Originally Posted by Robert Cook
Possibly, because as far as I know the BDP-83 only has settings for 5.1 and 7.1 output. If you don't plan to use the surround back channel, then simply set the player to output 5.1, and you're done. If you do plan to use the surround back channel, then until you get a 7.1 receiver you'll need to combine the two surround back outputs from the BDP-83 into the single surround back input on your receiver with something like this:
Do not combine channels using a simple wye-connector as listed above. I refer you to RaneNote 109 "Why Not Wye?" for the details as to why not. But put simply, "A wye-connector used to split a signal into two lines is being used properly; a wye-connector used to mix two signals into one is being abused and may even damage the equipment involved." Don't want you to shorten the life of that new BDP-83.
So either use just one of the surround back channels into the single back surround or obtain a properly resistant line combiner. If you're handy with a soldering iron, you can make your own simple mixer. I've probably made half a dozen of them over the years and I stink with a soldering iron, and they've still worked without a hitch.
MC
You're absolutely right--thanks for catching that. I'm sorry if I mislead anybody.
I am sort of
