AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Samsung LN52A550 or Toshiba 52RV535U ?
post #1 of 11
The Sammy is $100 more and has terrible speakers. Is there any reason to go with the Sammy?
post #2 of 11
This accusation is false in my opinion. I had this set since September plus an AV reveiver with decent speakers available to me at any time. I find the set's speakers very acceptable. To get the best out of them I selected MUSIC for the audio setting.
post #3 of 11
None of the sets from the factory have what I would consider very good sound. I don't understsand how people can have a big screen set up with the stock speakers, as the sound is at least 40% if not more of the experience.
post #4 of 11
As to the Sammy speakers, hundreds of reviewers made them their #1 con about the unit. Does anyone have an opinion about the 2 TV's?
post #5 of 11
Based on reviews, the Sammy is the better display. IMO, you should be using external speakers anyway.
post #6 of 11
One thing the 535u has that the 550 doesnt is srt. It will improve your picture when viewing 480/720 and dvd sources.
http://www.avsforum.com/avs-vb/showthread.php?t=1113668
If possible find a place you can compare with similiar picture settings.
post #7 of 11
uhhh the set speakers are AWFUL. One of the worst for sure...
Anyone with a good sized LCD should opt for an avr receiver and some decent speakers.
post #8 of 11
A soundbar can also be a good option.
post #9 of 11
I have the 535U and the speakers are ok. They are no better/worse than any other TV speakers I have used. IMO SRT is crap, it really is just edge enhancment. However SD on mine looks great with it off. I have just basic cable and I was very suprised at how good the picture was.
post #10 of 11
How are your srt modes and levels set?
post #11 of 11
I have played with them all. To me it really just looks like someone cranked the sharpness. But like I said SD looks great so I really don't have an issue with it.
