Hello all,
I bought this television a few months back when my trusty Westinghouse suffered and ill fate. This TV is great but there are a couple issues I notices and hope to find some advice or some help.
I notice that on this TV when using my Xbox 360 with HDMI regardless of the resolution I use it does not use 1:1 pixel ratio. It looks like the TV was setup to overscan slightly (like on older CRTs).
I'm not referring to the aspect ratio just the borders of the screen(top and sides) being over scanned slightly. My late Westinghouse would display the entire image but this TV does not. Unless I use the PC input(VGA) which honestly on this TV isn't very good. The image displayed is to blurry and while in this mode you can not change the sharpness or color settings.
Has anyone discovered a way to get it to display the whole image and or adjust the sharpness and color for the VGA mode input?
