AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-83 Owner's Thread [technical talk only]
Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 157
post #4681 of 38777
You've got it. Or, if you want to play with the multichannel analog output, you can do so with 5.1 sources (DVD-Audio, SACD, and a lot of Blu-ray discs) with downmix set to 5.1.
post #4682 of 38777
Originally Posted by bwillcox View Post
Is your Oppo player connected to your Rotel via HDMI? If not, then there's no way you can get DSD to it.
It's not. That's, in part, why I posed the question. I had expected the Setup program to either recognize that HDMI was not being used for audio and not allow DSD to be selected or that it would simply default to PCM somewhere in the process.
This morning, I discovered that the OPPO had done the latter. Even though I had selectd DSD last night for SACD playback, when I played an SACD this morning and took a look at the Setup page, it had reverted to PCM. I guess the OPPO wait until you "refresh" the setup before it lets you in on the fact that it didn't take the DSD setting and went to PCM. Mystery solved.
post #4683 of 38777
Originally Posted by jam88 View Post
Since your Rotel RSP-1066 only has 7.1 analog inputs, DSD decoding must be performed by the BDP-83 and sent out through the analog outputs. The reference to the AVPs/AVRs being able to decode DSD only applies to units that have HDMI inputs that can accept the DSD streams for decoding by AVPs/AVRs that support that feature (not your case).
If you set the the SACD output on your BDP-83 to DSD, the DSD data will be converted into an analog signal directly by the internal DACs.
If you set the the SACD output on your BDP-83 to PCM, the DSD data will be converted to PCM by the BDP-83's DSP. That PCM data will in turn be fed to the DACs. This option will give you more flexibility as you'll be able to use features such as the channel down-mix mode, the bass management, volume trims & distance settings for your speakers.
See pages 53 through 62 in the user manual.
My question was more related to the Setup protocols in the OPPO. Setup allowed me to select DSD. I would have expected the OPPO to sense that there was not a digital pathway available and not allow DSD to be selected. As it turns out, it defaults to PCM under those circumstances, it just doesn't let you know until after you "refresh" the Setup page. Not a big thing, just interesting.
post #4684 of 38777
Thanks. I ordered a couple of DVD-As to play with the Oppo DV-981HD vs. the BDP-83. Still not a lot of TrueHD or DTS-HD titles available.
post #4685 of 38777
Even if it could sense the lack of a digital pathway for DSD, that option also applies to analog output (the DSD bitstream goes straight to the DAC), so it would be counter-productive to disable that control.
TrueHD and DTS-HD Master Audio are starting to be more common, although 7.1 tracks remain scarce. I've got almost as many DTS-HD MA discs now as I do multichannel PCM discs, with TrueHD just a few spots behind DTS-HD MA. Finding out what is on a disc before you order can be tough, though - Amazon.com in particular seems to make no effort to figure out that information.
post #4686 of 38777
Please the the appropriate forum(s) for non-player related inquiries. Thanks.
larry
post #4687 of 38777
You are mistaken about the setup and how it works. Suggest re-reading the manual in the relevant section. For analog output, you still have DSD or PCM options, determining which is sent to the DAC. Using DSD will bypass all the speaker setup and bass management.
post #4688 of 38777
Originally Posted by Neuromancer View Post
OPPO reads the forums. If they read your e-mail after your previous issue (no power) then they may not respond to your other e-mail, as your issue had been resolved and their response would be redundant or inaccurate.
Indeed they do, they just proved it to me!
I am happy to say they are sending out a replacement today. As this is my only DVD/BD player, I'm going to be out of commission for a few days. At least they're doing a cross-ship.
Sucks to be down, but OPPO is handling this about as awesomely as anyone could ask. They're even going to mail me back the DVD once they get it out. Kudos to them.
post #4689 of 38777
Originally Posted by zorro524a View Post
I was in error. I thought adjusting the audio delay through the HDMI menu under video settings affected the analog output. After more critical analysis, I was incorrect. I was simply perceiving what I wanted to see/hear.
Speaking of audio delay, I wish Oppo (and other companies) would support adjusting the delays in increments of 1 or 0.5 ms. Sound travels 10.8ft in 10ms and I believe the brain is sensitive to within a few inches when it comes to mapping sound to a perceived location. For audio-video sync, it may not be such a big deal, but for the speaker time delay, it can make a significant impact on perception.
You can tweak the speaker distances in the Speaker Configuration section of Setup for the analog outputs (see manual, ppg 58-59). Distances are set in 1ft increments. Is that what you need/want?
The HDMI lipsync stuff is applied enmasse to the whole HDMI audio signal, not per speaker, and is for exactly as you say: audio-video sync.
If sending audio via HDMI, your receiver should apply the relative speaker distances, rather than the player.
Or have I missed what you were trying to say?
shinksma
post #4690 of 38777
Yeah, probably just a bunk unit. Can't expect electronics to never fail. I think out of the EAP units in the wild, this is the first one we have heard of that seems to have a hardware failure (not bad!) You'll be up and going again soon enough.
post #4691 of 38777
Received my player today, but probably won't get a chance to hook it up until Friday. I do have a handful of BD movies and 20+ SD DVD's I can test and I now own 3 DVD-A and 2 SACD's, with 2 more DVD-A's coming.
post #4692 of 38777
Originally Posted by nathan_h View Post
Watched a PAL (region=0) DVD of an old Fritz Lang movie tonight and was impressed with what the Oppo could wring from such a middling source.
Nathan, many thanks for that comment - although I'm obviously looking for a BD player, it would make the layout of my rack so much better if a single device could also handle my existing PAL region 0 disks (of which I have many).
Every other US-model BD player for which I've seen the specs, explicitly states that it does not handle PAL DVDs - so OPPO get a big thumbs up from me for doing this.
Do you know if it can take a PAL R0 disk and output it via HDMI as either 1080i/60 or 1080i/50 dependent on the display's capabilities?
post #4693 of 38777
Possibly st00pid question, arguably OT:
Is there a market for a niche room optimization processor that oppo might offer as they did with their HDMI switcher? Stubby HDMI to the outboard oppo EQ, 7.1 analog to AVR? I wonder also if would have to be cost prohibitive, I'm guessing it would need to be sub $150 to be a cost effective solution.
As one of many with a tragically family-supporting living room > HT, I know it would make more sense for me to buy a new AVR, but I hate change anyway and I am happy, etc. etc.
The only time I have heard this mentioned was to salvage quite expensive equipment, made me wonder if a truly simple unit could prove profitable for oppo.
post #4694 of 38777
It can output PAL or NTSC, user selectable, or be set to do both depending on the source content.
post #4695 of 38777
His was also the first unit to be opened ... just saying *cough*
post #4696 of 38777
I output it as 1080p (60hz). I have the setting for 1080p24 conversion for DVDs "on", but it didn't work for the PAL DVD (though it works great on the NTSC DVD I tried).
Note, I wouldn't expect the conversion to 1080p24 to work for PAL DVDs but it would have been cool!
post #4697 of 38777
I hope he didn't let the magic smoke out...
post #4698 of 38777
Losing the magic smoke is fine. But if he let out the magic smoke and steam, that is when you run into mechanical problems.
1080p/24Hz will not work, but 1080p/25Hz will.
post #4699 of 38777
I just got mine set up. I am connected to my processor via analog for the time being. Can't wait to get the audio set up with HDMI but am waiting for the Meridian board which I hope to receive in the next few weeks.
Plugged it into my LAN as well. Set up the network configuration and checked for new firmware. It said I already had the latest. So the LAN part seems to be working fine. There is also a setting to be notified when there are FW updates, which is good.
Using the DSD setting (IIUC the PCM setting will just convert from DSD to PCM so why do an extra conversion?). Played a DVD-A and a SACD with no problems.
Popped in the Bond Casino Royale BR and no problems. Unfortunately it doesn't have one of the new HD audio formats. Picture is great but I'm using source direct setting on the Oppo to let my Radiance VP do all the video work. I didn't notice any lipsync problems.
One thing I noticed is that I have to crank the volume up much higher on my Meridian processor with the Oppo as a source via analog. I don't think there is any way to adjust that from within the Oppo. Not a big deal unless I switch audio sources when the Meridian volume control is cranked for Oppo. That work hurt....
Oh. I can also confirm that the ir codes from the other Oppos work with this one. On my Pronto remote I used the same Oppo command setup as for my 980 and no problems. I did the entire set up and playback control through the Pronto. I haven't even taken the Oppo remote out of the plastic.
post #4700 of 38777
Originally Posted by NoiseGoth View Post
The EAP2 manual I received did not say "Preliminary" on it.
Mine had a slip of paper in it saying something along the lines of "Updated manual available on oppo.com"
post #4701 of 38777
The FedEx guy brought me a present this morning
post #4702 of 38777
Thanks for the picture of the box...we've never seen one!
post #4703 of 38777
Is that the EAP-2 box, or did they go into production mode on shipping cartons?
post #4704 of 38777
Mine too. But I had already read the online version (which, as many of you know, has "preliminary" stamped all over it).
post #4705 of 38777
I don't see an option to choose 25hz output from a PAL DVD. Is that done by choosing PAL instead of NTSC output AND 1080p24 conversion for DVDs?
If so, I probably won't bother because I don't want everything to default to PAL output....
For you members of "the 300", remember what the Oppo site says:
A "Yes" vote means that the features and stability of the BDP-83 player are suitable for my home theater. Please release to the general public.
post #4706 of 38777
Liar. Just maybe the first one to post pictures. Names withheld to protect the guilty, but a certain beta-tester opened his to place temp probes.
In my defense: all work was done on an anti-static workstation, fully-grounded. Nothing was touched on the inside except for the analog audio board, which was only handled by the edges and only enough to disconnect the cables, which was done carefully. Acknowledging that this part was indeed handled, when the power-on issue surfaced I tried disconnecting it again (in-place) to see if something about that board was preventing powering on but the problem remained. So yes, a seemingly incriminating coincidence but I do feel I'm not the cause.
post #4707 of 38777
For you members of "the 300", remember what the Oppo site says:A "Yes" vote means that the features and stability of the BDP-83 player are suitable for my home theater. Please release to the general public.
Ok. So what is your point? Please give us some time to use them before we start firing off votes.
post #4708 of 38777
I just heard FLEETWOOD MAC with DVD AUDIO and it sounded fantastic!!!!! This is a very hard disc to purchase as i have tried for a year an just won on E-BAY last week.No problem playing the disc.
post #4709 of 38777
So, what does that make the defect rate? ~2% That's kinda scary.
post #4710 of 38777
Wait, which one? Rumours or Say You Will? Rumours was the 1 disc I had (out of about 50) that AFTER playing would lock up my Panny CP72...
