Originally Posted by Ryan30
With 2.04 it froze just as the rogue broken robots crash through the window, around the 56 or 59 minute mark. It also freezes just as EVE reboots in the garbage heap around the 1:12 mark. The first freeze was corrected with 2.05 but the other is still there. If you hit rewind or fast forward though before the freeze then it won't happen. It also won't freeze again on the same play after the initial freeze. However, if the movie is left alone to play freely it will freeze everytime.
What if you go through the menu and select the chapter where the skip is as soon as you put in the disc? I'm just wondering if I have to sit and watch the movie all the way to properly test it.
Once I test it I'll let you know the results.
