AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-83 Owner's Thread [technical talk only]
Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 1262
post #37831 of 38730
Originally Posted by herman56 View Post
I've tried in vain to watch the bluray "The Expendables"....however I can't get it to play. Anyone know particular issues with this disk? It's the only bluray I've had trouble with. Thanks for any help.
(1) Make sure you're running current firmware.
(2) Erase Persistent Storage and reboot the player.
If still no good, let us know.
-Bill
post #37832 of 38730
Originally Posted by rdgrimes View Post
You're still not really providing much info regarding specific issues. If you're playing rental BD discs, no visible scratches are acceptable - ever. Also, any problem disc should be washed and tried again...
That's helpful info, rd. irt the highlighted part on scratches: do you mean that one should not play a scratched disc or simply that one should not expect the player to read such a disc?
post #37833 of 38730
One should not expect it to play. BD has extremely low tolerance for any surface anomalies.
post #37834 of 38730
I have not had much trouble with scratched Blu-rays (the coating is pretty tough) but I have had several with visible "warps" or "bends" in the disc. You have to inspect the reflective surface carefully with a strong light.
I don't know if these are caused by stress during mailing in flimsy envelopes or are manufacturing defects.
By contrast I have had DVDs that are almost frosted with fine scratches and still play, and many with bad scratches that can be repaired with a polishing machine. A pock-mark in the plastic is tougher, and radial scratches (like grooves in a vinyl record) are very bad, as they defeat the error correcting code.
-Bill
post #37835 of 38730
You won't hurt the player by attempting to play a scratched disc. You just may have to sit through some error retries as it attempts to find a place to continue beyond the damage. If you find that too annoying, then don't play scratched discs. I play scratched rental discs all the time as part of Beta Testing with the OPPO players. The OPPO players can handle some pretty scratched up discs, often without even having to do read retries. Its all in the nature of the scratch.
You should NOT try to play a disc that is cracked or visibly warped (as by overexposure to heat) as those could impact the laser head.
You should also not try to play a disc that has grunge on the surface that might fly off and attach to the laser head. Clean the darn thing first.
It's also not wise to play a disc that has had a sticky tag or the like added to the label side, as they have a tendency to come loose and fly off at inconvenient moments.
Some types of disc damage are not so obvious. For example if you play enough discs you will eventually run into some where the center hole is either too small for the disc to load properly on the spindle or where the hole is not precisely centered causing the disc to have excess wobble. Both will almost certainly mean the disc can't be read, or even won't load properly (won't be recognized when you try to load it). It happens.
And with Blu-rays in particularly, there are types of manufacturing flaws which are tough to pick out with the naked eye. If a disc doesn't play, and other discs continue to play, and the disc surface looks pristine, and you don't see reports here or elsewhere of other folks having problems with this title, then the odds are pretty good you've got a disc with a manufacturing flaw. Usually the store or the studio will be happy to exchange it. By all means, ask here first, or email OPPO to see if they have history on this title (i.e., it is known to play for other people). But don't be shy about seeking a replacement disc.
If you are having trouble getting multiple discs to read without problems, particularly if the problem time codes vary each time you try a given disc, then it is quite possible your laser lens needs a cleaning.
--Bob
post #37836 of 38730
Tried your suggestions....however i can only play the previews on the disk.....then it seems to just not open any other area. So I can't actually play the movie...can't get any menus on the movies as well. Strange
post #37837 of 38730
I'm not sure if there are differences between the "hardcoat" technologies used with the various BD media, but I remember reading an article which suggested the hardcoat could be made to flow by heating it up with a hot air gun, which filled in scratches.
I received a BD-RW in the mail which had been sent in a fabric sleeve and actually imprinted the fabric weave onto the playing surface: I could not read the disc beyond a certain point. As an experiment, I held the disc in a heated air column and was surprised to discover that the playing surface was now visually perfect and all the data could be retrieved.
I can see why they don't suggest storing Bluray in sleeves, but only on disc hubs that prevent contact with the playing surface.
Whilst I wouldn't suggest it with rental discs, for those discs one owns that are scratched and won't play, it may not hurt to try the hot air approach to "heal" the surface.
post #37838 of 38730
It may use tricky authoring which is not completely compatible with the player.
You could try enabling or disabling BD-Live, with or without a connection to the internet, with or without a flashdrive to provide supplementary memory: one of the combinations might work.
If you are attempting to play a Region B disc in a Region A player, this may be the way the disc identifies it can't be played in that region. Alternatively, even if the player is region switchable, the disc may have 50Hz menu elements that will not display on a 60Hz TV.
Or maybe it's just a defective disc.
post #37839 of 38730
Originally Posted by Bob Pariseau View Post
You won't hurt the player by attempting to play a scratched disc. --Bob
Thnx, guys.
post #37840 of 38730
Originally Posted by superheropunk View Post
I will on Monday. Have had the player new for a few years and it have had dealings with Oppo over the years. It is updated to the latest firmware and know about the persistent storage and BD Live Off. Most of the times I blame the disc but it is just happening to often (bluray's through blockbuster).
Have a replacement disc of Hanna (reported 1st disc as unable to play) and the player is still freezing on the 2nd disc (incredible!!!). The disc has a few light scratches but otherwise looks perfect. Most regular DVDs can be scratched to heck and still play perfectly. Last night I experimented a little and cut the 24 frame off and lots of other things to off but still didn't help...
Just an update I was able to test the bluray disc Hanna on a Samsung bluray player and it the movie froze it the exact same spot so it is for sure the disc on not the player. This is the 2nd Hanna disc rec'd from blockbuster and waiting for the 3rd....
post #37841 of 38730
I was having an issue with the Shrek movies and Puss in Boots where the 7.1 Dolby TrueHD track was being identified by the player as 5.1, and LPCM output over HDMI would only send 5.1 channels to the receiver while bitstream output worked fine. The same discs played on a similarly configured BDP-93 don't have this problem. I saw from earlier comments in this forum that some people were having similar issues with Megamind and Kung Fu Panda, so this may apply to all DreamWorks releases with 7.1 Dolby TrueHD tracks. I didn't see that anyone had posted an explanation of why this happens (I apologize if someone beat me to it), so I thought I'd post what I found out from my conversation with Oppo customer service.
We have confirmed with at least these discs that this is a platform limitation. Even with Secondary Audio set to OFF, the player is aware of the Secondary Audio Program and prepares itself to decode it, even if the player is being told not to (Secondary Audio is OFF and Animator's Corner is disabled). This is normally not an issue, as Secondary Audio Programs are done in standard Dolby Digital or DTS.
With the Shrek series of films the Secondary Audio Programs are done with Dolby Digital Plus. The DSP in the player can't decode Dolby Digital Plus and Dolby Digital TrueHD 7.1 simultaneously. This results in the player only producing 5.1, rather than 7.1, audio.
Unfortunately this seems to be a platform limitation that will not be addressed through future firmware.
Best Regards,
Customer Service
OPPO Digital, Inc.
post #37842 of 38730
^ Deep Sigh.
I wonder what they were thinking authoring Secondary Audio as DD Plus? Talk about overkill....
Anyway, thanks for posting the explanation!
--Bob
post #37843 of 38730
DD plus in Shrek? Prolly ported from HD-DVD releases.
post #37844 of 38730
^ It's in the Secondary Audio. That's the thing that boggles the mind. There's no point in doing anything fancy with Secondary Audio.
--Bob
post #37845 of 38730
Doesn't really qualify as "cleaning", you need to open it up and use a q-tip with alcohol.
Sometimes those lens cleaning discs with tiny brushes built-in can do the trick. However I also recommend lifting the cover to blow the dust out. These units have fans which get caked in dust and draw a lot of dusty air over the internal heatsinks, which could cause performance problems.
I've never actually had to manually scrub the optics with alcohol, nor do I relish the thought. That would be a last resort, perhaps warranted under extreme environmental conditions such as airborne grease or smoke.
post #37846 of 38730
Wow, I just had a flashback to the days of having to regularly clean the guts of my Pioneer cassette player with a q-tip and rubbing alcohol...ah, the good 'ole days.
post #37847 of 38730
Me, too... though mine was a Pioneer 10.5-inch reel-to-reel flashback
post #37848 of 38730
Mine is cleaning Pioneer open reels (RT-1020L and RT-707) and assorted cassette decks. I still have them all and relish the fumes from the radio shack tape head cleaner.
post #37849 of 38730
Don't forget the de-magnetizer!
post #37850 of 38730
Here's my kit...
post #37851 of 38730
Gosh! The 83 must be getting kinda old if this has turned into a nostalgia thread.
--Bob
post #37852 of 38730
2009? Seems like it was yesterday. How time flies...
post #37853 of 38730
I used to use an ion gun to zap the static out of my LPs.
post #37854 of 38730
Don't forget the tool to align the stylus.
post #37855 of 38730
Wow, are you guys are bringing back memories. I still have my Revox 10 inch reel to reel, belt-driven, synchronous-motored LP player and a shelf full of LPs. Lost all my tapes in my last move.
At one time, I tried using the bulk tape eraser on Sony digital vidio tapes -it had absolutely no effect on them.
Alan
post #37856 of 38730
Alan
I'll see your Revox and raise you with my Nakamichi Dragon. In its day . . .
Now it's on a shelf in the closet. Not even sure if it powers on any more.
post #37857 of 38730
I used to drool over the overpriced dragon in Tech HiFi.
post #37858 of 38730
Just wanted to report my experience with Oppo customer service. I had the not-uncommon tray eject problem. Oppo fixed it in two days, free of charge. Truly, they are a class act.
post #37859 of 38730
Originally Posted by palmfish View Post
Here's my kit...
Found one of those in a thrift store for $3. It does a great job cleaning and demagging my Akai GX-646 and GX-747.
I love my Oppo's but nothing is more impressive than watching a 10.5" reel to reel at work!
post #37860 of 38730
is it possible to play dsd on a usb thumb drive?
