Here is a comparison chart I have composed so far for all the info. available. Hope it helps.
The North American M-Series is NOT a direct import from Europe or any other part of the world. It is designated for the custom installer market in North America. Although the specification is very similar to the European M-Series, they have different firmware (i.e. No ISFccc mode - See Note in the 3rd section) in North America
Note: First number is for the 50"; Second is for the 60".
| xx20 | M (N. America) | 111/151 | 101/141 | A (Europe) | LX-XX90 | |
| Physical | ||||||
| Speakers | Bottom* | Optional | Side | None | Optional | Optional |
| Stand | Raised | Optional | Normal | Optional | Optional | Optional |
| Depth | 3.75" | 2.5" | 3.75" | 2.5" | 2.5" | 3.75 |
| HDMI | 4 | 2 | 4 | 4 | 4 | 3 |
| DVI-D(HDCP) | 0 | 1 | 0 | 1 | 0 | 0 |
| D-SUB 15** | 1 | 1 | 1 | 1 | 1 | 1 |
| USB | 1 | 0 | 1 | 0 | 1 | 1 |
| Component | 1 | 1 | 1 | 1 | 1 | 1 |
| Composite | 3 | 1 | 3 | 1 | 1 | 1 |
| S-Video | 1 | 0 | 1 | 0 | 0 | 0 |
| Audio-In*** | 5 | 2 | 5 | 0 | 2 | 3 |
| Sensors | 1 Light | 1 Light | 2 Color/Light | 1 Light | 2 Color/Light | 1 Light |
| IR Repeater | 0 | 1 | 1 | 1 | 0 | 0 |
| Digital Audio Out | 1 | 0 | 1 | 0 | 1 | 1 |
| RS-232 | 1 | 1 | 1 | 1 | 2 | 1 |
| LAN**** | 1 (For HMG) | 1 (For WCS) | 1 (For HMG) | 1 (For WCS) | 1 (For HMG) | 0 |
| ANT Terminal | 1 | 0 | 1 | 0 | 7***** | 5****** |
| AR Filter | xx20 Specific | Elite Specific+ | Elite Specific | Elite Specific | Unknown | Unknown |
| Media Receiver | No | No | No | No | Separate | No |
- *xx20 Speaker can be mounted on the top; Side mounting Elite speakers also work.
- **The D-SUB 15 Connection seems to be able to configure for Component video.
- ***Including both RCA and Headphone jacks
- ****HMG=Home Media Gallary; WCS=Web Control System
- *****Euro-SCART: 3; CI Slot: 2; Ant: 2;
- ******Euro-SCART: 3; CI Slot: 1; Ant: 1;
- + It is known that the M series share the same replacement PDP parts (AWU1378 for the 500M & 101; AWU1347 for the 600M, 151 & 141) and service manual with the Signature series. However, the glass is not hand picked like the Elites.
- The Pro-111fd speaker brackets will need some modification to fit on the KRP-500M. The Pro-151fd speaker brackets fit on the KRP-600M with NO modification needed.
- The Pro-151fd stand can be used on Pro-141fd and KRP-600m. Parts Number: AXY1212 - STAND ACCESSORY ASSY (Nuts & Screws); AXY1221 - BASE COVER ASS'Y; AXY1222 - STAND PIPE L ASS'Y (Need to order 2). You can order them directly from Pioneer Parts: http://parts.pioneerelectronics.com/...lNum=PRO-151FD.
| Picture Control | ||||||
| Optimum | Yes (Light) | Yes (Light) | Yes (L & C) | Yes (Light) | Yes (L & C) | Yes (Light) |
| Performance* | Performance | Standard | Performance | Standard | Standard | Standard |
| Dynamic | Yes | Yes | No | Yes | Yes | Yes |
| Movie | Yes | Yes | Yes | Yes | Yes | Yes |
| Pure | No | Yes | Yes | Yes | Yes | No |
| Sport | Yes | Yes | Yes | Yes | No | Yes |
| Game | Yes | Yes | Yes | Yes | Yes | Yes |
| Standard** | Standard | User | Standard | User | User | User |
| Contrast | Yes | Yes | Yes | Yes | Yes | Yes |
| Brightness | Yes | Yes | Yes | Yes | Yes | Yes |
| Color | Yes | Yes | Yes | Yes | Yes | Yes |
| Tint | Yes | Yes | Yes | Yes | Yes | Yes |
| Sharpness | Yes | Yes | Yes | Yes | Yes | Yes |
| Color Temp | Fixed | Yes | Yes | Yes | Yes | Yes |
| Gamma | Fixed | Yes | Yes | Yes | Yes | Yes |
- Optimum: automatically adjusts the image quality for the brightness level of the viewing area
- *Performance: for a highly defined image in a normally bright room (called "Standard" in M, 101/141 and A)
- Dynamic: for a very sharp image with maximum contrast but manual image quality adjustment unavailable
- Movies: for movies
- Pure: reflects input signals as faithfully as possible for checking image materials, for example
- Sport: for sports programs
- Game: lowers image brightness for easier viewing
- **Standard: allows customizing settings as desired (called "User" in M, 101/141 and A)
| -- xx20 -- | M (N. America) | 111/151 | 101/141 | A (Europe) | LX-XX90 | |
| Pro-Adjust Control | ||||||
| Intelligent Mode | No | Yes | Yes | Yes | Yes | Yes |
| DRE Picture | Fixed | Yes | Yes | Yes | Yes | Yes |
| Black Level | Fixed | Yes | Yes | Yes | Yes | Yes |
| Automatic Contrast Limiter | Fixed | Yes | Yes | Yes | Yes | Yes |
| Enhancer Mode | Fixed | Yes | Yes | Yes | Yes | Yes |
| Color Transient Improvement | Fixed | Yes | Yes | Yes | Yes | Yes |
| Color Space (Mode 1 & 2) | Fixed | Yes | Yes | Yes | Yes | Yes |
| 3DYC | Fixed | Yes | Yes | Yes | Yes | Yes |
| I-P Mode | No | Yes | Yes | Yes | Yes | Yes |
| Drive Mode | No | Yes | No | Yes | Yes | Yes |
| Game Control Pref. | Yes | Yes | Yes | Yes | Yes | Yes |
| Blue Only Mode | No | Yes | No | Yes | No | No |
| ISFccc (Day, Night, Auto) | No | No# | D, N & A | D, N & A | D, N & A | D,N; "H": D,N,A |
- 3DYC: optimizes characteristics for separating brightness signals from color signals (Off, High, Mid, Low)
- I-P Mode: provides optimum conversion from interlace signals to progressive signals (1=Optimizes video images; 2=Standard setting; 3=Optimizes still images)
- Drive Mode: switches image display frequency (1=Standard settings; 2=Enhances readability for horizontally scrolling text; 3=Optimizes movie content)
- Game Control Pref.: establishes a gaming preference for image quality or operability (Off=Image quality preferred; On=Operability preferred)
- Blue Only Mode: displays images in blue only (Off, On)
- # By Using a Custom Profile (NOT Supported by Pioneer) developed by ControlCal, North America M-series can have ISFccc Auto, Day, Night enabled. ControlCal will also provide a rollback profile in order for owners to avoid any potential warranty dispute with Pioneer. For details, contact ControlCal at www.controlcal.com.
| Other Spec. | ||||||
| Factory Break-in | Unknown | 50 Hours | 50 Hours | 100 Hours | Unknown | Unknown |
| Power Consumption* | 436W/524W | 396W/492W | 436W/524W | 384W/481W | 440W/530W** | 420W/510W |
| Weight*** | 74.1/112.0 lbs | 69.2/110 lbs | 74.5/112.4 lbs | 69.2/110 lbs | 69.2/110 lbs | 73.9/112 lbs |
| Speakers | 18W+18W(6Ω) | 6Ω-16Ω/9W+9W@6Ω | 18W+18W(6Ω) | N/A | 18W+18W(6Ω) | 18W+18W(6Ω) |
| Warranty | 1 | 1 | 2 | 2 | 1 | 1 |
- *All models standby consume less than 0.3W (N. America)/0.4W (Europe).
- **Combined both the panel and media receiver (52W).
- ***Weight are without stand, speakers and/or media receiver.
. Its actually cheaper than the 6020 non-elite right now. Its really a no brainer if it works for your application. This of coarse is speaking about the 60" version. I dont know how the 50" plays out right now.
