OK a few replies....
Originally Posted by
Arcadia88
YES! Thanks Isumu. The 8720 has what amounts to zero lag. I am going from my ps3 and htpc to a sony receiver to the 8720 with hdmi and no lag. I hope having to buy a new reciever isn't making you as mad as I would have been.
Haha, I was a little miffed that my state of the art Yamaha HTR-5990 was finally outdated a bit, but I'll live
coderguy
Off-topic a bit, but for people playing Skyrim, it will look better if you change the textures...
coderguy, I read all about the textures and how great they look, and was going to apply them, until I read NUMEROUS horror stories on both the Nexus *and* official Beth forums, about they cause CTD's up the wazoo. They cause the game to be very unstable and crash prone. This was about a month or so ago on patch 1.3 so I don't know about today...have they fixed the Hi-res tex patch so that it's more stable?
ondaedg
You may want to check to see if the receiver is introducing lag first. Based on what I've read, the W6000 is quite possibly the best projector for gaming with very low input lag times. If the receiver is introducing lag, check to see if you can bypass or disable any of the video processing capabilities of it. The problem with bypassing the receiver is that you lose the lossless sound capabilities coming from the PS3 by having to use optical.
I don't think I'll be getting any lag going through my receiver, because I didn't get any when using my 8720 at all. I was just curious if by passing it normally yields any benefits at all.
I have come with a workaround solution for the receiver/1080p dilemma. I am now running a DVI-HDMI cable straight from my ATI 5870 card to my pj, while simultaneously running an HDMI cable connection from the 5870 to my receiver *just* for the audio! It actually works beautifully! I get full 1080p resolution from the ATI DVI connection to the pj, and lossless HD audio from my HDMI connection to the receiver. Saves me having to rush out and buy a receiver right away
Gotta love this ATI 5870 card!
