I want to add external sound to an LCD TV. I don't want to run wires all over the place, so I'm looking at soundbar solutions.
I was looking at the Marantz ES7001 SSX Sound bar (happened to be a good deal at Big River). http://us.marantz.com/Products/2241.asp
For slightly less, there is the Sony HT-CT100 which, believe it or not, has gotten good reviews. http://www.sonystyle.com/webapp/wcs/...52921665361523
The Marantzt has two hdmi 1.1 ins and one out. It also has a built in amp and can decode Dobly Digital, DTS, and Dolby Pro Logic II. It can receive PCM audio.
The Sony has 3 HDMI inputs and 1 out (1.3 I think). It can decode Dolby and DTS surround. It can also accept uncompressed PCM soundtracks.
I don't know much about how to hook this stuff up. I have a Fios HD-DVR and a PS3 (will use for gaming and BluRay).
From what I understand, the PS3 will process the audio and send it to the speaker as PCM. In the case of the Marantz, since it is an HDMI 1.1 connection, the audio will not be automatically lipsynched to the video image. Also since it is 1.1, there will be no support for deep color.
With the Sony, the audio and image should be synched.
Quesitons:
Are either of these sound bars decent?
Does HDMI 1.1 affect image quality a lot?
How out of synch will audio be on the Marantz?
Is there some other way to hook the Marnatz up that will avoid lip synch issues?
Quesitons:
