AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-83 Owner's Thread [technical talk only]
Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 230
post #6871 of 38733
Originally Posted by jbm007 View Post
"Days of Future passed" on DVD A loaded and immediately decided to play the last track ( track 8) rather then starting on the first track.
Jim
Thanks for reporting on those discs. AFAIK for surround on optical discs, "Days Of Future Passed" has only been released on DTS-CD and SACD.
post #6872 of 38733
Originally Posted by Roger Mathus View Post
Pardon me if this has been covered. Apparently there are still some audio issues not fixed in the new firmware. Example: DTS Surround CD :Vince Gill (High Lonesome Sound). It sounds like the pitch of his voice is way too high on the OPPO. When I played in a Marantz BD8002, Vince sounded normal.
It's the Oppo that is playing Vince's voice correctly. Try playing a Guy Clark, or Tom Russell CD, and you won't have that problem...
post #6873 of 38733
I just ran the firmware update via ethernet connection - very fast.
i performed a factory reset per the instructions and got a strange green initial setup menu. i turned the device on and off and it reset to normal.
any one else get this?
post #6874 of 38733
Originally Posted by mark69 View Post
Hi,
2.Rob Thomas Something to Be DualDisc-Will not play, just zeros on the player display. I have to shut the player down, and then hit eject while the player is off to get it to eject.
3. Jackson Browne Running on Empty DVD Audio-I am having issues with the menu, when I select audio set-up the player freezes. If I go straight to play it will play.
4. Neil Young Hawks & Doves 2ch DVD Audio- When I play the disc the songs are played back extremely slow, doesn't even sound like music.
5. Neil Young On the Beach 2ch DVD Audio- Same issues as #4.
2. Same here total hang
3. Same here most of the menus work really well and it plays perfectly.
5. I don't get any audio at all on On the Beach, although the menus seem to work for the most part.
I also tried Yes - Fragile as someone mentioned it way back, it appears to use the same menu system as #3 with pretty much the same results.
post #6875 of 38733
Originally Posted by gsr View Post
I just ran a quick test playing the Kenny Wayne Shepherd HDCD with the HDMI output set to Bitstream and then again with it set to LPCM. In both cases, the HDCD indicater on my Denon AVP flickered and the audio stuttered. I can't figure out how to get the signal bit depth on the AVP for this digital source - I've posted a question in the AVP thread. If I'm able to find that information out, I'll post an update, but it would appear that the Oppo is not sending the expanded HDCD digital info to out the HDMI cable in either mode.
You may have missed it but I got this from Oppo today.
Tom,
The BDP-83 right now is always decoding HDCD. We are working with our engineers to resolve HDCD related issues through future firmware releases.
However, at this time, we have no resolution for all reported HDCD issues.
Best Regards,
Customer Service
OPPO Digital, Inc.
It is very strange to me that LPCM triggers the HDCD decoder on the Denon. You would think if they really are decoding and padding to 24bits all remnants of the HDCD bits would be gone. As I said earlier LPCM works great for me but like Nathan I have no way of telling if it is really sending 24 bit words instead of 16 bit.
post #6876 of 38733
Originally Posted by NoiseGoth View Post
Glad you have a system that seems to work. I think the average person isn't going to be willing to go through such a laborious process to simply listen to a CD that played just fine yesterday on a different player... I know I certainly wouldn't and I have over 4000 CDs and 250 DVDs (not including burns).
I've encountered the vibration issue on one DVD and one CD so far, out of about 15 DVDs and 4 CDs I've played in the BDP-83. I do believe that the problem can be attributed to individual discs (not necessarily individual titles), but a player should be able to compensate for such minute defects. If previous players had no problems, I think it's fair to expect the BDP-83 to perform just as well.
I have cleaned my discs right after acquiring them so this has been going on for decades. My discs play fine in my older players and in the BDP-83.
post #6877 of 38733
FWIW, I can confirm that Queen DVDA Night at the Opera is not playing correctly after the firmware update. It is strange behavior, at least on my system with HDMI connected to a Sony DA 5300ES, it shows the root menu and allows you to access the playlist, but after selecting a song it tends to skip periodically and it has sound dropouts here and there on all songs. It seems that the firmware is getting close but something is just a bit off. It seems to play 95% of the song okay but the 5% sound issues is a bit disconcerting.
On the other hand I played the Eagles with the output set to Bitstream and it played fine. Before you had to set the player to LPCM or else it would stutter through the Eagles Hotel Califorinia. Now it plays fine with no issues. Of course you would expect a California company to get this right
As time permits I will go through more DVD audio, but I am getting no other issues on any other formats. My CDs, DVDs and Blurays all play fine.
post #6878 of 38733
Yes, several people have reported this since yesterday.
post #6879 of 38733
Nope, I saw that post earlier - which is one of the things that prompted me to try Bitstream AND LPCM modes again to confirm that what I remembered was what was actually happening.
Based on what I'm seeing, I don't believe they are sending a 24bit signal out of the HDMI cable for HDCD regardless of the mode being bitstream or LPCM.
I'm sure they'll get this fixed - I wasn't expecting they'd have all the problems fixed in one firmware update.
post #6880 of 38733
This is my first post in this thread, even though I'm an EAP2 participant. I uploaded the new firmware today. First BD I threw in after an exceptionally easy upgrade via USB drive, was Planet Earth, Disc 1, Fresh Water, Chapter 1 (David Attenborough narration). The Oppo picked up from the previously stopped point despite the FW upgrade (very surprising). First thing I noticed was at about 2:50 into the chapter. There was a "pulsing" of grainy frames at about a 1 hz rate (1 per second) for about three minutes (the beginning of the Angel Falls scenes). It appeared to occur on only certain camera shots (apparently from a helicopter), so it's possible this is source-related.
Can anyone else duplicate this, and tell me whether in their expert opinion this is a possible bug, or whether it's in the source?
I would swear that I would have picked this up on my original viewing, but I don't recall seeing this phenomenon before.
I am running the BDP-83 with all default settings, pass-through an Onkyo TX-SR606 AVR, then to my Pio PDP-5020FD, all HDMI. When I change any of the settings, (e.g., color-space, deinterlacing, CUE, deep color, etc.), the pulsing is still there. I have checked on a few other discs and have not been able to see this anywhere else. I want to hope that this is in the source, but would like to hear from some other members before sending this to Oppo.
TIA.
post #6881 of 38733
Now that I'm a proud owner of the BDP-83, how do I pronounce Oppo? Is it "Ah-poe" or "Oh-poe"?
post #6882 of 38733
So if your really not that into SACD or DVD-A would it be advisable "not" to download this so-called firmware "upgrade?"
post #6883 of 38733
Personally, I think we all (EAP members) owe Oppo, their future customers, and ourselves the minimal effort it takes to download and install the new firmware and make sure it doesn't break anything we care about. I honestly don't see how anyone can feel like they're doing the right thing voting on a firmware version they haven't even tried which is effectively what you're doing if you have already voted but haven't installed the update. My no vote happens to stand because they clearly haven't fixed the HDCD issue yet.
post #6884 of 38733
TIA.
First, I don't have a BDP-83, but I thought I'd check out my BD of Planet Earth where you noticed the pulsing on my PS3. If you are referring to a very subtle pulsing sporadically occurring (for instance as the helicopter is going up the falls and over the top and the waterfall mist is half in sun and half in dark shadow creating a rainbow) I do notice a pulsing. It is very subtle, and I likely would not have noticed it unless you had mentioned it. But it is there.
How obvious is it on your BDP-83? Perhaps others can see if they also notice it.
post #6885 of 38733
I recommend all EAP owners install this upgrade.
--Bob
post #6886 of 38733
Dang! I do believe you've found a question that is NOT covered in the FAQ!
--Bob
post #6887 of 38733
Not all enhancements are listed in the Release Notes. So it is always advisable to upgrade to the latest firmware release.
post #6888 of 38733
TIA.
Sounds like you have the Oppo set to output 1080i, or source direct. Planet Earth should be 1080/60i. If you want the player to de-interlace it you should set output to 1080p. The "auto" setting is default, and should work if your display is calling for 1080p.
Anyhow, you are describing "aliasing" that is common with interlaced material, and is more obvious the larger your screen is. Some people call it "shimmering".
The Oppo can eliminate some of it, but not all. It really depends on the source material.
post #6889 of 38733
"Oh-poe" is how I have been saying it for years.
post #6890 of 38733
Hi,
Before I include the email I just sent to Oppo I thought I would let all of know that I am a big Oppo fan. I have owned a 981, and 2 983 dvd players. I currently own a 980 and obviously the BDP-983. I am using my BDP-983 in my bedroom, I am bitstreaming to a Pioneer Elite SC-05 receiver, and HDMI from the receiver to a Pioneer Kuro 5020 TV.
The BDP-983 is replacing a Oppo 983, and a Pioneer Elite 05 blu-ray player. I have sold both of these players so that shows the confidence I have in Oppo to fix the problems I have experienced. I got the player last Saturday, and have been playing blu-rays, SACD and dvds with no problems. The picture and audio quality is excellent.
I wanted to wait for the new firmware to come out before I wrote to Oppo since I knew that DVD Audio was a work in progress. I will say that most of the discs that I had problems with now play without problems. There is still one disc that doesn't play properly which I include in my email.
Lastly I have not voted yet, because I wanted to wait until the new firmware was released. I will not vote until either a new firmware is released that fixes my problems, or until Oppo instructs us to vote. I also wanted to thank all of the people on this forum for their contributions.
Below is the email I sent to Oppo this morning:
I am part of the 2nd EAP and I have several discs that I am having problems with. I downloaded the new software last night so the discs I am writing about are being used with the new firmware. I am using HDMI out bitstream to a Pioneer Elite sc-05 receiver.I also tried LPCM and had the same issues. I also have tested all of the discs in My Onkyo 805 HDDVD player, and the problems don't exist with that player.
1. Elvis 30 #1 Hits is a 5.1 DVD Audio discs with 6 stereo tracks at the end of the disc. When I attempt to play this disc it always goes to the stereo tracks at the end of the disc. Will not recognize the 5.1 tracks.
I am writing to you to send you my feedback on the player so far. No issues with SACD discs yet, no CD issues. Blu-Ray and regular DVD both play very well.
Originally Posted by Villella View Post
"3. Jackson Browne Running on Empty DVD Audio-I am having issues with the menu, when I select audio set-up the player freezes. If I go straight to play it will play."
FYI - I just tried this same DVD-A and didn't have any problems with it, or specifically with the menus.
1) +1 on the Jackson Brown issue with "Audio Setup". Also, when I press track list this list comes up then after a pause the player "stops". Third issue with this disc is the transition from "The Load Out" to "Stay" is not smooth as on my Denon 3910.
2) Same "Audio Setup" problem with Chicago II.
3) All DVD-A discs tried that have lyrics have a "flicker" as you go from page to page. It works, just not smooth as on the Denon 3910.
Sure hope Oppo keeps at it with DVD-A........................they do sound great though!
post #6891 of 38733
Yes's Fragile on DVD Audio sounds fantastic on the BDP-83. Highly recommended. I also got the BD Live content to work on Sleeping Beauty.
post #6892 of 38733
Thanks for checking on a different player. It is very obvious to me now that I have noticed it for the first time. But since you can report seeing it on a different player, I will assume that it is in the source and is not a problem inherent in the BDP-83.
post #6893 of 38733
Thanks for the reply. Planet Earth is indeed encoded at 1080/60i. In my original post, you will note that I originally saw this after the FW upgrade, and after I reset to default, per Oppo's instructions.
Once I noticed this "defect", I attempted to make it go away by varying a bunch of different settings in the Video and HDMI menus. Nothing I did could make it go away, including setting 1080p, 1080p/24, color space, deep color, etc.
Not to open another can of worms, but while making these adjustments and with color space at 4:4:4 and changing deep color from 30 bit to 36 bit, I got a terribly pixelated green screen of the video playing, almost like when you're using component cables and one of the cables is bad - but worse. I made it go away by resetting back to factory defaults and starting over again. When I did the same thing a second time, the weird screen would not come back (no problem with that).
In addition, the PDP-5020FD is set to Pure Cinema - Advance, which is supposed to output a 1080p/24 signal at 72hz, so that isn't the problem either. I'm convinced this is in the source, and don't want to take up anymore precious thread space with this observation.
This is the only "glitch" I have encountered thus far, and it apparently has nothing to do with the Oppo. I will be voting YES any day now...
post #6894 of 38733
I tried a few HDCD's Kenny Wayne Shepherd Eric and Clapton Reptile and still the same problem, with both HDMI and coax. It will lock on and the flicker with sound going in and out with the flicker. It did seem like the HDCD light would stay off longer since the update with less cutting in and out, but still a problem.
On a good note DVD-A is working a lot better. Most of the disc I tried worked. Eagles Hotel California work great 192kHz 2 channel and 96kHz 5.1.
Diana Krall the look of love played fine.
Queen Night at the Opera still has problems.
OPPO keep the updates coming
Brad
post #6895 of 38733
Dowloaded the new firmware. I still notice a bad A/V sync problem with the audio. I popped in Mask of Zorro superbit, and audio was way off from the video. I also noticed this on Pirates COTBP Blu-ray. Other discs, I have not noticed as yet. Yes, I know I can set the A/V sync, but it is a hassle to have to do it for some and not others. The only DVD I ever had a problem with sync on my Denon 3930 is Saving Private Ryan DTS version. Otherwise, the sync is excellent. I have played only a handful of movies, and I am having the sync problems. Very annoying.
Also, I am growing a bit annoyed with the place holder aspect on the DVD/Blu-ray. I don't mind if I leave the disc in the player overnight or whatever, and come to it later and it picks up where I left off. That's great, but it is quite annoying if I take the disc out, place it back in, and it doesn't start from the beginning. Is there a way to disable this feature?
Lastly, just my gut impressions, but I still feel the Realta is performing DVD playback just ever so slightly a bit better...a bit smoother. I am not knocking its performance, I just feel the Realta does a slightly better job IMHO. Nothing specific per se, just little tiny things that you kind of notice out of the corner of your eye. Haven't checked out any DVD-A or SACD playback as yet. I am more interested in video performance at the moment, and these are the things that are bothering me about the player.
post #6896 of 38733
Planet Earth cannot be made into 24p, at least not correctly, since it's video material not film. The Oppo will ignore a 24p setting on such material, I don't know what the display will do with it.
post #6897 of 38733
Simply press stop twice. Or press stop when prompted to do so on disc insertion.
post #6898 of 38733
When you insert a disc that has a Resume location recorded, you'll get a message that the player will resume at the previous play position unless you press Stop.
Press Stop while that message is up and you'll be able to play the disc from the beginning.
You can also discard the Resume position when you are done viewing the disc by pressing Stop to end playback, then press Stop again when you get to the Oppo splash screen. Then eject the disc.
--Bob
post #6899 of 38733
Originally Posted by AudioBear View Post
I find the vibration issue very curious. I have not seen it on my unit so this is a shot in the dark but here goes. Spinning little shiny plastic discs in trays is hardly a new technology. It's hard to figure what Oppo could have done wrong here--if anything. They buy their BD drives from some supplier (somebody here can tell us who makes them) so they should be more or less the same as any other. Making a tray that slides in and out is also hardly a new technology. Most optical media players just don't vibrate so much that you would report it. So what has OPPO done to make discs vibrate? Or is the fault in the discs as has been suggested? Something just doesn't add up here.
I just received this from OPPO this afternoon (I had sent them some disks I had that were vibrating and have since found others) .....
Joel,
We have been investigating issues related to CD vibrations and the BDP-83. What we have discovered is that many of the discs which are causing vibration issues have plastic rings which are smaller than industry standard. This causes an issue when the loader spindle engages the CD.
We are looking at adjusting the RPM of the servo to compensate for these discs in a future firmware release.
Best Regards,
Customer Service
OPPO Digital, Inc.
2629B Terminal Blvd.
Mountain View, CA 94043
And I sent this back a little while ago:
Thanks for the info.....
I took it upon myself to fix my vibration issue. As I stated it seemed to be an problem with the seating of the tray. I used a small rectangular rubber foot that came with my WD TV. It was designed to be used on the side ribs if you planned on standing the unit upright.
It is only about 0.9 inch long by 0.1 inch wide and I measured it at 0.066 inches thick (I got to play with my electronic caliper). I placed the strip on the inside of the top edge of the tray directly behind the BluRay logo. It proved to be too thick as the door closed and immediately opened. Using a scalpel I trimmed it down so that there was barely enough rubber to cover the 3M tape strip underneath it. This actually took two tries - after the first it was still too thick and the tray reopened itself. The final thickness was only about 0.020 inches and the length was about 0.7 inches. I placed it in the same spot... only slightly below the top edge so that it was not visible when the door was closed. My vibration is completely gone!
You have to understand that the vibration I am talking about when it occurs is quite loud and consistently reproducable using the same disks .... easily heard as a loud noise several feet away and still quite noticeable when the entertainment center door is closed. I have tried all of the additional disks that I have found that were vibrating and am not able to reproduce any noise whatsoever. Even disks that did not vibrate prior to this but made what I considered normal spinning noises are much more quiet. I am certain that the disks I have sent you will now work fine as well.
I hope you can correct this with a firmware update.... again I am not certain that this is not a hardware issue. If you have a BDP-83 and disks that vibrate in it you may want to try this fix. If it works it may be easier to manufacture/insert a similar strip into the players to stabilize the tray and stop any vibrations without a major hardware redesign.
Joel
post #6900 of 38733
TIA.
I just watched the same edition of Planet Earth on my Oppo83 and saw no anomalies or pulsing throughout the entire waterfall scene you reference above. I watched it 3 times and couldn't find the pulsing you referred to. Could it be the display? I'm watching on a Pioneer 151.
I have 108024p turned off and 36bit deep color turned on. Picture and sound are absolutely fabulous on Planet Earth.
