AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-83 Owner's Thread [technical talk only]
Official OPPO BDP-83 Owner's Thread [technical talk only] - Page 269
post #8041 of 38777
Originally Posted by HT_n_Me View Post
Is this done with the remote via the audio button?
Via the Audio button on the remote control, not through the Audio menu option of the disc.
However, I will make a couple amendments to my statement:
1. The first track is silent for the first minute, no matter if you are using PCM or DTS on this disc. Switching between DTS and PCM during this stage will show changes on the OSD and front panel of the player, but there is no audio acquisition on my receivers (verified with digital coaxial and optical to PIoneer Elite VSX-54TXH and HDMI to Integra DTC-9.8).
2. I redid my tests, and the breaks I was having with losing the DTS track when changing chapters was due to a handshaking problem with the projector. I disconnected the projector from the chain and no longer have the problem. I will trouble shoot this problem tomorrow night when I have time to swap out cables, mess with resolutions and timings on the VP50.
post #8042 of 38777
Some people accept cables swaps every few weeks or days as a fact of life and maybe it is but thats not for me.
I don't think anyone is saying this. What we are saying is that you should never assume anything is working properly just because it was working properly. I have gone through a couple of HDMI cables, and one was between my Optoma HD-81 video processor breakout box and the projector itself in the middle of a session.
Refusing to do any kind of diagnostic testing, which I would assume would include trying other cables, is being unfair to OPPO. You can't reasonably call something defective, especially if in your previous situation with OPPO, it was discovered that your HDMI cable was the cause of your malfunction.
You have every right to have the player exchanged or refunded, but assuming defects doesn't help any of the parties involved.
post #8043 of 38777
Smarty/Neuromancer;
I have swapped cables out. The Oppo did play. I put the "bad" cable back in, the Oppo did play. I put in a much more expensive cable, about half the cost of the Oppo and it played. Yesterday the Oppo quit playing with that cable - for a while - then it started playing again with the same cable. This is the second time it has done this.
Now Oppo says because its the second time its done it, it proves its the cable and not their unit. To me it proves the opposite. If a bad "cable" works again then something is not right somewhere. So I swap those inputs on my processor and I try other equipment. I still have my 983 and 980 and they plus my DVR work fine with the "bad" cable. The input used now for the Oppo is a different input from the time it failed before.
I've swapped cables and check the inputs on my processor as best I can and things work fine - the only time they don't is when the Oppo is connected.
post #8044 of 38777
Smarty/Neuromancer;
So, if I'm following correctly, what you're saying is:
  • You had intermittent problems with two different HDMI cables.
  • You had the intermittent problems on two different processor inputs.
  • The two cables connected during the intermittent problems have not shown any issues with any other HDMI gear.
If that is correct then I'd say fingers point towards the Oppo. If part of that is not true then I'd say you have to rule it out before pointing the finger towards the Oppo.
post #8045 of 38777
i don't own an 83 (yet)... however...
if the 3 items that geof listed have been proven "true", then it sure sounds like to me that the hdmi port on the oppo is wonky...
post #8046 of 38777
I haven't been following closely, but if there is a video processor or receiver involved, I would first try to simplify the diagnosis by eliminating it and connecting directly to the display.
-Bill
post #8047 of 38777
i want my oppo does anyone have a updated release date or idea when this beast will be available?
post #8048 of 38777
You can't have it both ways here. On the one hand you say "you should never assume anything is working properly just because it was working properly" and on the other hand you say "assuming defects doesn't help any of the parties involved".
post #8049 of 38777
Originally Posted by narkspud View Post
Paris Hilton's singing can be trying for any receiver to reproduce.
Too true.
However, I'm wondering if there is a problem with dts HD MA 7.1 discs. I think this may have been the first dts HD MA 7.1 disc I've tried with this player.
post #8050 of 38777
Originally Posted by electronics craz View Post
...anyone have a updated release date....
Too often asked, with the same response...when's it's ready! Read the first post of this thread!
post #8051 of 38777
I to want my Oppo 83 so throw me under the bus I will take it for everyone.
I want to be able to act like I'm an entitlest also.
Don't hesatate to delete at any time.
post #8052 of 38777
-Bill
+1
Take that AVR out of the picture and test.
post #8053 of 38777
Originally Posted by xradman View Post
Too true.
I watched Rambo last night, I am pretty sure it is 7.1 and I had no problems.
post #8054 of 38777
Thanks Gonk, I forgot that it would downmix the multi-channel stuff. Someone has to report back about this experiment!
Well this worked but with out pleasing results. I disconnected the LF RF leads from the BDP-83 and attached them to the L & R audio out, leaving the balance of the 5.1 connected appropriately.
I was able to achieve a center channel as the L & R have the entire audio tracks down mixed to “stereo”. The sounds stage I experienced in 4.1 (no center speaker, which causes this whole issue) was, at best, a lame attempt of an old Fisher Receiver in Dobly Surround mode from a stereo source. Ugh. The front stage seamed flat and lacking fidelity of which I still question why. Add to that though, the high res LFE SL & SR and the image became quite interesting. I used the fader on the DENON AVR-3805 to try and balance out but became board with the result.
I put everything back together to begin my next test. See post #8069
Thank you
mopar
post #8055 of 38777
Good Morning
Originally Posted by mopar426 View Post
Question: Who out there does NOT have an actual Center Channel Speaker?
Originally Posted by jam88 View Post
That being said, this issue reported by mopar426 must be resolved by Oppo. It will affect others with 4.1 setups and non-HDMI receivers. This functionality has been as basic as it comes in HT for many years.
In search of a Center Channel:
All 5.1 Analog connections from BDP-83 to DENON AVR-3805 connected.
Each test starts with BDP-83 off with no disc in player.
Test disc is Dark Knight.
Test 1: Original Configuration. My current system w/ no Physical Center Channel Speaker.
DENON AVR-3805 SET @ 4.1, Power on throughout test.
BDP-83 SET @ 4.1, prior to removing disc and powering down.
No physical Center Channel Speaker so Actual Center Sound is N/A.
1. Power on BDP-83 = Phantom Center Channel Sound, NO.
2. In BDP-83 audio set up, turn on C to activate 5.1 = Phantom Center Channel Sound, NO.
3. In BDP-83 audio set up, turn off C to activate 4.1 = Phantom Center Channel Sound, YES.
Test 2: Connected Center Channel Speaker to DENON AVR-3805 binding posts.
DENON AVR-3805 SET @ 5.1, Power on throughout test
Center Channel Speaker now connected
1. Power on BDP-83 = Phantom Center Channel Sound, NO. Actual Center Channel Sound, YES.
2. In BDP-83 audio set up, turn on C to activate 5.1 = Phantom Center Channel Sound, NO. Actual Center Channel Sound, YES.
3. In BDP-83 audio set up, turn off C to activate 4.1 = Phantom Center Channel Sound, YES. Actual Center Channel Sound, NO.
Test 3: Connected Center Channel Speaker to DENON AVR-3805 binding posts.
BDP-83 SET @ 5.1, prior to removing disc and powering down.
Center Channel Speaker still connected
2. In BDP-83 audio set up, turn off C to activate 4.1 = Phantom Center Channel Sound, YES. Actual Center Channel Sound, NO.
3. In BDP-83 audio set up, turn on C to activate 5.1 = Phantom Center Channel Sound, NO. Actual Center Channel Sound, YES.
From this test alone the trend I am seeing is that the quasi default internal setting for 5.1 down mixing is 5.1. When changed in the audio set up menu to 4.1 the desired result is achieved. When changed back to 5.1 the desired result is achieved. However the unit is failing to keep the down mix settings in memory upon powering off, even though menu is still in the state it was left when powered off. The menu is correct but the setting defaults back to 5.1.
Oppo has been sent this information as well.
Thank you
mopar
post #8056 of 38777
Smarty/Neuromancer;
Frustrating ain't it. It's not enough you're having issues but you have to sustain the harassment from "Gang Oppo". I know the feeling.
That said, it seems just from reading this thread that HDMI is a technology that has never been ready for prime time. I have no issues but I only connect my video directly to my TV.
post #8057 of 38777
"Gang Oppo?"??? How about you elaborate on how you "know the feeling?"
By the way, how is Moulin Rogue lip sync problems? Did the latest firmware fix those issues?
post #8058 of 38777
Smarty/Neuromancer;
HDMI plugs are only friction fit. It only takes a little bit of looseness to lose the connection. And of course pulling the plug and putting it back in again cures that -- even with the same cable.
If the problem recurs, try the "wiggle test": Grasp the HDMI cord about one inch from the socket, press gently STRAIGHT IN towards the socket, and give a gentle wiggle. Try both ends of the cable. If that cures the problem then the most likely cause is that the weight or bending of the cable near the socket is causing the plug to shift in the socket just enough to make the electrical connection marginal.
If that doesn't work, get a flashlight and carefully inspect the socket and the plug for signs off bent pins. Again, check the sockets and plugs at both ends. If there is any mechanical damage at either end then that too can cause a marginal connection.
You didn't say what length cables you are using but I'm presuming they are the same sort of length as the one included with the player. If not, then cable length may be an issue. And of course if you are daisy-chaining HDMI cables (any cable in the path from the player all the way to the display) or using wall plates, then THAT can be the problem.
Some devices begin the HDMI handshake too soon after the power up -- before they are really ready to do what needs to be done. If your receiver or display is like that, then changing the order in which you power things up, or adding a little delay between powering up each device, is the usual cure.
The latest firmware includes improvements in HDMI in the Oppo. Be sure you are testing with that installed.
Keep in mind that the Oppo is a 1080p device, an HDMI V1.3 device, a "Deep Color" device, and an HDMI CEC device. All of these put more demands on the next device in the HDMI chain -- and on the cable quality.
To see if THAT'S the problem temporarily do this:
1) Turn off Deep Color and HDMI CEC in the Oppo.
2) Set the Oppo to 480p output (not 480i). This is the "simplest" resolution for HDMI devices.
3) Set an explicit HDMI color space choice instead of using Auto. Typically you will use YCbCr 4:4:4.
4) Set the video system in the Oppo to NTSC instead of Multi System.
5) Set audio output from the Oppo to HDMI LPCM.
With those temporary settings, see if the HDMI handshake works more reliably when you turn things on. If so, you can start changing them back one by one to what you normally use to see which might be causing the problem.
For example, if you find that 1080i output works reliably but 1080p output doesn't work reliably, that indicates either a marginal cable or a marginal socket at one end or the other. 1080p is higher bandwidth and puts more demands on cable/socket quality.
Another test is to take your Oppo to a friend's house or perhaps to your favorite store, and try it with another receiver. If it works reliably on the other receiver, then that indicates a problem either in your receiver or your display -- again, probably triggered by the higher bandwidth stuff the Oppo does compared to your other source devices.
Sorting out HDMI issues can be frustrating. But if you approach it logically, you will soon be able to isolate what's giving you the problem.
--Bob
post #8059 of 38777
That's been intuitively obvious to me since I bought my first HDMI equipment last year. In the time since, all the reading and discussion about issues with HDMI, as well as experience connecting it and using it, have convinced me that HDMI is, first and foremost, a copy-protection system (yes, I know that's actually HDCP) and only secondarily, if even that high in priority, a means for delivery of problem-free HD content. As far as the companies behind the standard are concerned, it's pretty clear they are willing to accept myriad problems in video delivery if it makes content more secure. I certainly don't lay the blame for that at the feet of OPPO, but knowing that makes me want to support the efforts of companies like those that produce the HDFury2 all the more.
post #8060 of 38777
I think the biggest single problem with HDMI is the stupid, underdesigned connector. I have solved this with the very nice PPC latching cables from bettercables.com. Under $45 for 3 feet. There are a few other less elegant but cheaper solutions out there, as well. It's worth it to me for the peace of mind, and with it most HDMI related issues disappear.
post #8061 of 38777
Some people have had good luck using the Monoprice port savers:
These are spec'd so they are a tight fit, making it hard for the cables to come loose. They are very inexpensive so it's worth a try.
post #8062 of 38777
Current status.
Total Votes: 350
Pending Votes: 134 (38.3 %)
Yes Votes: 175 (50.0 %)
No Votes: 41 (11.7 %)
Approval is at 81.0% currently with votes taken.
post #8063 of 38777
No, not really. They gave me a song and dance about cables going bad and how this is acceptable to them.
The cable that came with the unit was the first one that went bad and as it turned out, worked fine with other devices - even the 83 when I tried it again. I kept the better cable attached though.
In my system, its not acceptable to swap cables every few days or weeks. you might find that to be okay but I find it to be over the top. I have never had any issues with other components and connections like this. Maybe I'm not as hardcore as you are but my system needs to be responsive for me and there when I want it, I don't want to troubleshoot cable problems and wind up replacing them (cables that DO work fine later even with that device) every time I use it.
Wally,
Swapping cables out weekly is not an option, especially since these same cables seem to work with other components. I don't recall anyone else in the EAP reporting a similar problem. There is a possibility that the problem could be hardware related. The only remedy I see at this point is to either swap the player for a replacement or return it for a refund. I would probably try the former 1st.
Just my $.02.
Willie
post #8064 of 38777
Neuromancer
Night at the Opera finally plays correctly with out drop outs using the new firmware. I did have the OPPO completely lock up when I tried to switch from "audio" to "video with audio" using the visual menu on the screen. I selected pcm and then selected "video" which should have given me 2 channel audio with video and the OPPO completely locked up;. I had to shut of and restart the machine. Its on to checking other issues now. So far much happier with the results.
post #8065 of 38777
Too true.
You don't mention what the problem is that concerns you.
In any case, I've played a few DTS HD MA 7.1 disks in the 83 with no problems.
post #8066 of 38777
You want to switch off Secondary Audio processing without using Setup? I have this in the FAQ: Can I toggle Secondary Audio on and off without using the setup menu?
-Bill
Bill,
No, what I would like to do is while bitstreaming and secondary
audio turned OFF have the ability to push the SAP button on the
remote and have the OPPO switch to PCM(decode internally) and
turn secondary audio ON automatically.
Basically, in the middle of a movie if you decide you want to
watch some PIP while bitstreaming, you can at the push of a
single button.
I don't think any Blu-ray players can do this. It would be
nice but definately not a must.
Is it even possible? It doesn't seem so based on the FAQ guide.
Mike
post #8067 of 38777
I had some pops and crackles from the speaker with Repo, the Genetic Opera. I was bitstreaming dts HD MA 7.1 track to my Denon 3808Ci receiver. It happened in couple of places, but could not be replicated when rewound and played again. This is with the latest FW.
Too true.
The problem is random pops and crackles on Repo, the Genetic Opera.
post #8068 of 38777
Originally Posted by JohnAV View Post
Current status.
Total Votes: 350
Any more recent ETA for this unit for the general public? Est MSRP?
post #8069 of 38777
Thank you
mopar
Thanks for the detailed report mopar426 and for sending the information to Oppo. I'm sure that everybody in the same boat as us will appreciate it.
From the tests you've performed, your conclusion appears inescapable. It appears to be an initialization issue when the player is started. Luckily for the time being, cycling the CC setup from 5.1 to 4.1 engages the phantom feature; it's a work around until Oppo addresses the issue. I'm sure they'll fix this issue quickly as initialization bugs are fairly easy to correct.
post #8070 of 38777
Originally Posted by petmic10 View Post
Bill,
single button.
Mike
Most BD-JAVA and BD-Live discs will over-ride the player's setting for SAP as soon as you select an SAP option in the disc's software. There are some that turn on SAP as soon as you load the menu. There's really no standard on BD discs for this.
