Originally Posted by Jack D
I don't think the following question has been answered in this thread or the FAQ(if so apologies):
Consider the statement from the manual:
"If you use HDMI to connect audio to an HDMI A/V receiver or audio processor, it is important
that you choose 720p or higher HDMI output resolution when playing high resolution audio
content (SACD, Dolby TrueHD and DTS-HD Master Audio). According to the HDMI
specification, the bandwidth available for audio is proportional to the total bandwidth used by
video."
OK so assume that the Oppo is set to "source direct" video mode and HDMI audio output is engaged. What HDMI bandwidth will be enabled when playing an SACD or DVD-A that has no video?
I ask because I use the Oppo with a Radiance XD video processor so I leave the Oppo in source direct mode. I currently am using analog audio out but will soon be able to use HDMI audio. So I was just preparing.
Thanks for any response.
video."
The manual does have a table showing the Source Direct output resolutions in "Installation / Setting Up the Player - Easy Setup Wizard / Select the Best Output Resolution". DVD-A is not yet shown but I think it is the same as SACD.
-Bill
Aside from being physically vulnerable when very heavy cables are used (they definitely need support not to pull loose), the digital connection itself seems to works extremely well for all the applications where I have used it.
