After nobody volunteered some 5.0 BR's to test my non-bass management, I went through my latest purchases and decided to use Anna Bolena for it. I had felt that D'Arcangelo was a bit weak, compared to Ramey in Semiramide, a DTS 5.1 recording, that I had used during my set-up period.
To make the long story short, I ended up with 60 hz as the cut-off for the fronts. D'Arcangelo sounded definitely fuller, while Meli lost some of his brightness. The localization of the voices in a group scene was also better. I would be willing to bet a dinner that I can hear the difference in a blind test.
I then played the Firebird again with this set-up, and I don't think I could tell the difference to my previous setting in a blind test, although I thought I still favored my old setting a bit. (Takes about 30 seconds to change and by then memory is already fading...)
So I will have better sound for 5.0's in the future, and I thank Andre, Kal and Lee for it.
