AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-83 Owner's Thread [technical talk only]
Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 1225
post #36721 of 38774
Originally Posted by gene9p View Post
loading times were much quicker on the 05..at least for me...
I also found the video quality on the 05 better than the Oppo,to the point I had to adjust the picture for the OPPO set up on Pio Pro Elite 111 fd..whereas the 05 looked just fine...I may have to retry the video by going directly from the OPPO into the tv instead of hdmi pass through from my Marantz pre -pro for HD sound..the 05 is direct into tv via hdmi and i just use the optical for sound to the Marantz
Thank you for that quick reply and info. Have a great day and enjoy Star Wars.
post #36722 of 38774
Originally Posted by kriktsemaj99 View Post
So what explains the difference, the firmware or just a case of one had BD live on and the other off?
I should add that my 83 has never had BD-Live turned on and never been hooked up to the internet. I have never cleared persistent storage either (I don't know what, if anything, is in there).
It just works.
post #36723 of 38774
I guess you were lucky with that old firmware. I just tried episode IV with the 54-0130B firmware and it wouldn't load (needed to power cycle to get the disc out). After updating to the latest (55-0226) it loaded OK and reached the menu in about 1m 30s (BD Live was Off).
post #36724 of 38774
yes ..I should have mentioned that too...the player becomes non responsive and has to be powered cycled just to remove the discs...my bd live also is always off and not connected to the internet
post #36725 of 38774
Weird glitch on Return of the Jedi…
If you have the 6.1 track sent out to your AVR (mine is an Onkyo 906) as LPCM the back surround will be silent. Turn it to DTS HD Master bit streaming and you get the 6th channel.
The other films do not have this issue...
post #36726 of 38774
yes..had not installed it and it would not play back movies until I installed it
also as was stated by another member...I have never encountered a disc that loaded so slow on the OPPO
now for some heartbreaking news....not so much that my panny 60k was faster than the OPPO...but my Pioneer Elite 05,a real turtle,blew away the OPPO with these discs
Well poo - I'll try a couple of my Star Wars discs tonight and report back with load times, etc.
post #36727 of 38774
With BD Live turned on and hooked to the internet, it took between a minute to a minute and a half to get to the top menu on the Phantom Menace. I had no audio or video glitches through the whole movie.
Being a Fox title I had my finger and toes crossed when I put the disc into the player. I was releaved when it loaded and played with out a glitch.
I am running the current firmware and I am bitstreaming to my Onkyo receiver. I aways clear the persistant storage before I turn off the player and I noticed that nothing was stored in it.
post #36728 of 38774
My testing says that loading of "Star Wars: Episode iV" is about a 50/50 proposition on the 83.
If it works, you will be on Top Menu in about 1:30 from Tray Close. This timing is very consistent. If it doesn't work you will be stuck AFTER the text about firmware updates appears and BEFORE "Top Menu" appears in the Front Panel display. Instead you will have dashes in the Front Panel display indefinitely. I've not seen it recover when stuck for more than 2 minutes this way (measured from Tray Close). Power cycling is necessary.
I've not had this problem on either the 93 or the 80.
Anyway, if it fails to load, just power cycle, clear Persistent Storage and try again. Odds are pretty good it will work. Oppo has the details of my testing.
--Bob
post #36729 of 38774
My experience was 100% good with Ep-4. I suspect the real issue may be with RE-loading the film, secondary to the JAVA-Resume programming. I find it can be temper mental if the movie isn't stopped and ejected with the correct secret code words. But my -83 had no issues with this title.
post #36730 of 38774
BTW, what IS the current firmware version of the BDP-83 or 83SE? Thanks!
post #36731 of 38774
You can always find the latest on the Oppo web site.
post #36732 of 38774
Agree. I had the same issues with episode IV (which that set has been returned as it wouldn't load any way you tried).
Between that and issues with back surround and bitstreaming, if this third set gives me any further headaches I'm going to blow up a f*%cking Death Star myself.
post #36733 of 38774
Interestingly enough I watched IV & V last night (cleared persistent storage first even though I'm not internet connected) and they both played fine. Went to watch VI tonight and of course it would not load. Just shut the player down and started it back up, erased again, and it started just fine and played perfectly. strong is the power of the Java.
post #36734 of 38774
Java the Hut....
--Bob
post #36735 of 38774
Latest firmware, no BD-Live, cleared persistent storage (on a 8GB flash drive), Eps 1&2 failed to start (I got the dashes). Cycling power with the BD still inside "fixed" it.
post #36736 of 38774
Darned if I didn't forget to try my Star Wars discs last night. Oh well - I have an excuse, my daughter has come down with a stomach bug - YUCK!
Anyway, I'll probably try them tonight . . .
post #36737 of 38774
Is it possible to have region free DVD with the latest firmware: BDP83-55-0226?
Is there a hacked version of it?
post #36738 of 38774
Yes, there are both hardware and software mods. Do a search and you will find. The hardware mods are the best way to go because you can get region-free BD as well.
post #36739 of 38774
Never, ever, install "hacked firmware". If you want DVD R-0 in the -83, there are several ways to do it. The easiest is a CD that can be used to set R-0.
http://www.multi-region.net/oppo_bdp-83
post #36740 of 38774
It worked!! ))
Thanks a lot!
post #36741 of 38774
Are all the issues with Star Wars and the 83 related only to loading, or are there also problems with audio dropouts when bitstreaming that are being discussed in other threads here and in other forums?
Anyone with an 83 running to a Denon 2310CI seeing this problem? Or is this only with software players? I'm trying to decide if I should go ahead and order the SW set from Amazon or hold off.
post #36742 of 38774
You can always set the player to LPCM and have it do the audio decoding if you experience errors with the player bitstreaming to your receiver.
post #36743 of 38774
^^^ Right, that's the workaround. I don't mind doing that as long as it's lossless.
post #36744 of 38774
It is lossless, just pre-decoded by the player prior to going out to your receiver. It is likely that you will not perceive any difference in the audio quality.
post #36745 of 38774
I'm sure I wouldn't. There are also reports of video pixelation along with the dropouts, but that seems to be hardware-specific. Haven't seen any mention of OPPO in those cases.
post #36746 of 38774
This would almost certainly be a symptom of a dirty or defective disc, which happens a lot more often than you'd think. There has been a feeding frenzy of people looking for issues on those discs, so it's no surprise that a pretty wide variety of issues (probably unrelated) have been reported.
post #36747 of 38774
I watched Episode IV last night - nothing all that unusual about the load times, maybe a tick longer than the norm.
Counting one thousand and one, one thousand and two . . . it was almost exactly 60 seconds from the time I loaded the disc until the "PLAY" menu appeared, then about another 30 seconds after I entered on the PLAY button until the movie actually began to play.
Video quality was fine, but on MY system the dialogue seemed thin, high-pitched or "tinny". The other audio seemed fine, nothing to write home about, but OK. Dialogue sucked! Need to try some adjustments next time I play IV.
I'll post more disc loading observations as time allows.
post #36748 of 38774
The mix for the Star Wars Blu-rays is almost exclusively Center channel oriented for the dialogue. It was annoying me to a certain extent as well.
post #36749 of 38774
Thanks for that info, that explains a lot. Next time I view a SW saga blu-ray I'll adjusting my various speaker levels to see if I can find a happy medium.
My system is such a mix-match of components that it is most likely exaggerating the problem as well.
post #36750 of 38774
More than annoying IMHO, but part of a greater trend amongst audio engineers.
Nobody ever taught them how to mix a center channel I guess, and I guess we should get used to it. (It's never OK to have dialog in center channel only)
