Originally Posted by
JazzGuyy
There are at least two major types of region mods. One uses the sequence you just cited to change the region, the other uses a different sequence that involves the colored keys on the remote. It seems the OP has this latter kind so your instructions probably won't help him.
I have what I believe is the "other type" of zone/region mod. So far (for several years) it seems to have worked fine. Here are the instructions that came with mine:
- Switching Zone is operated by the remote control
- Turn the player off with the romte control, using the power button
- Press and hold the the BLUE button until the player beeps (approx. 5 sec.)
- Now you can select your zone:
- Zone A: Press 1 on the remote control
- Zone B: Press 2 on the remote control
- Zone C: Press 3 on the remote control
- Switching Region is operated by the remote control
- Press and hold the the RED button until the player beeps (approx. 5 sec.)
- Region 1: Press 1 on the remote control
- Region 2: Press 2 on the remote control
- Region 3: Press 3 on the remote control
- Region 4: Press 4 on the remote control
- Region 5: Press 5 on the remote control
- Region 6: Press 6 on the remote control
- Region 0: Press 0 on the remote control
