or eSATA). Get the point?
--Bob
Where the discussion begins.
post #36315 of 38733
^^^ you're absolutely correct, I went back and checked and I misinterpreted the info I saw.
post #36316 of 38733
It's still a great new feature that I want.
post #36317 of 38733
ISO support would be useless without NTFS support, which I think will never happen on the BDP-83
post #36318 of 38733
I'd be very surprised if Oppo adds significant new features like this to the 83. The underlying control programming in the 83 and the 93 are quite different.
--Bob
post #36319 of 38733
--Bob
I asked Oppo point-blank if they would offer a Netflix upgrade to the 83, and their answer was no.
post #36320 of 38733
Well I suppose the "upgrade" is buying a 93 -- less whatever you get for selling your 83. (Or were you thinking FREE upgrade?)
Not the answer you want to hear of course, but every company has to move on as their product line evolves. At some point, Oppo will stop adding features to the 93 as well.
--Bob
post #36321 of 38733
Now that this player has been out a while, Does anyone here use an IR solution other than the IR-ES1 that Oppo says is required?
I am moving my 83 to a closet and will need something in the HT room to control it.
post #36322 of 38733
there are plenty of IR solutions out there. Mine has been out of site for years, I also have my D2v, projector, lights, blinds etc on IR. Easy as can be, just stick the small IR sensor on the front of the device and put a central receiver somewhere where it can be seen, and off you go. I use a NEVO universal remote and all works well. http://www.tigerdirect.com/applicati...598&CatId=4738
post #36323 of 38733
Thats what I wanted to hear.
Sounds like I can use non-Oppo IR repeaters/extenders.
post #36324 of 38733
The only trick is that the rear IR input of the 83 (unlike on the 93/95) includes a power feed for the external sensor Oppo sells.
If you want to use some other sensor, you need an adapter cable which discards that power feed and keeps from frying your external sensor or shorting the power output from the Oppo. Oppo sells the adapter cable. Again this is only needed for the 83 and 83SE. This is nothing fancy. It's like a cable with a stereo plug at the player end and a mono plug at the sensor end that simply doesn't connect the extra wire carrying the power out of the player jack.
--Bob
post #36325 of 38733
I was able to sell my oppo 83 for 399. I got a buyer within 24 hours of posting it on amazon.
Jacob
post #36326 of 38733
With the ones I linked to in my post, you do nothing on the back of the 83, the sensor sticks on the front of the 83 - its very small.
--Bob
post #36327 of 38733
Interested in a BDP-83? Check the AVS classifieds.
post #36328 of 38733
Yay,
I love the fact it's not getting Netfix, Face book or YouTube. That stuff blows anyway. This player is a rock solid disc player and that keeps me happy.
Ta Dono
post #36329 of 38733
Check out a Roku XDS.... $99. Great little box...
post #36330 of 38733
Originally Posted by badas View Post
yay,
i love the fact it's not getting netfix, face book or youtube. That stuff blows anyway. This player is a rock solid disc player and that keeps me happy.
Ta dono
+1
