Originally Posted by
Mark Petersen
When I first looked at the low APL greyscale test pattern, I assumed that I was seeing brightness compression very similar to what happens with dynamic gamma with a Sony DI implementation.
I think you probably were, except that Optoma adds lamp modulation on top of it. Put another way, looks like the Optoma uses dynamic gamma to me (like the Planar does) and the suggestion to lower the Contrast setting would probably lower the native on/off CR, much like people could lower the Contrast setting on the Sony's to get rid of brightness compression, but at the expense of native/static and dynamic on/off CRs.
Mark Petersen
But with dynamic gamma, it's the inability to boost luminance in the upper ranges that causes BC.
While the Optoma looks like it could use the lamp to avoid brightness compression, it still looks like it was doing dynamic gamma in your case. Maybe the TI part is doing the dynamic gamma and the Optoma part is doing the bulb, causing the compression. Either way I think your measurements show that gamma was changed dynamically, any way you look at it.
Mark Petersen
We can see from the relative white point graph that DB doesn't have this problem however.
In this case it looks like the Optoma projector could have used the lamp to get more peak lumens for the same CR without using dynamic gamma, but TI's part may include dynamic gamma and need something to be done to avoid having it do that (like telling it different iris positions than you actually have because the lamp is compensating).
Mark Petersen
At 100 IRE, it's delivering 15% higher brightness at about 1/2 of the black level as the DB=off setting. Pretty impressive.
I agree that it is impressive, but looks like another case of a DLP manufacturer using DB to deliver more lumens, instead of to deliver more CR. What I mean is it looks like they could have given just as much CR natively, but with lower lumens. That is useful for people looking for high lumens and still caring about CR, but for those who were fine with less lumens (like those using a high gain screen) it doesn't necessarily give them more on/off CR that they could have achieved just by leaving 2 irises closed down (like the Marantz 11S2 and Sharp 20k). And without the DB artifacts.
Mark Petersen
So it seems like the technology is capable of a good greyscale without brightness compression.
If it is used for higher lumens when you have high CR and they start at a low static on/off CR iris position and end at a much higher static on/off CR iris position. If it was used for even higher CR at lower lumens that generally come with fairly closed down irises then I'm not sure it would still have the above advantage. It looks to me like they are using the fact that static on/off CR can go up significantly when going from a very open iris to closed down with DLP and that isn't likely to apply as much if they started with the irises closed down a fair amount for higher native or static on/off CR.
Just for the sake of trying to figure out how they achieve this, let's go with your 2000:1 without the DB on. If the lamp is turned down low (I'll say 60% of max for this example, although I'm not sure they could go that low) and they could shut 1 or 2 irises down in a way that would lower lumens by 30% and increase static on/off CR by 2.3x (to 4600:1) then they could have 1/2 the black level and 15% higher white level in a dark image with a little bit of white and the lamp at max with the iris(es) shut down.
In the above case what they largely would have achieved is higher lumens at around 5k:1 on/off as opposed to higher on/off CR.
Sorry if I missed it, but did you notice any difference in how loud the projector was between low lamp and high lamp? Is so, then how about between DB on with the lamp on low and DB off with the same? If they are pushing the lamp up to and maybe even beyond what it does for high lamp then some extra cooling might be necessary, especially for very dark movies where the iris might remain shut down a lot.
It would be interesting to see graphs like yours for the Lumis and see if they did things similarly.
--Darin
