AVS › AVS Forum › Display Devices › Flat Panel General & New FP Tech › Burn-in image using a DVR
post #1 of 11
I have the Samsung LN40A550 and I just got a DVR.
My question is how long would the DVR have to be in pause before I damage my screen with burn-in ?
post #2 of 11
any more than 15 minutes would be enough...
post #3 of 11
actually 5 minutes should do it.
post #4 of 11
post #5 of 11
OP,
Yes, we were joking.
the LN40A550 is an LCD.
You have absolutly nothing to worry about unless you plan on leaving it paused for a year or two.
The worse youll get by leaving it like that for hours and hours is a little image persistance. And that probably wont even happen.
don't worry about it at all. thats one of the plusses about LCD.
post #6 of 11
Originally Posted by ramazur View Post
Your "thanks" were premature. Both replies are pure crap. The authors should be ashamed for taking advantage of a new member.
Coulda swore I saw you say something like "Having a sense of humor is a virtue. Try it. ".
post #7 of 11
yes I have that model, I've left it on for two days by accident, paused on a program from my TiVo. No problems since it's LCD.
post #8 of 11
I apologize. We are on the opposite sides of the great plasma-LCD debate but I respect your position and its consistency. A smiley face would have helped but it is still my fault. Sorry. Post deleted.
post #9 of 11
Thanks for the responses.
No problem about the joking.
If you take life to serious, you'll miss out on all the laughs.
I am new at this forum and leaning how it works.
post #10 of 11
Well LCDs can burn in, but usually only cheaper quality ones. Technically it's called Overdrive, not burn in.
That said...you have a quality LCD and should have nothing to fear. Maybe if you keep it on a for a few months straight you might get overdrive...but who knows.
post #11 of 11
Overdrive.
I have never heard that to describe burning in of a image.
Like I said I am new and I will have look that up.
Thanks for the terminology.
